Arksey(at)aol.com Guest
Posted: Sat Sep 19, 2009 4:17 pm Post subject: boom tube bolt question? |
Hi group,
I was looking over the boom tube on my firestar ll the other day and got to wondering if a person should remove the large bolt that goes thru the boom tube where it attaches to the rear of the cockpit cage when a person does a annual inspection to see if the bolt is ok. Do you think it is necessary to do that? I have been doing a lot of flying the last couple of weeks, weather is good up here in Michigan...went to fly in last weekend and meeting some people today for lunch today. The firestar is getting a work out, already been over to a breakfast get together for coffee and donuts, cool ride even with a coat this morning at 9 am. thanks in advance....jswan
JIM SWAN
firestar ll, 503, N663S
Eaton Rapids, Mi. 48827
PH 517-663-8488 runway 2300' E & W (42-28.58N 084-44.69 W )
Posted: Sat Sep 19, 2009 4:47 pm Post subject: boom tube bolt question? |
Jim, it would be interesting to do a one time inspection after several hundred hours and report to the list.I doubt that bolt would show anything unless it was loose and spinning around. Better to check what visible rivets
you can see on the tube, cracks around them, etc. The bolt goes in a sleeve built into the H-frame.
The rivets inside the cage are tougher to see. The bolt mount area on the cage is usually covered with enough paint (or fabric) that
visual inspection can't reveal any early problems. Maybe some owners who have done some damage could report
what failed first.
The Kolb's H-frame is designed to taper the load at the boom and on the spars. The Rans aircraft didn't
have this feature and had a few shear failures on their tails.
BB
On 19, Sep 2009, at 7:55 PM, Arksey(at)aol.com (Arksey(at)aol.com) wrote:
[quote] Hi group,
JIM SWAN
| [b]
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Sat Sep 19, 2009 5:48 pm Post subject: Re: boom tube bolt question? |
I removed the main fuse tube bolt after 19 years of flying and found absolutely no wear.
Ralph B
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
