txpilot
Posted: Wed Oct 28, 2009 7:18 am Post subject: 701 Max structural Cruising Speed |
Does anyone know the max structural cruising speed for the 701 (VNO)?
I can't seem to find it in the plans. They only show max flaps down, maneuvering speed, and VNE.
Dan Ginty
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lgold(at)quantum-associat Guest
Posted: Wed Oct 28, 2009 5:06 pm Post subject: 701 Max structural Cruising Speed |
Dan,
On the third page of my copy of the 701 plans (Page 7-G-3) there is a speed
limitation paragraph. It says the Vne is 110 mph or 180 km/h. However, the
plane is so "draggy" that you have to work a little to get it past Vne.
Les
txpilot
Posted: Wed Oct 28, 2009 6:14 pm Post subject: Re: 701 Max structural Cruising Speed |
Yes, Thanks Les. I got the Vne, but I'm looking for Vno. Vne (110 mph) is the redline on the airspeed indicator. Vno, the maximum structural cruising speed, should be the 'divider' between yellow and green arcs on the airspeed indicator.
Dan
Posted: Wed Oct 28, 2009 7:07 pm Post subject: 701 Max structural Cruising Speed |
Dan,
Now I have questions! What does Vno represent and why is it important for
you to know its value?
When I fly I want to know how fast the plane can go before the thing will
fly apart, what is the maximum speed I can go in turbulent air during
turbulent maneuvers, what speed do I need to be at so I can deploy flaps,
and the speed the plane will stall at in various configurations. I think I
know these things. The first three are provided by Zenith and the last I
have come to by testing. Why do I need to know Vno?
Les
jetboy
Posted: Wed Oct 28, 2009 8:50 pm Post subject: Re: 701 Max structural Cruising Speed |
For the TP10141E specd 701
Vfe 52Kt
Vno 74Kt
Vne 96Kt
for Europe specs complying with BCAR'S'
Vfe 55Kt
Va 62Kt "max speed for large abrupt control changes"
Vno 78Kt " max structural cruise clean air"
Vne 94Kt
Ralph
_________________ Ralph - CH701 / 2200a |
txpilot
Posted: Wed Oct 28, 2009 9:39 pm Post subject: Re: 701 Max structural Cruising Speed |
Quote: | Now I have questions! What does Vno represent and why is it important for
Vno is essentially defined by FAR Part 23 Cert standards. I know it's not required since we're experimental, but here's the gist:
Aircraft Manufacturers like Cessna show Vno as the max cruising speed and say "Do not exceed this speed except in smooth air, and then only with caution." Basically, the certified aircraft are required to show no structural damage if the aircraft encounters vertical gusts up to 50 fpm at or below Vno (The FAA call it Vc). For reference, it's under FAA Regs 23.333 through 23.337, although I recommend a strong cup of coffee before diving into it!
Conservatively, I could just call Va at 84mph the Vno speed, but with a 100hp Rotax engine I'm hoping the aircraft will fly faster than 84mph. I'm not interested in flying the plane continuously in a yellow arc region and would simply like to know what value I could safely show the green arc.
Dan
