albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Fri Oct 23, 2009 7:05 pm Post subject: Cheap hanger ideas |
Hi again,
Anyone have some good ideas for a cheap hangar just to keep snow and the likes off of the kolb?
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
rickofudall
Posted: Fri Oct 23, 2009 8:43 pm Post subject: Cheap hanger ideas |
Do they have those cheap steel carports in Canada? They're pretty thin corrugated so I don't know how they'd do for snow loads, I don know that they stand up to 70 mph winds. Not bad for a structure that's nailed to the ground. If you folded the wings for the winter you could get by with a single car size and extend the length for just a bit more money. There was an article in EAA's Light Sport Magazine about a fellow who made a footing to extend the height and used it for his trike. I had a buddy who bought one of the silver tarp portable carports and it was rotten inside of two years.
Rick
On Fri, Oct 23, 2009 at 10:05 PM, albertakolbmk3 <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)> wrote:
[quote]--> Kolb-List message posted by: "albertakolbmk3" <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)>
Hi again,
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p=269197#269197
le, List Admin.
gliderx5
Posted: Sat Oct 24, 2009 4:25 am Post subject: Cheap hanger ideas |
Fred Kerfoot
Posted: Sat Oct 24, 2009 4:47 am Post subject: Cheap hanger ideas |
If you don't mind folding the wings C you can get a used 40' Sea/Land container. They are strong C very secure C excellent protection from the weather (anything short of tornado) lots of extra storage (40') and relatively inexpensive. In Florida you can find a good used weather-tight container for less than $2000 US. If you don't want to fold the wings you might want to consider a pole shed.
http://www.ehow.com/how_4697457_build-pole-shed.html
FredK
Windows 7: It helps you do more. Explore Windows 7. [quote][b]
_________________ Fred K
Do Not Archive |
Thom Riddle
Posted: Sat Oct 24, 2009 4:59 am Post subject: Re: Cheap hanger ideas |
albertakolbmk3,
I respectfully request that you edit your signature, which includes lots of information about your airplane, to include your name.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Oct 24, 2009 6:33 am Post subject: Cheap hanger ideas |
Fredrick Kerfoot wrote:
Quote: |
If you don't mind folding the wings, you can get a used 40' Sea/Land
container. They are strong, very secure, excellent protection from the
<http://www.ehow.com/how_4697457_build-pole-shed.html>
FredK
I'd 2nd that idea, with a minor mod to the technique. If you design with
a 'single pitch' roof, you can do it with 4x4 or 6x6 posts and steel
purlins, used to build metal buildings. The purlins can be purchased to
span amazing distances. Set 2 rows of posts at whatever width you need
for the plane, with the post spacing determined by spacing requirements
of the purlins you buy (typically around 4-5 feet). Make the 2 posts at
the entry end the tallest, and the posts at the back the shortest; your
choice of pitch. Pull a line along the posts at the chosen pitch angle,
mark the tops at that angle & cut the tops. Using 'Z' channel purlins
allows you to sit the purlin on the cut top of the post at the correct
angle. Cut wood wedges to fill the gaps between the purlin's 'web' and
the post, or just trim the high side of the posts at the right angle if
you're using 6x6 posts. Lay metal roofing on the purlins & go to work
with the screw gun.
Shelter done.
I added a 30x50 lean-to addition to my hangar using a similar technique
& built the entire structure totally alone. The 30' purlins were light
enough for me to lift one end & carry it up the ladder to set in its
hanger on one end, then lift the other end to the top of its post. The
32' pieces of roofing were placed on an over-extended extension ladder
going from the ground to the eave, then dragged/pushed onto the roof.
The work would have gone 3 or 4 times faster with a helper, but the
point is, a helper isn't absolutely required.
The benefit of the single pitch roof is that all the water runs to the
back, meaning you won't need a gutter on the front to keep water away at
the entrance. (Simpler to build, too.)
BTW, isn't it amazing how many new and unexpected things you can learn
when you visit a new web site? I've always wanted to 'learn to pole
dance at home'....
Charlie
Thom Riddle
Posted: Sat Oct 24, 2009 6:54 am Post subject: Re: Cheap hanger ideas |
The airport where I keep my Slingshot does not allow privately built hangars since hangar rent is a big part of their revenue, at $250/mo rent and they are full with a waiting list. However, on the end of each row of T-hangars is a 1/2 T-hangar space with a wide roll up garage type door. Some of these are used for storage of ground maintenance equipment including snow plows etc.
I am renting one of the unused 1/2 T-hangar spaces and store my Slingshot in it during the winter and tie-down outside during the summer flying season. I would probably fold the wings after every flight and store it in the 1/2 T if it did not require muffler removal. My A&P I/A partner and I
http://riddletr.googlepages.com/a%26pmechanix
store our tools and equipment there and do a small amount of maintenance and inspection work on airplanes there which pays for our shop and my winter storage space at $100/mo. It is not ideal but it is cheap enough with the bit of revenue we get.
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Sat Oct 24, 2009 7:11 am Post subject: Cheap hanger ideas |
At 10:54 AM 10/24/2009, Thom Riddle wrote:
Quote: | ...on the end of each row of T-hangars is a 1/2 T-hangar space with a wide
the 1/2 T if it did not require muffler removal...
Couldn't you fit it in the 1/2 T by folding only one wing? Of course it
depends on which half of the T you have...
At our airport there's a Firestar (folded) and a gyrocopter sharing a 1/2 T.
-Dana
The first rule of intelligent tinkering is to save all the parts.
Thom Riddle
Posted: Sat Oct 24, 2009 7:29 am Post subject: Re: Cheap hanger ideas |
Dana,
Yes I could fold just the left wing but would still have to remove the muffler to do that. It has two springs (like Rotax exhaust) per cylinder and safety wire securing each spring. Too much work for folding after every flight. If it were not for the need to safety the springs, the muffler removal would probably not be too onerous, but 8 safety wires is more than I'm willing to do every time I want to fly. I have an adequate cover for the canopy and engine but will be making a new and better one this winter.
While on this subject of tie-down outside... someone this list has commented that the Jabiru engines are prone to hard starting in humid conditions, at least the one(s) he was familiar with. It is not particularly humid here in Buffalo during the summer except when it rains. Once this summer, my first attempts at an engine cover failed during a rain storm and the engine was out in the rain over night. It was drenched when I arrived at the airport the next morning. It cranked right up with no problems.
Perhaps the Jabiru that someone commented about was a very early model or perhaps the spark gaps (plugs and coils) were not set properly, or their distributer caps were not sealing properly. I can't say but can say without equivocation that I've not had any starting problems on my Jabiru 2200A (#1574) in any conditions, including those just described.... discounting the time I left the master switch on overnight .
Buffalo, NY (9G0)
- Anonymous |
Richard Pike
Posted: Sat Oct 24, 2009 7:44 am Post subject: Re: Cheap hanger ideas |
albertakolbmk3 wrote: | Hi again,
Anyone have some good ideas for a cheap hangar just to keep snow and the likes off of the kolb? |
Here is a page showing how I built my hangar back in the 80's, we added another one just like it alongside a couple years back for Ed's FSII. It cost $1800 to build 25 years ago, Ed's recent one cost about $3200.
We use a roll up and roll down tarp across the front.
http://www.bcchapel.org/pages/0003/Hangar.html
One correction to the article on that page, what took 4 days 25 years ago takes 2 weeks after you pass age 60...
I can post more pictures if you want.
Richard Pike
MKIII N420P (420ldPoops)
ulflyer(at)verizon.net Guest
Posted: Sat Oct 24, 2009 7:39 pm Post subject: Cheap hanger ideas |
There a way of interlocking the springs using small dia. aircraft
cable where it can be quickly removed and taken out. Think about how
you would do it.
jerb
At 08:30 AM 10/24/2009, you wrote:
Quote: |
Dana,
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x31
A complex system that works is invariably found to have evolved from
a simple system that works.
- John Gaule
http://forums.matronics.com/viewtopic.php?p 69232#269232
frank.goodnight(at)att.ne Guest
Posted: Sun Oct 25, 2009 6:12 am Post subject: Cheap hanger ideas |
Hi Richard ,
Thanks for the photos of the mods to your firestar. I'm especialy
interested in the PVC
fuel tanks. I,m planing to fly to M.V. this spring and some of the
legs in west Texas are
longer than my fuel supply. I had thought about strapping on a 5
gallon jug, and landing
someplace to pour it into my mains, but I like your idea better. My
concern is with the glue
and fuel with alcohol. Did you use the pvc cement that you can buy at
home depot & have
you had any problems? Thanks for any info you may be able to provide me.
Frank Goodnight
Firestar2
Brownsville Tx
On Oct 24, 2009, at 10:44 AM, Richard Pike wrote:
> Hi again,
about $3200.
Richard Pike
http://forums.matronics.com/viewtopic.php?p 69234#269234
Thom Riddle
Posted: Sun Oct 25, 2009 8:38 am Post subject: Re: Cheap hanger ideas |
Jerb,
The cable run through all the springs is worthing investigating. I'll do that tomorrow when I visit my slingshot next.
Rick,
I'll see if Jabiru sells another smaller muffler that might work on the Slingshot. It appears to me that my muffler is no wider than the engine either but the wing hinge location on the Slingshot is pretty close together, about 12" on centers if my eyeball tape measure is not too far off. The existing muffler is probably closer to 24" wide.
Thanks for your ideas.
Buffalo, NY (9G0)
- Anonymous |
Richard Pike
Posted: Sun Oct 25, 2009 8:03 pm Post subject: Re: Cheap hanger ideas |
[quote="frank.goodnight(at)att.ne"]Hi Richard ,
home depot & have
Frank Goodnight
Firestar2
Brownsville Tx
Used the glue that Lowe's sells, no problems in 2 years.
But when I rebuild the airplane, will be trying my hand at building an aluminum tank and mounting it in the upper area as John does with his MKIII. Ought to be able to get at least 12 gallons in the FSII, and have storage space underneath it. If it works out, will have these tanks for sale.
Richard Pike
albertakolbmk3
Posted: Mon Oct 26, 2009 10:12 am Post subject: Re: Cheap hanger ideas |
Thanks for the ideas guys... I especially like the idea of using perlings.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
