Charles Heathco
Posted: Mon Nov 02, 2009 3:28 am Post subject: engine mount washers |
Thanks for the info re washers, now who is the math whiz that knows how thick the washer should be to raise the front 3/8"? I heard mention of cutting a slot to enable sliping behind mount, anyone done this?
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Mon Nov 02, 2009 5:16 am Post subject: engine mount washers |
charlie heathco wrote:
Quote: | Thanks for the info re washers, now who is the math whiz that knows how
I can't help with the math, but my comment is ..... what can slip in
.... can slip out.
Linn
Posted: Mon Nov 02, 2009 5:50 am Post subject: engine mount washers |
Changed my mind. Measure from the floor to the prop. Measure how much
you want to lift the engine. Pull the lower isolator bolts and shim
until you get the sum of the two measurements. Best I can offer.
Linn
> this?
..... can slip out.
Linn
Kellym
Posted: Mon Nov 02, 2009 7:03 am Post subject: engine mount washers |
Not when supporting 300+lbs of engine, with slot to the bottom. Standard
industry practice.
Linn Walters wrote:
Quote: | I can't help with the math, but my comment is ..... what can slip in
..... can slip out.
Linn
KCHD |
Posted: Mon Nov 02, 2009 8:13 am Post subject: engine mount washers |
Kelly, I find that troublesome .... it may be standard practice .....
but I stand by my comment. When the airplane is flying, all the engine
weight isn't on the isolators, and where the washers go .... it can
become looser and conceivably work it's way out. No real problem
if/when it does, but I don't see why you'd slot the washer just to save
a little time. Well, if you're wrenching for a living ......
Linn
Kelly McMullen wrote:
industry practice.
> ..... can slip out.
> Linn
> do not archive
John Myers
Joined: 10 Jan 2006 Posts: 11 Location: Cedar Bluff, AL
Posted: Mon Nov 02, 2009 9:21 am Post subject: engine mount washers |
Kelly, Lynn, others,
This may be a dumb question, but wondering if everyone is talking the same
location for washers. I have seen washers mounted under isolation mounts
as it seems most are talking about but I have also seen 970's added under
the engine mount to firewall gussets. I have used both locations for
different purposes. One to reposition the isolation mount geometry and one
to reposition the whole mount and engine. I know of one occasion where the
spacer inside the mount was reduced in length to tighten up the isolation
mount. I would think they present different problems and or solutions. The
engine tends to change it's weight on the mounts during flight and moves
around a lot during cranking, shutdown and anything other than 1 G flight.
On the other hand the mount to firewall fit is more rigid and tends to stay
where you bolt it. However a loose bolt or lost washer at that location is
possibly more troublesome as the bolt size there may not be sufficient,
given the abuse that occurs when they are loose.
I also have a sagging engine and was planning on going with one or two 970's
between the mount and firewall, but also realize that in flight the engine
may not be sagging as much. It seems that most commenting on this thread
are putting a 970 washer under the isolation mount but I don't see how that
will tighten up the isolation mount without treating the internal spacer.
I don't do any negative G stuff (on purpose anyway) and generally never
exceed 3 to 3.5 G positive but the engine still moves around a lot with
gyroscopic actions as well as simple G loads. Is the concensus that short
of changing out the mounts, the best approach is to washer up the isolation
mounts? I know the best solution would probably be to replace the kit iso
mounts with Lord mounts but what is the consensus for next best solution.
John Myers with a little sag with a 360 on an 8
Posted: Mon Nov 02, 2009 12:25 pm Post subject: engine mount washers |
It'll be the first one! <GR>
Quote: | same location for washers. I have seen washers mounted under isolation
mounts as it seems most are talking about but I have also seen 970's
added under the engine mount to firewall gussets. I have used both
locations for different purposes. One to reposition the isolation mount
geometry and one to reposition the whole mount and engine. I know of
one occasion where the spacer inside the mount was reduced in length to
tighten up the isolation mount. I would think they present different
problems and or solutions. The engine tends to change it's weight on
the mounts during flight and moves around a lot during cranking,
shutdown and anything other than 1 G flight. On the other hand the mount
to firewall fit is more rigid and tends to stay where you bolt it.
However a loose bolt or lost washer at that location is possibly more
troublesome as the bolt size there may not be sufficient, given the
The mount bolts are not as accessible (like on the inside) as the
isolators, so I typically work on the isolators. Putting washers under
one or two of the airframe bolts also stresses the steel mount. Just MHO.
970's between the mount and firewall, but also realize that in flight
the engine may not be sagging as much. It seems that most commenting on
this thread are putting a 970 washer under the isolation mount but I
don't see how that will tighten up the isolation mount without treating
The washer goes forward of the isolator and the flat on the engine
mounting ears if you have the ring type isolator mounts. On mounts
where the isolator is cone shaped and sandwiches the mounting ear, then
the washer will be behind the isolator.
short of changing out the mounts, the best approach is to washer up the
isolation mounts? I know the best solution would probably be to replace
the kit iso mounts with Lord mounts but what is the consensus for next
best solution.
I'd use the washer method before spending so much money on new
isolators. I've seen no difference in who makes them .... in my limited
experience. I think the consensus is ..... whatever you prefer. No
matter what route you take, the end result should be the same. Best of
luck.
Linn
Kellym
Posted: Mon Nov 02, 2009 2:21 pm Post subject: engine mount washers |
The washers are clamped in place by the engine mount bolts with locking
nuts. No way for them to work loose. I've heard similar arguments about
certain aircraft tiedown rings that aren't secured by anything other
than the tightness of the threads and torque applied. Haven't seen one
fall out yet.
Linn
> Standard industry practice.
>> ..... can slip out.
>> Linn
>> do not archive
KCHD |
mcculleyja(at)starpower.n Guest
Posted: Mon Nov 02, 2009 3:32 pm Post subject: engine mount washers |
Another viewpoint based on experience with the slotted-washer spacers (&
slot downward).
I placed 1/8 inch thick ones behind the two lower mounts and one stayed
in place without problems. The other one gradually worked upward in
about 10 hours time. After twice putting it back in proper location and
seeing it creep up each time, I finally added a drop of CA glue between
the surfaces and no problems to date after another 200 plus hours.
Jim McCulley
industry practice.
> ..... can slip out.
> Linn
> do not archive
rice737(at)msn.com Guest
Posted: Mon Nov 02, 2009 5:23 pm Post subject: engine mount washers |
Anyone who has done this C
With reference to adding washers between the engine and the mount C did you have to get longer bolts as well? It looks like the cotter pin hole would be covered up if I add even a thin washer.
Paul Rice
RV8 180 hours
[quote] Date: Mon C 2 Nov 2009 18:29:07 -0500
To: rv-list(at)matronics.com
Subject: Re: engine mount washers
--> RV-List message posted by: "J. Mcculley" <mcculleyja(at)starpower.net>
slot downward).
seeing it creep up each time C I finally added a drop of CA glue between
Jim McCulley
> --> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com>
> Not when supporting 300+lbs of engine C with slot to the bottom. Standard
> industry practice.
> Linn Walters wrote:
>> --> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net>
>> I can't help with the math C but my comment is ..... what can slip in
>> ..... can slip out.
>> Linn
>> do not archive
