		ledson
				 Posted: Mon Oct 26, 2009 10:05 am    Post subject: Engine oil check door |
				I'm considering the addition of an oil check door for my Allegro 2000.  My question is, has anyone installed one on their aircraft, and if so do you have any information on the process that you can share?
 Larry
 N4362C
  |  | - The Matronics Allegro-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Allegro-List |
		hgmckay
				 Posted: Mon Oct 26, 2009 1:53 pm    Post subject: Engine oil check door |
				Larry:
  I have an oil level check "door" on my Allegro 2000. It is part of the top engine cowel, and it came with the airplane kit which I completed 2 years ago. I have over 300 hours on the Rotax 912 UL engine, and have never used the door. It is a useless addition. Here is why. Each time you check the oil level in the oil reservoir you should also check the coolant level in the small expansion reservoir on top of the engine (this is not the overflow bottle). To check the coolant level you have to remove the top engine coweling. This allows you to also check the oil level. This also allows you to inspect your engine as well. It only takes a minute to remove the top engine cowel.
  I would not waste my time by adding such a door.
  Hugh McKay
  Allegro 2000
  Rotax 912 UL
  N661WW
 --- On Mon, 10/26/09, ledson <ledson(at)oneil.com> wrote:
 Subject: Engine oil check door
 To: allegro-list(at)matronics.com
 Date: Monday, October 26, 2009, 2:05 PM
  --> Allegro-List message posted by: "ledson" <ledson(at)oneil.com (ledson(at)oneil.com)>
 Larry
 N4362C
 http://forums.matronics.com/viewtopic.php?p=269520#269520www.matronics.com/Navigator?Allegro-List" target=_blank>http://www.matron;                     -Matt Dralle, List m/contribution" target=_blank>http://www.matronics.com/contribution
  | 	   [quote][b]
