rv9jim(at)juno.com Guest
Posted: Wed Sep 23, 2009 3:51 am Post subject: : IO-320 Fuel System Diagram?? |
Mike,
I have the IO360 and I wouldn't trade my fuel sysytem from AFP
for a system that does not have the "purge " valve. It lets you have
cool fuel on hot restarts and when shutting down, it "stops" the fuel
from letting the engine "run" on for a bit. I put my return line back to
the fuel line that comes from the right tank between the gear leg and the
fuel selector valve. this lets you pump the hot fuel back to the right
tank wile puttling cool fuel from my left tank. Works great.
Jim
Best Weight Loss Program - Click Here!
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTFoYczwqK6xkYeYq9T0r1ZusWUakOPPTVQF3tZ3kOEVETRUbMON7S/
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Wed Sep 23, 2009 4:41 am Post subject: : IO-320 Fuel System Diagram?? |
Well, I have been operating an IO-360-A1A in a Mooney for over 10 years
with no need for purge valve complexity, no issue for hot starts, no
issue for shutdown. If an engine tries to run on there is something
wrong with it. KISS. No need to add parts to solve non-problems.
James H Nelson wrote:
Quote: |
Mike,
Jim
KCHD |
DwightFrye
Posted: Wed Sep 23, 2009 11:17 am Post subject: : IO-320 Fuel System Diagram?? |
As a note ... Airflow Performance is in the process of making a new
version of their system available which does not require a purge
valve and/or return line. I believe it is bolt-compatible with the
Precision as well, but Don Rivera (Airflow owner, and FI guru) is who
you should talk to for details.
Like Jim I did not run the purge line all the way back to the tanks,
but just back to the feed line from the right tank. It is simple and
has proven to be effective.
As for me, I _like_ the functionality that the purge valve provides in
the system and have found the additional plumbing to be trivial. But
for those who really don't want the purge valve and line ... Don now
will have an option for you to run with.
-- Dwight
FYI: I am not affiliated with Airflow in any way except as someone who
has received absolutely superb customer service.
On Wed Sep 23 07:49:29 2009, James H Nelson wrote :
Quote: |
Mike,
Jim
