Posted: Mon Sep 07, 2009 3:57 am Post subject: Trim for level flight |
Folks,
I'm at just under 31 hours in my flight testing and have been getting things set up for hands-off and autopilot flying. I got the hands off part finished and found that I need a little up-trim to mainatain altitude - the left/right part is fine with zeroe'd roll trim and will allow for some fuel difference in the tanks before it tries to roll in any direction. Similarly, when I'm running the autopilot, it'll fly straight and level forever - so I zeroe'd out the elevator trim and turned off the autopilot - and got the expected descent - until I added back the up-trim.
Leads me to think that my Horizontal Stabilizer needs to have its angle of attack lowered a little bit.
My CG is in the forward part of the range but not waay forward. I'm going to try it with the CG a little farther aft and see what happens. The airframe is still 'dirty' as I haven't added leg fairings or covered the mainwheels - the nosewheel is covered per Vans requirements.
It will trim for a climb or descent as desired - but will always descend if I zero out the elevator trim.
What do you folks think?
Meanwhile, what a wonderful machine!
Ralph
N822AR (at) N06 - just under 31 hours
Posted: Mon Sep 07, 2009 4:38 am Post subject: Trim for level flight |
Before you spend the time changing the incidence in the tail, I'd make
sure that it's really out ..... and not a CG thing. Do your test at
varying airspeeds to see if you need to tweak the tail. My Traumahawk
will trim lock to lock from low speed to high .... so I know it's out of
whack.
Linn
Ralph E. Capen wrote:
| Quote: | Folks,
back the up-trim.
Ralph
Posted: Mon Sep 07, 2009 4:53 am Post subject: Trim for level flight |
Good point - I'll try it at different airspeeds and valid CG configurations
before I monkey with it......
khorton01(at)rogers.com Guest
Posted: Mon Sep 07, 2009 7:10 am Post subject: Trim for level flight |
On 2009-09-07, at 7:56 AM, "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
| Quote: | Folks,
I wouldn't worry about this until you have all the fairings on. The aircraft will be faster, and you need to trim more nose down as the speed increases.
Kevin Horton
mcculleyja(at)starpower.n Guest
Posted: Mon Sep 07, 2009 8:12 am Post subject: Trim for level flight |
When you eventually add gear and wheel fairings you will see much less
up-trim needed due to less drag from the current pitch-down drag of
gear. May even reverse the trim needed.
Jim McCulley
| Quote: | Folks,
back the up-trim.
Ralph
