sarg314(at)gmail.com Guest
Posted: Mon Oct 05, 2009 1:17 pm Post subject: high temp. tie wraps. |
I understand that there are high temperature tolerant tie wraps that can be used under the cowling. Can some one tell me where to get these things?
Tom Sargent, RV-6A, final assembly
Jim Berry
Posted: Mon Oct 05, 2009 2:31 pm Post subject: Re: high temp. tie wraps. |
Look at steinair.com.
Jim Berry
RV10
N15JB
Posted: Mon Oct 05, 2009 3:14 pm Post subject: high temp. tie wraps. |
They are Tefzel tie wraps. About $2 each.
Consider Dacron string ties. Works good, lasts
a long time and is really cheap.
( -Thomas Paine 1776- )
rgf(at)dcn.org Guest
Posted: Mon Oct 05, 2009 3:51 pm Post subject: high temp. tie wraps. |
http://www.terminaltown.com/Pages/Page206.html is one source.
Ralph Finch
Davis, California
RV-9A QB-SA
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Monday, October 05, 2009 2:16 PM
Subject: high temp. tie wraps.
JimT
Posted: Mon Oct 05, 2009 4:44 pm Post subject: high temp. tie wraps. |
thomas sargent wrote:
Quote: | I understand that there are high temperature tolerant tie wraps that
these things?
Unless you're putting them where they are exposed to the radiant heat of
the exhaust pipes, just about any UV resistant ones will work ok (at
least in my experience).
Charlie
lerohl(at)gctel.net Guest
bakerocb
Posted: Tue Oct 06, 2009 4:10 am Post subject: high temp. tie wraps. |
10/6/2009
Hello Tom, Note that the PEEK ty wraps are rated to + 500 degrees F and the
Tefzel ty wraps are rated to + 302 deg F.
Also note how horrendously expensive the PEEK tys are compared to the Tefzel
tys.
http://www.mcmaster.com/#harsh-environment-wire-ties/=3xvkp5
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 02:17:53 PM PST US
lists(at)stevet.net Guest
Posted: Tue Oct 06, 2009 5:26 am Post subject: high temp. tie wraps. |
Stein Air is another good source:
http://www.steinair.com/cableties.htm
Steve Thomas
________________________________________________________________________
On Oct 5, 2009, at 2:15 PM, thomas sargent wrote:
[quote]I understand that there are high temperature tolerant tie wraps that can be used under the cowling. Can some one tell me where to get these things?
steve(at)tomasara.com Guest
Posted: Tue Oct 06, 2009 5:45 am Post subject: high temp. tie wraps. |
If you don't mind sticking to the lower strength 4" ones (which I've
found to be sufficient for most things, though I sometimes double them
in length) you can get Tefzel ties from http://www.cabletiesandmore.com/
for 15 cents each in packages of 100.
Steve Stearns
Boulder/Longmont, Colorado
CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less)
Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
