brubakermal(at)yahoo.com Guest
Posted: Sat Oct 17, 2009 4:51 pm Post subject: jetting a 582 and a choped elbow |
Nothing new, it has been this rich all along but lattley I wory about carbin. Probbly the egt is not acuret what realy bugs me about the idle jet is it is not marked ? How do you know if it is right from leaf when you order one? and it is the most costly one. I flew for .6 hr today mostly at 1275 egt and 50 oat the plugs still looked rich that was at 5500 rpm slower would make the temps come down to 1200 at 5100rpm do you need to move the egt hole when you chop the muffler? should I order a new egt gage and jets? mal mod 2 582 w pre mix
--- On Sat, 10/17/09, dave <dave(at)cfisher.com> wrote:
Subject: Re: jetting a 582 and a choped elbow
Date: Saturday, October 17, 2009, 11:06 AM
--> Kitfox-List message posted by: "dave" <[url=/mc/compose?to=dave(at)cfisher.com]dave(at)cfisher.com[/url]>
The elbow and Y pipe have been shorted about 2.5 " approx. That is a huge difference and I have proven it many times over.
Regardless, your problem is odd -- black plugs and EGT 1275f ?
something askew here. What have you done to make this happen lately? I have seen some adjust needles and put the needle on top off plastic clip and get a similar problem.
MAke sure your oil injection marks line up at IDLE ......... and the lever travels smoothly through out the throttle movement.
Dave
[quote="brubakermal(at)yahoo.com"]5 plus HP sounds like allot to loose becous of such a little adjustment to the elbow. That should effect gas consumption or change the power band or the echo back prechur and in turn accurate EGT readings. Mystatic rpm is 5800 and at climb out I get6200 at 55 mph and 6600 max rpm flat and level yet my egt,s are 1275 and the plugs are still very black and wet w/ penz oil 50 to one pre mix
To: [url=/mc/compose?to=kitfox-list(at)matronics.com]kitfox-list(at)matronics.com[/url]
Date: Wednesday, October 14, 2009, 5:17 PM
--> Kitfox-List message posted by: "akflyer"
and make sure the oil pump line up marks are correct. I leaned mine out just a tad and got better plug color and performance. I do the same on all my snowmachines as well. I measure the gas put in the tank, and the oil put in, then figure the ratio and get it to match as close to 50:1 as possible. I know the pump actually gives closer to 100:1 at idle, but 99% of the time the engine is running in the 50:1 range so I set the adjustment accordingly.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p=267934#267========================http://www.matronics.com/Nav= - MATRONICS cs.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution (http://forums.matronics.com/viewtopic.php?p=267934#267934)
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=268313#268========================http://www.matronics.com/Nav= - MATRONICS cs.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution
akflyer
Posted: Sun Oct 18, 2009 2:22 pm Post subject: Re: jetting a 582 and a choped elbow |
No you dont need to move the EGT probe when the elbow was chopped. The EGT probe gets installed at X distance from the face of the piston.
If the plugs are black, and the EGTS are high then I would think of the pitch on the prop. What is the MAX RPM you can turn on the ground and in the air?
_________________ DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Sun Oct 18, 2009 5:33 pm Post subject: jetting a 582 and a choped elbow |
I may have overlooked it, but has anyone confirmed how these "black
plug readings" were obtained? Was it after a lengthy taxi back to the
hangar...if so, shame on the mechanic.
Lynn Matteson
Jabiru 2200, #2062, 800.0 hrs
Countdown to 1000 hrs--200 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
On Oct 18, 2009, at 6:22 PM, akflyer wrote:
piston.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p 68448#268448
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sun Oct 18, 2009 8:36 pm Post subject: jetting a 582 and a choped elbow |
To answer you both the max rpm is 5850 static and 6300 climbing and 6600 now in colder air flying flat and level. there is lots of carbine built up in the manifold and jug just 3/8 of an inch from the piston all the way out and not so much a long taxi back to the hanger but carbon built up allot on the plugs after 31 hrs on my last set and just as black after only6 hrs and one needle adjustment since my last plug change malcolm
--- On Sun, 10/18/09, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Subject: Re: Re: jetting a 582 and a choped elbow
Date: Sunday, October 18, 2009, 11:49 PM
--> Kitfox-List message posted by: Lynn Matteson <[url=/mc/compose?to=lynnmatt(at)jps.net]lynnmatt(at)jps.net[/url]>
I may have overlooked it, but has anyone confirmed how these "black plug readings" were obtained? Was it after a lengthy taxi back to the hangar...if so, shame on the mechanic.
Lynn Matteson
Status: flying
dave
Posted: Mon Oct 19, 2009 1:47 am Post subject: Re: jetting a 582 and a choped elbow |
5800 static is a bit low. This will contribute to the darker plugs BUT how can you have EGT 1250 and black plugs? Either EGT is messed up but on both cylinder that unlikely . Check your needles first and verify what notch the clips are on and that you have the O rings on them. And also that the white plastic space it on TOP of the needle and clip.
I would set your static for 6000 to 6300 rpm to start with. What prop do you have ?
What plugs are you running ? Should be BR8ES and Solid tipped NOT alum tipped. and Gapped at .018 . IF you buy from Rotax they are pre gapped at 018 and should last a 582 with oil injection 100 to 150 hours.
http://www.cfisher.com/152hournkg.html
http://www.cfisher.com/ngk/
Notice alum tip here worn flat ......http://www.cfisher.com/ngk/ngk.htm
Your 582 will likely need to have needles set for winter soon . Bottom notch on needles should be good if you have stock jetting.
I would not worry about a muffler mod unless you understand pipe tuning well. Skystars cut the Y pipe and Elbow to fit inside the cowl. You will have to mod the cowl if you lengthen the header part of the exhaust. ( header is the first part from ports to the start of the cone. You need to add 1.5 to 2.5 inches but it will be challenging for you .
Take some pics of this carbon build up and send it or post it .
| Quote: | | To answer you both the max rpm is 5850 static and 6300 climbing and 6600 now in colder air flying flat and level. there is lots of carbine built up in the manifold and jug just 3/8 of an inch from the piston all the way out and not so much a long taxi back to the hanger but carbon built up allot on the plugs after 31 hrs on my last set and just as black after only6 hrs and one needle adjustment since my last plug change malcolm |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Mon Oct 19, 2009 4:10 am Post subject: jetting a 582 and a choped elbow |
Malcolm, even though there are different opinions out there, your numbers aren't far enough off to explain the carbon buildup. One of the big problems of the 582s is that they were supplied with idle jets that were way to rich. On them you will find a number. Look very closely with a magnifying glass then talk to Lockwood, or one of the suppliers about getting a couple numbers leaner. They're a little bit pricey, but will smooth out your idle considerably. Then again, now that cold weather with denser air has arrived it may get better all by itself. Also, you might also suspect your EGT gauge is reading a bit high. Maybe you can borrow a spare to double check it.
Also, as I recall, Barstow does have a fairly long taxi back which would also contribute.
One little trick is to take some tools with you, fly to a seldom used grass strip somewhere and when you have the runway made, shut the engine off on short final, stop and make a plug reading without any taxiing. See if you still have black plugs. Ensure you fly long enough to burn off the soot that is already on them. Better yet, start off with clean plugs.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
akflyer
Posted: Mon Oct 19, 2009 4:58 am Post subject: Re: jetting a 582 and a choped elbow |
The best plug reading you can get is to warm the plane up on the old plugs, shut down, put in new plugs, start up, firewall it and climb to altitude WOT then shut the mags off and glide in. This will give you the truest plug reading you can get.
An alternative would be to tie the plane down and put in new plugs, firewall it for a minute or two then shut down and read the plugs.
One issue with premix.. you are always at 50:1. With a pump, you are closer to 100:1 at idle. The oil you are burning plays a HUGE part in the carbon build up. Some oils burn much much cleaner than others.
I would lean towards faulty EGT readings. If you only turn 5800 static, and maybe 6300 in the air, you are loading the engine too much and your EGT's should be closer to 950 - 1000 at that loading. I am thinking you are running way fat and shooting way too much unburned (or still burning) fuel out the exhaust giving elevated EGT's. This was a demon we chased on my brothers KF when we swapped to the "winter" jets. EGTs went way up and it was damn near impossible to keep them under 1200 even with the IFA prop and loading the engine way down. I think he called CPS and talk to Mike who explained the high EGT if your way to rich thing to him. Dropped back down from 175 to 170 mains and the issue went away.
I run 165 in the summer and 170 in the winter, no matter how cold it gets and the plugs and EGT's stay perfect.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Fox5flyer Guest
Posted: Mon Oct 19, 2009 5:59 am Post subject: jetting a 582 and a choped elbow |
Agreed. The plug reading is the final proof of engine performance. When I
raced desert bikes (previous life) we would run them hard for about 10-20
minutes, then make an immediate shut down to make a plug check. Most
accurate for actual conditions. I suggested this several years ago to the
list and got some flack about the dangers of doing it, blah blah, etc. and I
don't think it was taken seriously by most. However, I still see no great
risk why one couldn't practice a real world engine out by shutting down on
downwind with a good long runway, have your tools ready, pull over off to
the side and do a quick check. Of course, it's best to announce intentions,
wear goggles, hearing protection, inform fire department...
Deke Morisse
Mikado Michigan
thesupe(at)hotmail.com Guest
Posted: Mon Oct 19, 2009 6:25 am Post subject: jetting a 582 and a choped elbow |
When I bought my first Avid B C it had a 532. Guy that had it had never flown it and didn't really know anything about the plane. They had the redline on the EGT at 1300 or 1350 and I thought that was odd C but figured I would sort that out later. After I started to fly the plane (after new seals in the engine ect) EGT temps were always wanting to go over 1250 in cruise or climb. I did everything I could think of to lower them C even changed the 532 to a just gone through 582 C larger jets C more pitch in the prop C sent 2 different EGT gauges to Westak to be recalabrated C different probes C and the temps still were high C and the plugs were BLACK. There was no question that I was running to rich C but the EGT temps said otherwise. Eventually I bought the Avid MK IV C it had a a 582 in it also C no problems with keeping temps in line with standard jetting. Later I changed the 582 to a Jabiru engine. Got to thinking about things and so I put the muffler from the MK IV on to the B C immediatly the EGT temps showed lower on the gauge and from then on I could fly with standard jetting and EGT temps showed what they should be (1050-1150). I used the same Y pipe in both instances so the probe location didn't change C and there was nothing I could see different in the two different mufflers. No damage visable or other than factory welding on the first muffler. No doubt in my mind that the muffler was causing a higher reading of the EGTs. I know that doesn't make sence C and this is the second time I wrote the message C the first time I deleted it without sending C because it doesn't really make sence to have a higher than actual temp reading C but I saw it for myself. At that time I had flown about 200 hrs with 2 stroke engines and did all the maintainence on them myself C so I wasn't a complete newbee at it either. Take care C Jim Chuk Avids C Kitfox 4 Mn.
| Quote: | Subject: Re: jetting a 582 and a choped elbow
Date: Mon C 19 Oct 2009 02:47:37 -0700
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Rotax Dealer C Ontario Canada
http://forums.matronics.com/viewtopic.php?p=268493#268493
&g==================
Hotmail: Trusted email with powerfu01/' target='_new'>Sign up now.
Lynn Matteson
Posted: Mon Oct 19, 2009 10:11 am Post subject: jetting a 582 and a choped elbow |
I've been keeping this little incident a secret up until now, but
can't keep my mouth shut any longer. While this doesn't come under
the heading of practice, it was a real world situation.
I needed 2 hours of flight a couple of weeks ago, so I could change
my oil at my chosen time of 25 hours. I checked the fuel....8 gallons
exactly...enough for a conservative 2 hour flight at my recent
3.0--3.8 gph. I took off and headed north, thinking of doing a half-
hour in each of four directions, and being near home when the 2 hours
were up. It was great flying weather, and it was mostly hands off
flying. I kept checking my Northstar fuel flow gauge for remaining
fuel and also checking the sight gauges in the wings...plenty of fuel
according to the sight gauges, and adequate, according to the
Northstar gauge. Getting near the end of my time allotment, I saw
B25, an airport just into Indiana from the Michigan state line. I
was curious about this airport, so I circled the field a couple of
times trying to see if there was a building large enough for a B-25
plane, or if one was sitting outside. Seeing nothing along those
lines, I figured I'd better head for home, and turned toward the
northeast. I had flown in this direction for about 3 minutes, still
looking outside and taking in the sights, when I caught sight of my
low fuel warning light which was brightly lit. My clear vent line up
to the right-hand fuel tank was empty, so I knew I was in deep do-do.
I hit the NRST button on my GPS and saw Williams County (0G6) as the
closest airport. This airport is just east of Bryan, Ohio, and 13
miles away from my (then) present location. The engine was still
running, and I was at about 4,000 feet MSL. I pointed it in that
direction, and hoped for the best, all the while looking for a place
to land. I had covered about 7 miles when the engine stopped. I had
tried to position the plane to allow the fuel to get to the port, but
also hoping to make the airport, which meant "quit screwing around
with the fuel and streamline the plane for best glide". Now I
*really* started to look for fields. I could tell that I didn't want
to try to stretch the glide, because this would put
me...possibly...right over Bryan, Ohio, and that was not appealing at
all. I'd covered maybe another mile when I saw a long green stretch
of land between all the brown fields of beans growing in the area. I
said to my self that this was gonna become an airport in the next few
minutes, and started to slip down toward it. The wind was from about
220° and this strip of green was running 9-27. I was north of it, and
I didn't want to try landing into the wind because that would have
eaten up too much altitude. So here I was slipping it down to the
west end of this "soon-to-become airport" at a pretty good clip, and
finally had to straighten it out and put it down. When it finally
touched down, I was going pretty damn fast, and got all over the
brakes and it pulled to the right and headed for the beans. I got
that straightened out and kept braking hard, with the nose of the
plane getting too damn close to the ground...I'd never had the tail
that high before on the ground, and I was pretty sure that I'd have
to turn it into the beans to arrest the speed if I got much closer to
the road which was coming up fast. Man, stuff was going by fast and
the road was getting bigger, when it finally slowed enough to drop
the tail. When I got out and looked around, I saw a plywood sign in
the shape of an airplane, a wind sock, and a long building that
looked like a series of hangars. I had landed at an real-life
airport, complete with porta-potty and way too-long (thank God )
grass. (I later found out that this is called "Al's Place", by the
locals) There was nobody at this airport, but I made a call and a
nice man from 0G6 came out with fuel....he knew exactly where I had
landed. I'll quit the story there because that was the important
part...the landing and getting the fuel so I could continue home.
All this is to point out that what Deke mentioned is true....it is
( in my opinion) excellent practice to do what he said, although try
to do it when you already have the airport in sight, and try to do it
into a headwind, not with a tailwind like I was forced to do. I also
didn't have my goggles nor any hearing protection, which would have
been nice to block out the screams coming from the cabin.
By the way, what got me messed up was relying on the sight gauges
more than the Northstar gauge. The fuel splashes up into those sight
gauges, giving a false sense of more fuel than is actually there. And
I had set the "GAS" reading on the Northstar to read 24 gallons when
I had filled it the last time, not taking into account the unusable
fuel. When I was circling over B25, I had the right wing up, and this
was forcing the right tank to empty, and the left tank to unport.
When I leveled off and headed for home, the right tank was empty, and
the left tank was taking its own sweet time to re-supply the header
tank with fuel, if indeed it had any to offer.
I've since then only entered 20 gallons into the Northstar under
"GAS" after a fill-up, and only trust the sight gauges when the plane
is rock steady.
Lynn Matteson
Status: flying (and learning)
On Oct 19, 2009, at 9:56 AM, fox5flyer wrote:
| Quote: | However, I still see no great risk why one couldn't practice a real
world engine out by shutting down on downwind with a good long
runway, have your tools ready, pull over off to the side and do a
quick check. Of course, it's best to announce intentions, wear
Deke
N369LM |
Pat Reilly
Posted: Mon Oct 19, 2009 4:16 pm Post subject: jetting a 582 and a choped elbow |
Lynn, Thanks for the insite. I have made a habit in the C150 I am taking
lessons in to make a point of, not having "enough " gas for the mission,
but, having enough gas to return with a minimum of 10 gallons still on
board. That was after another club member alerted that I had left the plane
with only 2 gals of gas in it. It has 3 galllons unuseable fuel!
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Oct 19, 2009 at 1:02 PM, Lynn Matteson <lynnmatt(at)jps.net> wrote:
I've been keeping this little incident a secret up until now, but can't
keep my mouth shut any longer. While this doesn't come under the heading of
I needed 2 hours of flight a couple of weeks ago, so I could change my oil
exactly...enough for a conservative 2 hour flight at my recent 3.0--3.8 gph.
I took off and headed north, thinking of doing a half-hour in each of four
directions, and being near home when the 2 hours were up. It was great
flying weather, and it was mostly hands off flying. I kept checking my
Northstar fuel flow gauge for remaining fuel and also checking the sight
gauges in the wings...plenty of fuel according to the sight gauges, and
adequate, according to the Northstar gauge. Getting near the end of my time
allotment, I saw B25, an airport just into Indiana from the Michigan state
line. I was curious about this airport, so I circled the field a couple of
times trying to see if there was a building large enough for a B-25 plane,
or if one was sitting outside. Seeing nothing along those lines, I figured
I'd better head for home, and turned toward the northeast. I had flown in
this direction for about 3 minutes, still looking outside and taking in the
sights, when I caught sight of my low fuel warning light which was brightly
lit. My clear vent line up to the right-hand fuel tank was empty, so I knew
I was in deep do-do. I hit the NRST button on my GPS and saw Williams County
(0G6) as the closest airport. This airport is just east of Bryan, Ohio, and
13 miles away from my (then) present location. The engine was still running,
and I was at about 4,000 feet MSL. I pointed it in that direction, and hoped
for the best, all the while looking for a place to land. I had covered about
7 miles when the engine stopped. I had tried to position the plane to allow
the fuel to get to the port, but also hoping to make the airport, which
meant "quit screwing around with the fuel and streamline the plane for best
glide". Now I *really* started to look for fields. I could tell that I
didn't want to try to stretch the glide, because this would put
me...possibly...right over Bryan, Ohio, and that was not appealing at all
msm_9949(at)yahoo.com Guest
Posted: Mon Oct 19, 2009 5:13 pm Post subject: jetting a 582 and a choped elbow |
A valuable cautionary tale Lynn. Thanks. Why did you hesitate to tell it until now? Afterall, it wasn't "off-airport" even if that was your intent.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Mon, 10/19/09, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Date: Monday, October 19, 2009, 2:02 PM
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I've been keeping this little incident a secret up until now, but can't keep my mouth shut any longer. While this doesn't come under the heading of practice, it was a real world situation.
I needed 2 hours of flight a couple of weeks ago, so I could change my oil at my chosen time of 25 hours. I checked the fuel....8 gallons exactly...enough for a conservative 2 hour flight at my recent 3.0--3.8 gph. I took off and headed north, thinking of doing a half-hour in each of four directions, and being near home when the 2 hours were up. It was great flying weather, and it was mostly hands off flying. I kept checking my Northstar fuel flow gauge for remaining fuel and also checking the sight gauges in the wings...plenty of fuel according to the sight gauges, and adequate, according to the Northstar gauge. Getting near the end of my time allotment, I saw B25, an airport just into Indiana from the Michigan state line. I was curious about this airport, so I circled the field a couple of times trying to see if there was a building large enough for a B-25 plane, or if one was sitting outside. Seeing nothing along those lines, I figured I'd better head for home, and turned toward the northeast. I had flown in this direction for about 3 minutes, still looking outside and taking in the sights, when I caught sight of my low fuel warning light which was brightly lit. My clear vent line up to the right-hand fuel tank was empty, so I knew I was in deep do-do. I hit the NRST button on my GPS and saw Williams County (0G6) as the closest airport. This airport is just east of Bryan, Ohio, and 13 miles away from my (then) present location. The engine was still running, and I was at about 4,000 feet MSL. I pointed it in that direction, and hoped for the best, all the while looking for a place to land. I had covered about 7 miles when the engine stopped. I had tried to position the plane to allow the fuel to get to the port, but also hoping to make the airport, which meant "quit screwing around with the fuel and streamline the plane for best glide". Now I *really* started to look for fields. I could tell that I didn't want to try to stretch the glide, because this would put me...possibly...right over Bryan, Ohio, and that was not appealing at all. I'd covered maybe another mile when I saw a long green stretch of land between all the brown fields of beans growing in the area. I said to my self that this was gonna become an airport in the next few minutes, and started to slip down toward it. The wind was from about 220° and this strip of green was running 9-27. I was north of it, and I didn't want to try landing into the wind because that would have eaten up too much altitude. So here I was slipping it down to the west end of this "soon-to-become airport" at a pretty good clip, and finally had to straighten it out and put it down. When it finally touched down, I was going pretty damn fast, and got all over the brakes and it pulled to the right and headed for the beans. I got that straightened out and kept braking hard, with the nose of the plane getting too damn close to the ground...I'd never had the tail that high before on the ground, and I was pretty sure that I'd have to turn it into the beans to arrest the speed if I got much closer to the road which was coming up fast. Man, stuff was going by fast and the road was getting bigger, when it finally slowed enough to drop the tail. When I got out and looked around, I saw a plywood sign in the shape of an airplane, a wind sock, and a long building that looked like a series of hangars. I had landed at an real-life airport, complete with porta-potty and way too-long (thank God ) grass. (I later found out that this is called "Al's Place", by the locals) There was nobody at this airport, but I made a call and a nice man from 0G6 came out with fuel....he knew exactly where I had landed. I'll quit the story there because that was the important part...the landing and getting the fuel so I could continue home.
All this is to point out that what Deke mentioned is true....it is ( in my opinion) excellent practice to do what he said, although try to do it when you already have the airport in sight, and try to do it into a headwind, not with a tailwind like I was forced to do. I also didn't have my goggles nor any hearing protection, which would have been nice to block out the screams coming from the cabin.
By the way, what got me messed up was relying on the sight gauges more than the Northstar gauge. The fuel splashes up into those sight gauges, giving a false sense of more fuel than is actually there. And I had set the "GAS" reading on the Northstar to read 24 gallons when I had filled it the last time, not taking into account the unusable fuel. When I was circling over B25, I had the right wing up, and this was forcing the right tank to empty, and the left tank to unport. When I leveled off and headed for home, the right tank was empty, and the left tank was taking its own sweet time to re-supply the header tank with fuel, if indeed it had any to offer.
I've since then only entered 20 gallons into the Northstar under "GAS" after a fill-up, and only trust the sight gauges when the plane is rock steady.
Lynn Matteson
| Quote: | However, I still see no great risk why one couldn't practice a real world engine out by shutting down on downwind with a good long runway, have your tools ready, pull over off to the side and do a quick check. Of course, it's best to announce intentions, wear goggles, hearing protection, inform fire department...
= --> http:========================
Lynn Matteson
Posted: Mon Oct 19, 2009 8:20 pm Post subject: jetting a 582 and a choped elbow |
Thanks, Pat.
Please, I urge everyone to read: ( http://www.avweb.com/news/pelican/
182044-1.html ) which is the address for Pelican's Perch #7, in
which John Deakin "takes aim at yet another OWT (Old Wive's Tale)" ,
that of running a tank dry on purpose. He has some ideas that might
change a pilots mind about the subject of fueling your plane.
By the way, after flying home, I folded the wings back and removed
the finger strainers, thinking that maybe I had a flow problem
(because I positioned the plane to feed the rear/only fuel outlets
during the descent to the field), but there was absolutely NO
obstruction to the finger strainers after 3-1/2 years of flying with
100LL with Kreeme APPLIED CORRECTLY, according to the instructions.
I was very surprised that there wasn't ANYTHING on those strainers,
and nothing anywhere else. Just to be sure, I changed all the hoses
from the fuel tanks down to the header tank. I also changed the
Purolator fuel filters after the same time period, and they were also
clean, but I changed them anyway. I had already changed the lines
from the header forward during the Rotec TBI installation 2 months
ago. My fuel lines...SAE 30R7....were still flexible after those
3-1/2 years.
Another "by the way"....at this very minute, I just turned 73...Happy
Birthday to me, happy birthday to me.... : )
Lynn Matteson
On Oct 19, 2009, at 8:14 PM, Patrick Reilly wrote:
| Quote: | Lynn, Thanks for the insite. I have made a habit in the C150 I am
taking lessons in to make a point of, not having "enough " gas for
the mission, but, having enough gas to return with a minimum of 10
gallons still on board. That was after another club member alerted
that I had left the plane with only 2 gals of gas in it. It has 3
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Lynn Matteson
Posted: Mon Oct 19, 2009 8:49 pm Post subject: jetting a 582 and a choped elbow |
Another "by the way" comes from this incident....I covered 552
statute miles, and flew for a total of 5.9 hours during the running
dry of the fuel tanks. Earlier runs showed two consecutive trips that
garnered 513 miles each, and one filling that got me 531 miles, but I
will not try to beat this (552 miles) distance. Those earlier 513 and
531-mile trips were not run dry, just longer-than-normal tank runs.
In the 531-mile run, I used 19.7 gallons to fill after. I don't have
a figure for the fuel used after this latest (552-mile) trip, because
we added an unknown amount of fuel down there, and I drained the
tanks when returning home, etc., so no good figures on amount used.
An earlier low-fuel incident took 22.5 gallons (386 miles) to fill at
some place called Oshkosh...perhaps you've heard of it? : ) That
flight was with the Bing carburetor. After I told the guy how much
fuel it should take, and nearly hit it on the head, he said "You sure
know your airplane" ...maybe I know it a little TOO well. : )
Lynn Matteson
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Lynn Matteson
Posted: Mon Oct 19, 2009 8:50 pm Post subject: jetting a 582 and a choped elbow |
I dunno....just felt a bit stupid, I guess, Marco. Plus, I wasn't
sure how much trouble I'd be in if I made it public. But a good
lawyer (ugh!) would argue that I did such a good service by admitting
it and letting others know, that instead of getting a penalty, I
should be given a medal....geez, those guys are such....I don't know
what, but they are!
I've always maintained, like aviation technical author John Deakin,
that you should "Know thine airplane" and know how much fuel you need
for the flight, and not just blindly pour fuel into it each and every
time you land, because this is just wasteful in terms of carrying too
much fuel most of the time "and not very professional." For a very
good read on this subject, see "Pelican's Perch #7" ( http://
www.avweb.com/news/pelican/182044-1.html ) He makes very good sense,
and I encourage every pilot to read this article...you might come
away with a new outlook on "filling her up" every time you land. I
know people who just about wet their britches when they think about
missing an opportunity to put fuel in the plane.
Since this happened, I've begun to think seriously about adding
another fuel outlet at the front of the tanks, just to enable access
to that "unusable fuel" when in a pitch-down attitude....I'm still
mulling that one over.
Lynn Matteson
On Oct 19, 2009, at 9:01 PM, Marco Menezes wrote:
| Quote: | A valuable cautionary tale Lynn. Thanks. Why did you hesitate to
was your intent.
Marco Menezes N99KX
Lynn Matteson
www.matronics.com/contribution _-
N369LM |
Fox5flyer Guest
Posted: Tue Oct 20, 2009 5:13 am Post subject: jetting a 582 and a choped elbow |
Great report, Lynn. Its just this sort of information that gives us all
pause for thought and many of us thinking that we've been in similar
situations, but got lucky and were still able to get home or safely on the
ground. The big thing here is that you learned something from it and shared
it with the rest of us. There have been hundreds of List discussion posts
in the past about what would happen if a fuel tank became unported and this
is the first report I recall of actual fuel starvation because of it. This
confirms that one can actually run out of gas in our Kitfoxes while still
having plenty left. It also reminds us to not just rely on one source of
information (sight gauges) when we have others for backup (fuel flow
gauge/time). Thanks for sharing, Lynn.
Deke Morisse
Mikado Michigan
Posted: Tue Oct 20, 2009 6:31 am Post subject: jetting a 582 and a choped elbow |
Hey, we all have those lapses. I have my header tank vented into the slipstream. On fueling, I open the vent to let out all the air, then before start-up, close the valve between the vent and header. At least that's what my checklist says I'm supposed to do. This was someone's suggestion a few years back as a way of preventing fuel starvation from header vapor-lock.
Well, you can probably guess the rest. In any event, while the Northstar (I have a Navman) is a marvelous device, it's useless when the "wetware" fails.
P.S.: I don't think your "intent" alone can get you in legal trouble if you act alone (no conspiracy) and don't actually do anything unlawful. Oh, and did I ever tell you I am one of "those guys"? No charge for that.
Marco Menezes N99KX
Date: Monday, October 19, 2009, 11:22 PM
I dunno....just felt a bit stupid, I guess, Marco. Plus, I wasn't sure how much trouble I'd be in if I made it public. But a good lawyer (ugh!) would argue that I did such a good service by admitting it and letting others know, that instead of getting a penalty, I should be given a medal....geez, those guys are such....I don't know what, but they are!
I've always maintained, like aviation technical author John Deakin, that you should "Know thine airplane" and know how much fuel you need for the flight, and not just blindly pour fuel into it each and every time you land, because this is just wasteful in terms of carrying too much fuel most of the time "and not very professional." For a very good read on this subject, see "Pelican's Perch #7" ( http://www.avweb.com/news/pelican/182044-1.html ) He makes very good sense, and I encourage every pilot to read this article...you might come away with a new outlook on "filling her up" every time you land. I know people who just about wet their britches when they think about missing an opportunity to put fuel in the plane.
Since this happened, I've begun to think seriously about adding another fuel outlet at the front of the tanks, just to enable access to that "unusable fuel" when in a pitch-down attitude....I'm still mulling that one over.
Lynn Matteson
| Quote: | A valuable cautionary tale Lynn. Thanks. Why did you hesitate to tell it until now? Afterall, it wasn't "off-airport" even if that was your intent.
Marco Menezes N99KX
--- On Mon, 10/19/09, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
From: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
I needed 2 hours of flight a couple of weeks ago, so I could change my oil at my chosen time of 25 hours. I checked the fuel....8 gallons exactly...enough for a conservative 2 hour flight at my recent 3.0--3.8 gph. I took off and headed north, thinking of doing a half-hour in each of four directions, and being near home when the 2 hours were up. It was great flying weather, and it was mostly hands off flying. I kept checking my Northstar fuel flow gauge for remaining fuel and also checking the sight gauges in the wings...plenty of fuel according to the sight gauges, and adequate, according to the Northstar gauge. Getting near the end of my time allotment, I saw B25, an airport just into Indiana from the Michigan state line. I was curious about this airport, so I circled the field a couple of times trying to see if there was a building large enough for a B-25 plane, or if one was sitting outside. Seeing nothing along those lines, I figured I'd better head for home, and turned toward the northeast. I had flown in this direction for about 3 minutes, still looking outside and taking in the sights, when I caught sight of my low fuel warning light which was brightly lit. My clear vent line up to the right-hand fuel tank was empty, so I knew I was in deep do-do. I hit the NRST button on my GPS and saw Williams County (0G6) as the closest airport. This airport is just east of Bryan, Ohio, and 13 miles away from my (then) present location. The engine was still running, and I was at about 4,000 feet MSL. I pointed it in that direction, and hoped for the best, all the while looking for a place to land. I had covered about 7 miles when the engine stopped. I had tried to position the plane to allow the fuel to get to the port, but also hoping to make the airport, which meant "quit screwing around with the fuel and streamline the plane for best glide". Now I *really* started to look for fields. I could tell that I didn't want to try to stretch the glide, because this would put me..possibly...right over Bryan, Ohio, and that was not appealing at all. I'd covered maybe another mile when I saw a long green stretch of land between all the brown fields of beans growing in the area. I said to my self that this was gonna become an airport in the next few minutes, and started to slip down toward it. The wind was from about 220° and this strip of green was running 9-27. I was north of it, and I didn't want to try landing into the wind because that would have eaten up too much altitude. So here I was slipping it down to the west end of this "soon-to-become airport" at a pretty good clip, and finally had to straighten it out and put it down. When it finally touched down, I was going pretty damn fast, and got all over the brakes and it pulled to the right and headed for the beans. I got that straightened out and kept braking hard, with the nose of the plane getting too damn close to the ground...I'd never had the tail that high before on the ground, and I was pretty sure that I'd have to turn it into the beans to arrest the speed if I got much closer to the road which was coming up fast. Man, stuff was going by fast and the road was getting bigger, when it finally slowed enough to drop the tail. When I got out and looked around, I saw a plywood sign in the shape of an airplane, a wind sock, and a long building that looked like a series of hangars. I had landed at an real-life airport, complete with porta-potty and way too-long (thank God ) grass. (I later found out that this is called "Al's Place", by the locals) There was nobody at this airport, but I made a call and a nice man from 0G6 came out with fuel....he knew exactly where I had landed. I'll quit the story there because that was the important part...the landing and getting the fuel so I could continue home.
Lynn Matteson
========================http://www.matronics.com/Navigator?Kitfox-List --> http://www.matronics.com==================
Guy Buchanan
Posted: Tue Oct 20, 2009 6:45 am Post subject: jetting a 582 and a choped elbow |
At 08:22 PM 10/19/2009, you wrote:
| Quote: | Since this happened, I've begun to think seriously about adding
The problem with the front outlet is that you have to run it down the
forward door post. It's ugly and makes your life difficult when you
want to fold. Easier to just consider one or two gallons unusable,
just like you do in any vehicle.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Tue Oct 20, 2009 12:30 pm Post subject: jetting a 582 and a choped elbow |
My condolences, Marco, on your choice of profession. : )
You just watch....as soon as I need one of "your type" you'll all be
the nicest bunch of guys I've ever run into. : )
Thanks for the consultation, Marco. By the way, ever since I retired
from the University of California, in fact even before I retired,
I've paid into the Legal Plan every month. I figured that as long as
I keep paying, I'll never need their services....but that was before
I learned(?) to fly.
Lynn Matteson
On Oct 20, 2009, at 10:26 AM, Marco Menezes wrote:
| Quote: | Hey, we all have those lapses. I have my header tank vented into
Marco Menezes N99KX
N369LM |
Lynn Matteson
Posted: Tue Oct 20, 2009 12:36 pm Post subject: jetting a 582 and a choped elbow |
Thanks for the insight, Guy. Yeah, I know it would be visible running
down the front post. I may just hang a short hose along that post and
live with looking at it for a while and see how much it bothers me
seeing it there. But like you said, it's easier to educate the pilot
(well, MOST pilots) than it is to change the plane.
Speaking of vehicles, I used to have two tanks in an old Toyota motor
home, and I would run the first tank until it ran out and quickly
switch to the other when it started to stumble. I gotta remember I
ain't just cruisin' along the freeway nowadays. : )
Actually, I don't fold the wings hardly ever, and I was thinking of
using a smooth fitting with a bulb-end at the front of the tank. They
come apart pretty easy....still thinking about it....
Lynn Matteson
On Oct 20, 2009, at 10:02 AM, Guy Buchanan wrote:
the forward door post. It's ugly and makes your life difficult when
you want to fold. Easier to just consider one or two gallons
unusable, just like you do in any vehicle.
Guy Buchanan
San Diego, CA
N369LM |
