albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Fri Sep 18, 2009 8:13 am Post subject: Grandrapids EIS or others. |
For those of you with the grandrapids eis for rotax 2 cycles,
what options do you have?
can the two aux. inputs be used for fuel level?
anyone using the fuel flow option, altimeter?
I have two 45 litre aluminum tanks that only have a clear fuel line to read the level. They are behind the passenger seat and very hard to see. I would like to put a skysport fuel sending unit in each one but before I buy a fuel guage as well I would like to know if the eis can read fuel level. I know alot of people like the standard needle guages but I find them hard to read (accurately). I've decided to replace them with an eis (not sure what one yet). I find that with the guages that I have, I am guessing as to what it is reading because the needle travel is so smalll.I would much prefer a digital number especially for the more critical readings.
Anyone else with a different eis such as a stratomaster please don't hesitate to comment on your unit.
Tony
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
HShack(at)aol.com Guest
Posted: Fri Sep 18, 2009 3:44 pm Post subject: Grandrapids EIS or others. |
Call Grand Rapids Tech. and they will tell you exactly what you need.
They sell the Prince capacitive fuel level sender, which I highly recommend. Yes, ties into Aux. Will also do altitude.
Best customer service>
In a message dated 9/18/2009 12:14:30 P.M. Eastern Daylight Time, cheriebraun(at)xplornet.com writes:
| Quote: | For those of you with the grandrapids eis for rotax 2 cycles,
lcottrell
Posted: Fri Sep 18, 2009 4:23 pm Post subject: Grandrapids EIS or others. |
He is correct, and the Prince fuel sender is a good one, but there is only one aux wire on the two stroke EIS that will work as a fuel sender. I used two senders with my two stroke EIS by getting a double pole, double throw switch and wired the switch so that one direction read the front tank and the other direction read the back tank. I also had the tanks isolated and selected between them with a selector fuel valve, so that when you changed tanks you also changed the switch. It has worked quite well for me for more than 6 years.
Larry C
albertakolbmk3
Posted: Fri Sep 18, 2009 7:29 pm Post subject: Re: Grandrapids EIS or others. |
That's exactly what I want to do... thanks for the info. What length does the sender come in and can it be cut down (I need about 22")... or is it a resistor swing type?
[quote="lcottrell"]He is correct, and the Prince fuel sender is a good one, but there is only one aux wire on the two stroke EIS that will work as a fuel sender. I used two senders with my two stroke EIS by getting a double pole, double throw switch and wired the switch so that one direction read the front tank and the other direction read the back tank. I also had the tanks isolated and selected between them with a selector fuel valve, so that when you changed tanks you also changed the switch. It has worked quite well for me for more than 6 years.
Larry C
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
lcottrell
Posted: Fri Sep 18, 2009 9:17 pm Post subject: Grandrapids EIS or others. |
Your best bet is to call Grand Rapids, you will talk to Sandy who is so knowledgeable that several guys have proposed to her over the phone, including me. She can fix you up with what ever you need. There are several sizes of senders, I used the 12 inch one with my stock tanks.
Larry C
albertakolbmk3
Posted: Sun Sep 20, 2009 6:03 am Post subject: Re: Grandrapids EIS or others. |
Anyone out there with a stratomaster? The grandrapids eis seems to be very popular.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
ulflyer(at)verizon.net Guest
Posted: Sun Sep 20, 2009 3:36 pm Post subject: Grandrapids EIS or others. |
Tony
Here is web site info for the EIS unit - note there are 2 stroke and
4 stroke models as well as 2 and 4 cylinder models.
http://www.grtavionics.com/product.aspx?productno
http://www.grtavionics.com/product.aspx?productno &featureno=8
http://www.grtavionics.com/product.aspx?productno &featureno 6
According to their web site info for the EIS-2002 (2-stroke, 2
cylinder model) it has two user configurable aux inputs, I would take
it these both can be used for fuel level sensors. You need to ask if
they remain available if you elect to have the altimeter/vertical
speed option or fuel flow option. It can be ordered with those
options. I have the fuel flow option on mine, works great. I use it
to cross check fuel remaining and my fuel level.
Check their warranty policy - its says a lot - I have my second unit
and like the first (on another plane) it has been rock solid. I am a
very happy user of their product. My next plane will also have one
of their units..
jerb
At 09:13 AM 9/18/2009, you wrote:
Tony
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p 63699#263699
