Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
sabrina
Posted: Tue Sep 01, 2009 2:19 pm Post subject: Re: UK LAA mods - official information |
psm(at)att.net Guest
Posted: Tue Sep 01, 2009 5:21 pm Post subject: UK LAA mods - official information |
Hi Sabrina,
I was thinking of implementing the aileron balance change and looking
at the spar carry-through reinforcement with no real idea about what
it does or whether it is necessary or not.
I called and talked to Sebastian Heintz a few days ago and learned
that Chris is planning to issue comments on the LAA changes soon (a
couple of weeks?). For now I intend to wait until we hear from Chris.
I looked at the complete LAA document and learned their design change
only applies to planes with hinged ailerons. My plane has hingeless
ailerons, so it is doubtful the LAA changes would work well for
me. Also, I got the idea that their changes were based on CZAW
planes which are somewhat different from Zenith kits.
My original reason for calling Sebastian was to see if he had the
weird 20 x 20 mm square tube called out for the mass balance arm. I
couldn't find any on the net and figured he might have some in
stock. He said that when they issued the engineering change for the
mass balance it would use materials readily available here.
I want to implement aileron mass balance and install a fix for the
control system oversensitivity. I understand Chris has developed a
simple change to add some springs to the elevator controls, and I
still don't know how to handle the aileron balance issue.
Paul
XL awaiting engineering changes
At 03:19 PM 9/1/2009, you wrote:
| Quote: | Paul... which LAA suggestions are you going to follow?
What about this 35% reduced to 30% MAC...
I have always seen/used 30% MAC...
Even at 30% MAC, 1320, full aft CG, the airplane is squirrelly...
Has anyone on this list conducted test flights at 35% MAC, 1320,
full aft CG?
How many of the crashes were 35% MAC aircraft?
Am I reading the report correctly, they are removing their
previously required elevator bias spring?
Reducing aileron cable tension to as low as 15 pounds? (20 +/- 5)
Pete54
Posted: Fri Sep 04, 2009 2:34 am Post subject: Re: UK LAA mods - official information |
I can add a little info on the C of G and trimmer issues from the LAA.
Back in February there was talk from them of slowing down the trimmer. The UK aircraft all have to have the large elevator trim tab. This gives a lot of trim authority and was 'necessary' for the initial UK acceptance. CZAW added the flap interconnect and many aircraft (like mine) have both.
There was a flight test programme which extended the c of g range to 530mm from 455. During the recent trials the interaction between the interconnect and larger trim tab showed the potential for the longitudinal stability to be compromised. The quick and dirty solution is to de-power the trimmer by turning the horn around. Apparently removing the interconnect increases the longitudinal stability quite a bit. We'll find out when we get to test fly the aircraft.
We'll have to carry out all the mods to get clearance to fly - that is just the way things are in the UK. Once we are flying there may be some potential for optimisation but after nearly 11 months of being grounded I'm just going to roll with it.
I have flown my aircraft with the c of g at around 500mm, it felt pretty 'relaxed' and needed careful attention to pitch control. The rumour is that the UK aircraft modified so far need a little nose ballast to stay within the c of g limits.
_________________ Pete Morris |
chuck_maggart
Posted: Sat Sep 05, 2009 7:46 am Post subject: Re: UK LAA mods - official information |
Pete, I'm curious about where and how nose ballast is added to a 601XL. My weight and balance indicate that some nose weight might be desirable.
Chuck Maggart
Finished and ready to fly
_________________ Chuck Maggart |
sabrina
Posted: Sat Sep 05, 2009 9:31 am Post subject: Re: UK LAA mods - official information |
Gig Giacona
Posted: Sat Sep 05, 2009 12:20 pm Post subject: Re: UK LAA mods - official information |
Where's your battery now?
601XL Under Construction
Pete54
Posted: Sun Sep 06, 2009 4:59 am Post subject: Re: UK LAA mods - official information |
The easiest choices seem to be the prop adapter or a heavier prop. I'm hopeful it will not be necessary on my aircraft (Warp Drive and prop extension) we'll see!
chuck_maggart
Posted: Sun Sep 06, 2009 10:22 am Post subject: Re: UK LAA mods - official information |
| Sabrina wrote: | | a metal prop moves that CG forward fairly well... |
Is there a metal prop for the Jabiru 3300? I would rather have a metal prop.
Chuck Maggart
chuck_maggart
Posted: Sun Sep 06, 2009 10:23 am Post subject: Re: UK LAA mods - official information |
| Gig Giacona wrote: | | Where's your battery now? |
The battery is mounted on the firewall.
Chuck Maggart
chuck_maggart
Posted: Sun Sep 06, 2009 10:25 am Post subject: Re: UK LAA mods - official information |
Thank you, Pete. I would like to have a metal prop, but don't know of a suitable one that would work on a Jabiru 3300.
Chuck Maggart
| Pete54 wrote: | | The easiest choices seem to be the prop adapter or a heavier prop. I'm hopeful it will not be necessary on my aircraft (Warp Drive and prop extension) we'll see! |
