vk3eka(at)bigpond.net.au Guest
Posted: Fri Aug 28, 2009 10:38 pm Post subject: 601XL Cowling |
Hi Guys,
I received my camlocs for the cowling from ASSC the other day.
Attached is a photo. The photo shows:-
40S5-3S SS CAMLOC STUD | Quote: | | 4002-NS CAMLOC GROMMET 214-16ND CAMLOC 4002 Receptacle |
How do I get the stud into the grommet. Do I have to remove the pin? If so, how?
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
504.63 KB |
4368 Time(s) |
Posted: Fri Aug 28, 2009 11:22 pm Post subject: 601XL Cowling |
Craig,
Thanks for that.
A pair of needle nose pliers did the same thing. I was looking for a complicated solution to what is a simple problem.
Peter
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Craig Payne
Sent: Saturday, 29 August 2009 5:08 PM
Subject: RE: 601XL Cowling
I haven’t used the grommets on mine but this is how I get the camloc studs through the holes I drill. Compress the camloc and its spring with the special camloc pliers. Then you should be able to “hook” the shaft with the pin through the grommet. Try this document:
www.afscamloc.net/xua/downloads/Camloc%20Quick%20Release%20Fasteners.pdf
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Peter W Johnson
Sent: Saturday, August 29, 2009 12:38 AM
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: 601XL Cowling
Hi Guys,
Cheers
Peter
Wonthaggi Australia
| Quote: | | 214-16ND CAMLOC 4002 Receptacle | 0 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 1 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 2 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 3 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 4 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 5 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 6 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 7 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 8 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 90123
maarten versteeg
Posted: Sat Aug 29, 2009 5:12 am Post subject: 601XL Cowling |
Hello,
Camlocs can just be inserted in the grommet by compressing the
spring and then it will fit through the hole. There are special
pliers available, but I just took a little strip of steel and
made a cutout at one end that can support the camloc under the
flange, then by holding the steel piece in your hand you can now
easily push on the head of the camloc and compress the spring and
then maneuver it through the grommet or aluminum plate. I can
send you a picture of the little tool if this is not clear but I
am on the road at this moment.
Maarten, 601XL, plans build
| Quote: | Hi Guys,
how?
Cheers
Peter
Wonthaggi Australia
_________________ Maarten Versteeg
601XL scratch building wings |
