napierm(at)cisco.com Guest
Posted: Mon Oct 12, 2009 10:14 am Post subject: KF IV questions |
Hello,
I've recently picked up a 2002 classic IV fuselage and have a couple of
idiot questions.
1st: I notice the mounting tabs for the cowling and turtle-deck are much
smaller than the ones on my KF III and the 1/4 turn fasters that I have
won't fit. What hardware is used here? I intend to essentially scratch
make the finishing kit.
2nd: I see a few small horizontal tabs on each side on the upper tube
just aft of the wing in the turtle-deck area. What are these used for?
Thank you much,
Mark Napier
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Oct 13, 2009 12:03 pm Post subject: Re: KF IV questions |
| Quote: | 1st: I notice the mounting tabs for the cowling and turtle-deck are much
make the finishing kit. |
Mark,
These fasteners are Duez studs.
Winged 2600-3W on the turtle deck. 2600-8W flaperon horn bearing. 2600-4W top cowls.
Phillips head 26S8-3 for the bottom rear cowl and 26S8-4 bottom front cowel.
Receptacles are all 212-12N.
Lock washers are all 2600-LW
| Quote: | 2nd: I see a few small horizontal tabs on each side on the upper tube
These tabs are where you mount a short piece of piano hinge to attach the lower half of the flaperon horn bearing material.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Wed Oct 14, 2009 7:50 am Post subject: KF IV questions |
Hey Tom,
Thanks for the reply.
I do see the purpose of the large horizontal tab in between the two
vertical mounting tabs for the turtle deck. But there are also three
more small horizontal tabs forward of that position that are on the
upper tube that angles down behind the rear wing mount. They look like
you could mount a shelf or something there but that would block the view
through the turtle deck. They're also look too low to be part of the
turtle deck mounting unless an angle or something is mounted there.
Thanks again,
Mark Napier
Time: 01:05:54 PM PST US
Subject: Re: KF IV questions
much
| Quote: | smaller than the ones on my KF III and the 1/4 turn fasters that I
have
| Quote: | won't fit. What hardware is used here? I intend to essentially scratch
Mark,
2600-4W top
cowls.
cowel.
the lower
Tom Jones
Classic IV
Ellensburg, WA
Tom Jones
Posted: Thu Oct 15, 2009 5:36 am Post subject: Re: KF IV questions |
| Quote: | I do see the purpose of the large horizontal tab in between the two
upper tube that angles down behind the rear wing mount. |
Mark,
I looked at the pictures in my builder's log and see the tabs you are asking about. There is nothing attached to them in my pictures. I can't find any mention about them in the assembly manual either. I'll take a look next time I'm at the airport to make sure. I'll let you know if I did use those tabs to mount anything I've forgotten about.
Classic IV
Ellensburg, WA |
kirkhull(at)kc.rr.com Guest
Posted: Fri Oct 16, 2009 5:57 am Post subject: KF IV questions |
I believe the 3 tabs are for floats but don't quote me on that. Two of them
hold the radiator on mine
Lynn Matteson
Posted: Fri Oct 16, 2009 7:45 am Post subject: KF IV questions |
Sounds like the shoulder belt mounting tabs, to me.
Lynn Matteson
Jabiru 2200, #2062, 796.4 hrs
Countdown to 1000 hrs~204 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
Two of them
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Posted: Fri Oct 16, 2009 6:19 pm Post subject: Re: KF IV questions |
I looked at my Classic 4 yesterday. The only thing I used the small horizontal tabs on the upper fuselage tubes directly behind the wing rear spar lugs for is to attach the pitot static line and antenna lead to them on the left side of the fuselage.
My kit came with the panel tank so the wing tank fuel lines run forward.
I have developed a theory that the purpose of the tabs in question is to attach fuel lines from wing tanks to a rear mounted header tank. They would work for that I think. Any body with a rear mounted header tank in a model 4 use them for that purpose?
Classic IV
Ellensburg, WA |
clint_bazzill(at)hotmail. Guest
Posted: Fri Oct 16, 2009 8:14 pm Post subject: KF IV questions |
Yes C works great. Pix if you want.
Clint
| Quote: | Subject: Re: KF IV questions
Date: Fri C 16 Oct 2009 19:19:16 -0700
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
I looked at my Classic 4 yesterday. The only thing I used the tabs in question for is to attach the pitot static line and antenna lead to them on the left side of the fuselage.
I have developed a theory that they are to attach fuel lines from wing tanks to a rear mounted header tank. They would work for that I think. Any body use them for that purpose?
Tom Jones
Classic IV
503 Rotax C 72 inch Two blade Warp
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=268296#268296
&g==================
lcfitt(at)sbcglobal.net Guest
Posted: Mon Oct 19, 2009 10:45 am Post subject: KF IV questions |
Mark,
I don't know what the original reason for those tabs being placed there, but
I used them to secure the fuel line as it came from the wing tank to the
header tank. I drilled a hole, looped a nylon tie wrap down through the
hole with a cotter pin through the loop and then around the fuel line.
Other wise, no clue.
Lowell
