elleryweld(at)AOL.COM Guest
Posted: Tue Sep 08, 2009 4:13 pm Post subject: HELP Radio GPS Noise Question |
In my Mk3CKThe radio & intercom system works great and no static at all until I turn on the GPS then there's steady noise (static) in the headsets that would drive anyone nuts so I have been flying without GPS but I would like to find a remedy for this anyone have any ideas on what I can try to remedy this I have tried using the GPS running on its internal battery's and I get the same results installed remote GPS Antenna and nothing seems to make a difference anyone else ever have this problem? How did you Fix it
Thanks in advance if you can help me solve this problem
Ellery in Maine
lcottrell
Posted: Tue Sep 08, 2009 4:51 pm Post subject: HELP Radio GPS Noise Question |
I had the same problem with my 196 on internal power, but when I take it off it doesn't cause any problems or noise. Not usable with internal power. Boyd suggested that it was the data wires integrated in the cable. I drilled them out of the end that runs into the GPS, but it didn't cure the problem. So I just run it on batteries. Not sure why you are still getting static.
Larry C
herbgh(at)nctc.com Guest
Posted: Tue Sep 08, 2009 5:18 pm Post subject: HELP Radio GPS Noise Question |
The computer and digital circuits in the gps generate a wide band of radio noise.. By law the strength of the radiation is limited.. Separating the two devices as far as is practical might help? Tying both units to a common ground might work? ..otherwise make an aluminum case for as much of the gps as is practical and ground that.. Herb
At 07:41 PM 9/8/2009, you wrote:
[quote]I had the same problem with my 196 on internal power, but when I take it off it doesn't cause any problems or noise. Not usable with internal power. Boyd suggested that it was the data wires integrated in the cable. I drilled them out of the end that runs into the GPS, but it didn't cure the problem. So I just run it on batteries. Not sure why you are still getting static.
Larry C
