Posted: Thu Sep 17, 2009 9:17 am Post subject: Gas line |
Last spring I installed a new gas line, and while looking the plane over I saw that it had collapsed at a mild radius. The hose below the gas level was all mushy. The line above the gas level is firm. The hose was acquired at a local auto parts store, and is marked as follows: 09 13 08 Z 50PSI Fuel/Emission SAE 30R7 Made in USA Goodyear
I am replacing it with a Gates hose, also marked SAE 30R7. The fuel in the tank has 10% alcohol in it, plus Penzoil 2-stroke oil, plus Stabil. The last time I ran it, it sounded funny at higher throttle settings. I believe it was starved for gas, due to the hose sucking flat. Luckily, it is not ready for flight and was only run in my back yard.
Has anyone else noticed this problem?
Bill Sullivan
Windsor Locks, Ct.
FS 447
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Thu Sep 17, 2009 1:35 pm Post subject: Re: Gas line |
17sep09
Bill S.,
I’m no help on the black fuel line, but recently I’ve experienced a failure with the blue urethane...
Nearly two years ago I had to park my FireFly and temporally relocate from Maui to Oahu. (No, I wasn't in jail this time...) Shortly before parking the plane I had replaced the fuel lines with the blue urethane line. The catalog said... "Absolutely will not harden, crack, or become brittle with age." After my last flight I did a somewhat incomplete job of draining the fuel.
Two weeks ago I got back to the plane and started to get her back to air worthiness.
In places where the fuel line was protected from the sun everything appeared to be OK. In unprotected areas, the blue had completely faded from the side of the line that faced the sun. In low places where fuel residue had gathered, the line was shot full of hairline cracks. (None appeared to be leaking...)
Inside the fuel tank I had used a two-inch piece of the blue urethane to connect the in-tank filter to the fuel pick-up tube. This piece of fuel line had completely come apart. It was in a dozen little blue pieces on the bottom of the tank. The little pieces would turn into a gritty blue jelly when given a squeeze.
I have elected to replace the blue line with the yellow tygothane... I note that the catalog says it will... "Absolutely will not harden, crack, or become brittle with age." And it cost more than the blue, so it's gotta be better... It is softer than the blue and has a "snakey" feel. I like it already.
Twice, I have seen unidentified bits of detris being sucked up towards the impulse pump in time to shut the engine down. This is why I have not migrated to the black fuel line.
You can bet that when the yellow line hardens, cracks, or becomes brittle with age, I'll be back to whine about it.
Almost forgot... Our fuel is 10% alcohol... Surprise, Surprise!!!
Aloha
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
Posted: Thu Sep 17, 2009 2:13 pm Post subject: Gas line |
Henry- My black neoprene line was exposed to sun while sitting in the yard. I don't think it was affected by it, but you never know. I was going to use the yellow Tygothane, but I was concerned that it would collapse under suction. I still wonder if it's the alcohol. If alcohol makes me soft and mushy, maybe it does the same to neoprene.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Dana
Posted: Thu Sep 17, 2009 2:37 pm Post subject: Gas line |
At 06:09 PM 9/17/2009, william sullivan wrote:
| Quote: | Henry- My black neoprene line was exposed to sun while sitting in the
I have used the yellow Tygon on my PPG's, but the blue line is harder, less
susceptible to collapse, and lasts longer. You still need to replace it
every couple of years. I think it's the sunlight (UV) that does most of
the damage.
The yellow Tygon, which they market as "fuel and lubricant tubing", is a
vinyl product. Tygothane is something different, a polyurethane product,
and according to Tygon is NOT suitable for fuel.
There are other yellow "fuel" tubings out there... stay away, they're
cheaper than genuine Tygon and don't last nearly as long.
I know others prefer the black neoprene but I still like to see what's
inside (or not inside) my fuel lines.
-Dana
The gene pool could use a little chlorine.
frank.goodnight(at)att.ne Guest
Posted: Fri Sep 18, 2009 5:51 am Post subject: Gas line |
when I built my firestar I used a pice of the leftover aluminum
tubeing for most of my fuel line
and only used a short piece of the plastic that kolb provided to make
the conection at the
very ends. I don"t know if that was a good idea or not. At my yearly
condition insp. I changed
to black fuel line for marine use it is supposed to be alcohol
resistant. Next time I am thinking
about going to copper air conditioning tube, I also don"t if that is a
good idea.
Frank Goodnight
Firestar 2
Brownsville , Tex
On Sep 17, 2009, at 5:24 PM, Dana Hague wrote:
> same to neoprene.
harder, less susceptible to collapse, and lasts longer. You still
need to replace it every couple of years. I think it's the sunlight
(UV) that does most of the damage.
is a vinyl product. Tygothane is something different, a
polyurethane product, and according to Tygon is NOT suitable for fuel.
they're cheaper than genuine Tygon and don't last nearly as long.
what's inside (or not inside) my fuel lines.
-Dana
Posted: Fri Sep 18, 2009 7:19 am Post subject: Gas line |
Frank,
I believe aluminum will withstand vibration better than copper. And for the
same size is lighter.
Jack B. Hart FF004
Winchester, IN
At 08:35 AM 9/18/09 -0500, you wrote:
good idea.
Frank Goodnight
Firestar 2
Brownsville , Tex
Thom Riddle
Posted: Fri Sep 18, 2009 8:15 am Post subject: Re: Gas line |
The Tygon tubing product intended for fuel lines is Tygon F4040A. It is yellow and traslucent but so are some other Tygon tubing types. The F4040A has been tested satisfactorily for use with E-10 auto fuel according to the factory tech rep I spoke to about it.
It is very flexible and resistant to cracking down to -35F but on the hot end it is not good above about 160F or so. It should handle suction for Kolbs from tank to fuel engine mounted fuel pump but NOT for pulse lines on 2-strokes. I've installed in on two airplanes with no apparent problems under the conditions I mentioned.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
ulflyer(at)verizon.net Guest
Posted: Sun Sep 20, 2009 10:18 am Post subject: Gas line |
There is blue tubing and then there is the tubing
produced by Bing - available from Aircraft
Spruce. Get the Bing stuff, cost more but is
less affected by fuel and oil we use. Note if it
is the actual Bing stuff it will have Bing
printed on it every foot or so. The plain blue
stuff hardens, often turns green over time and
becomes brittle where it can easily break and
does. Don't use it, use the Bing product.
jerb
At 02:36 PM 9/17/2009, you wrote:
17sep09
Bill S.,
Aloha
Henry
http://forums.matronics.com/viewtopic.php?p 63584#263584
Posted: Sun Sep 20, 2009 10:23 am Post subject: Gas line |
I've used the Tygon tubing in the past, it took a little longer than
the plain blue (non-Bing product) but it hardened over time also. I
have totally gone over to the blue Bing tuning for my fuel and primer
lines and am very pleased with it. The Bing is sold by Aircraft Spruce.
jerb
At 03:24 PM 9/17/2009, you wrote:
-Dana
Posted: Sun Sep 20, 2009 10:44 am Post subject: Gas line |
You know replacing the flex tubing with aluminum tubing for most of
the run might not be a bad idea. When Kolb shipped my kit they sent
the wrong wall thickness tube, They said it would cost more to return
it than it was worth so told me to keep it and reshipped the correct
material. That tubing might work just fine. Got to think about this
and look things over.
jerb
At 06:35 AM 9/18/2009, you wrote:
good idea.
Frank Goodnight
Firestar 2
Brownsville , Tex
>>same to neoprene.
>-Dana
