occom
Posted: Tue Nov 03, 2009 3:37 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
This was one of the things on my mind when I did not move the header tank
from the firewall. When I do an additional fuel pump might be a worthwhile
addition. With the old aluminum header close to the pump and roughly the
same level or above the carbs it seemed to me that fuel flow was about as
assured as possible. The fact that almost everyone else has it way down low
behind the seats and experiences no problems is assuring but then most are
flying behind fourstrokes with stronger mechanical pumps that the little
diaphragm rig the two strokes run. In a static level setup mine flows far
in excess of requirements, when the tailwheel is on the ground and the wing
tank(s) near empty , fuel flow is marginal/inadequate for the 582 . No
filters between the wings and the header in this setup.
Dave Goddard
KF IV 1050 / 582 / Warp
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Tue Nov 03, 2009 4:37 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Today, I am going to work on the fuel outlet (from the tanks) area of my fuel system. Plan to cut the nipple off the 90 elbow so I can unscrew it, remove the finger strainer and start over with the elbow assembly.
What should I use to reseal the finger strainer fitting to the fiberglass tank? Hopefully something I can purchase locally.
Second, I will be cutting the root rib (end rib) to the fuel line does NOT run uphill before entering the fuselage! After thinking about this hump...it actually makes for a large area for air to collect.
At least I feel like I am making progress with my problem!.
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Nov 03, 2009 6:45 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
| Quote: | Today, I am going to work on the fuel outlet (from the tanks) area of my fuel system. Plan to cut the nipple off the 90 elbow so I can unscrew it, remove the finger strainer and start over with the elbow assembly.
Travis, after you get the fittings at the tank outlet apart take note of the inside diameter. I'll bet it is 1/4 inch. A couple of those brass fittings for the fuel system that came with my Kit had 1/8th inch inside diameter. Once plumbing is reduced down you will never increase the downstream flow with larger fuel line.
I would check the inside diameter of the on/off valves and other fittings in the system too if you haven't already.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Tue Nov 03, 2009 6:48 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I used Permatex Aviation Gasket Maker, or threadsealer, or something
like that. It comes in a 4-ounce bottle, I think. The number I really
recall is 3H. Dan Mc Intyre just mentioned Permatex 9 AR Tack and
Seal, so if that is available, you might try it. The 3H stuff I
mentioned is a little bit runny, so I mix it up good, apply it, then
let it set up for 10 minutes before screwing the strainers back in.
When I first installed my finger strainers 3 years ago, I applied the
3H sealer to the male f'strainer threads, AND to the tanks' internal
threads. Then I had to be very careful to insert the f'strainer into
the hole without getting any goop onto the screen.....PITA! I got a
little tiny bit of goop on the screens, (as I found out when I
removed them a couple of weeks ago) but it was only a little and not
worth worrying about, but I didn't do that again. This last time I
only applied it to the male threads on the f'strainer, and they are
holding fine...no leaks.
Lynn Matteson
Jabiru 2200, #2062, 805.4 hrs
Countdown to 1000 hrs--195 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Nov 3, 2009, at 7:38 AM, FlyboyTR wrote:
elbow assembly.
collect.
Travis
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70758#270758
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
FlyboyTR
Posted: Tue Nov 03, 2009 7:26 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Thanks Tom & Lynn...
My fuel valve is for 5/16 fuel hose. The ID was slightly less than 1/4". I drilled them out to....9/32" ( I believe...). Anyway, just slightly larger than 1/4". I will probably drill out the new elbow and nipple coming out of the tank as well.
I plan to push some Goop into the nipple, all the way into the elbow, prior to cutting it with the rotary tool. At least...should i have a spark from the cutting wheel (or spark from the motor) it will be isolated from the tank. Don't need no excitement today!
I'll report on the results. If you don't hear from me...you will know it probably didn't go well!
Travis
Mobile, AL
ADI-II Autopilot
Tom Jones
Posted: Tue Nov 03, 2009 7:48 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
| Quote: | | I plan to push some Goop into the nipple, all the way into the elbow, prior to cutting it with the rotary tool. At least...should i have a spark from the cutting wheel (or spark from the motor) it will be isolated from the tank. Don't need no excitement today! |
Purge the tank. I had some welding done near the panel fuel tank on my kitfox. It was done at the Skystar factory. Their welder just purged it with compressed air.
Classic IV
Ellensburg, WA |
FlyboyTR
Posted: Tue Nov 03, 2009 8:34 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Tom,
I know some folks will weld and cut after just blowing out a tank with compressed air... However, since I do frequent welding and cutting for friends, and I have headr of, and seen, several tanks explode (not by my doing). Blowing it out with compressed air really doesn't purge the tank. If there is ANY fuel in a seam, or even a damp area it is a recipe for disaster.
Way back when, I used to weld on race car tanks with fuel in them. However, I had a 3 HP Clinton engine that I ran VERY rich...barely running...and ran a line from the exhaust and down into the fuel tank I was working on. The carbon monoxide would displace/replace any O2 and a fire or explosion was no threat. Never had a problem...however, I wouldn't do it now. ...strange how things change with time!
I'm not saying is can't be done that way...it's just not a safe practice (IMHO). ...sorry ya'll...didn't mean to go off topic!
[quote="Tom Jones"] | Quote: |
Purge the tank. I had some welding done near the panel fuel tank on my kitfox. It was done at the Skystar factory. Their welder just purged it with compressed air. |
Mobile, AL
ADI-II Autopilot
Lynn Matteson
Posted: Tue Nov 03, 2009 12:05 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Ok, Travis, I can't let ya get by with just *your* story...gotta
throw one of mine in there, too.
I was severely lowering (chopped, channelled, and sectioned) a 1950
Oldsmobile Holiday Coupe (God, I wish I had that now, in stock
condition!), and decided to put the fuel filler neck inside the
trunk, so I stuffed wet rags down inside the filler neck below where
I was going to cut it with a hacksaw. I had prepared the wet rags by
rolling them together, then wrapping a 1/16" welding wire around
them, leaving the long end of the wire sticking out of the filler
neck. I them sawed the neck apart, avoiding cutting the wire, and
rotated the neck so it was about 180° from where it started, and
pointing inside the trunk. Then I re-wet the rags, fired up the torch
and welded the neck back on, pulled on the wire and out came the rags
and most of the hacksaw droppings.
Hey, maybe this is where I started to appreciate fuel filters! You
know, like the ones on our Kitfox's (to stay on topic). Speaking of
which, I dropped into KFPK Charlotte, Michigan, while flying today,
and the IA there said he was restoring a Model III with a (of course)
Rotax 80 hp engine. I'll check back with him in a few months and see
how it goes.
Lynn Matteson
Jabiru 2200, #2062, 807.7 hrs
Countdown to 1000 hrs~193 to go
On Nov 3, 2009, at 11:34 AM, FlyboyTR wrote:
problem...however, I wouldn't do it now.[Shocked] ...strange how
N369LM |
FlyboyTR
Posted: Wed Nov 04, 2009 6:07 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Well...Nothing went boom at the airport! I injected some silicone into the fitting prior to cutting the nipple. All parts were removed without issue. The finger strainer was clean as a pin! There was a tiny bit of residue laying under the strainer in the little sump area. No heartburn there!
Today I will complete the mods to the left wing root rib and reconnect the fuel system on that side. Then, do the right wing.
The header tank has a fitting/plug on the end/side of the tank, near the top. Was this for the addition of a low fuel sensor? I know there are several available (I was looking at Murle Williams unit, self contained little can, that sits on top of the tank). Is there one that just screws into the tank?
Lynn...good story!
Mobile, AL
ADI-II Autopilot
Lynn Matteson
Posted: Wed Nov 04, 2009 9:36 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I have the same opening in my header, Travis, and if memory serves
me, there is a float valve that will screw into this opening, but for
some reason my switch wouldn't work....switch was too long, or
something like that. I do know that you have to be careful screwing
the switch into that opening, so that the float doesn't flop over and
hit something and you break it off inside. I ended up getting the
Williams can, and using my switch. He does sell it as a complete
unit. I see the benefit of having his external can as giving you
about a 2 minute earlier warning than the in-header-tank
version....and I need all the help I can get. : ) There are also
optical sensors available, I've heard.
Ah yes, the good old days of welding bravery/stupidity. Nowadays I
exhibit my bravery/stupidity in other ways.
Lynn Matteson
On Nov 4, 2009, at 9:07 AM, FlyboyTR wrote:
Well...Nothing went boom at the airport! [Shocked] I injected
Lynn...good story!
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70930#270930
N369LM |
Pat Reilly
Posted: Wed Nov 04, 2009 10:16 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Lynn, Tell me more about the float switch problems you experienced. I have one in my header tank, and the damn thing won't work. I pulled it out checked it with continuty meter. It seemed to work again . I put it back in and again it doesn't work. The switch is hooked to ground to close and complete the circuit with power directly to the warning light. The light stays lit. The circuit is complete all the time. I know I haven't got the switch in upside down. It has to be a magnetic switch of some kind as the pivoting float cannot, and does not attach by wire. I think the magnet must be too weak to work when installed in the tank for some reason.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Wed, Nov 4, 2009 at 11:31 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I have the same opening in my header, Travis, and if memory serves me, there is a float valve that will screw into this opening, but for some reason my switch wouldn't work....switch was too long, or something like that. I do know that you have to be careful screwing the switch into that opening, so that the float doesn't flop over and hit something and you break it off inside. I ended up getting the Williams can, and using my switch. He does sell it as a complete unit. I see the benefit of having his external can as giving you about a 2 minute earlier warning than the in-header-tank version....and I need all the help I can get. : ) There are also optical sensors available, I've heard.
Ah yes, the good old days of welding bravery/stupidity. Nowadays I exhibit my bravery/stupidity in other ways.
Lynn Matteson
[quote]--> Kitfox-List message posted by: "FlyboyTR" <flyboytr(at)bellsouth.net (flyboytr(at)bellsouth.net)>
Well...Nothing went boom at the airport! [Shocked] I injected some silicone into the fitting prior to cutting the nipple. All parts were removed without issue. The finger strainer was clean as a pin! There was a tiny bit of residue laying under the strainer in the little sump area. No heartburn there!
Lynn...good story!
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p=270930#270==========
he Contribution link below to find out more about
lder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
-Matt Dralle, Li - The Kitfox-List Email Forum -
fox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List< - MATRONICS WEB FORUMS -
= --> h
Lynn Matteson
Posted: Wed Nov 04, 2009 11:55 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Why not put the inspection ring in place during the covering job?
Then paint a couple of covers to match that area (stripes, etc), and
you're ready to cut out the fabric and install the cover if need be.
Lynn Matteson
On Nov 4, 2009, at 2:18 PM, Dorsal wrote:
FWIW, When I covered my wing I put a U-shaped aluminum reinforcing
plate under the fuel fitting. If I should need to inspect the
finger strainer I will be able to cut the fabric and fabricate a
simple cover plate.
http://forums.matronics.com/viewtopic.php?p 70992#270992
N369LM |
Lynn Matteson
Posted: Wed Nov 04, 2009 11:56 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Boy, that IS weird. I'm tempted to think that the torque of screwing
it in somehow causes a "tweak" in the body and it won't make contact
in that configuration. I'm pretty sure that your wiring is the same
as mine....hot to the bulb, and ground through the switch to a good
ground. The only thing I can suggest is to check for "normally open"
or "normally closed", but I'm sure you've done that. The switch
should "connect" when the float drops, as I'm sure you know.
Lynn Matteson
On Nov 4, 2009, at 1:13 PM, Patrick Reilly wrote:
| Quote: | Lynn, Tell me more about the float switch problems you experienced.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Wed, Nov 4, 2009 at 11:31 AM, Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Lynn...good story!
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70930#270==========
contribution
Email Forum -
= --> h
N369LM |
Dorsal
Posted: Wed Nov 04, 2009 3:32 pm Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
| Lynn Matteson wrote: | Why not put the inspection ring in place during the covering job?
Lynn
That is what I did except is was more like 1/2 an inspection ring, I probably didn't word my response very well. This could also be done after the covering job if need be.
simple cover plate.
Pat Reilly
Posted: Wed Nov 04, 2009 5:13 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Lynn, Torque of installation wasn't enough to hurt the switch. It is a plastic tank. I have checked everything you mention. I'd like to get another switch and try it, but I am afraid it wouldn't work either. And, I'm tired of pulling the damn header tank.
Pat Reilly
On Wed, Nov 4, 2009 at 1:53 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote] --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Boy, that IS weird. I'm tempted to think that the torque of screwing it in somehow causes a "tweak" in the body and it won't make contact in that configuration. I'm pretty sure that your wiring is the same as mine....hot to the bulb, and ground through the switch to a good ground. The only thing I can suggest is to check for "normally open" or "normally closed", but I'm sure you've done that. The switch should "connect" when the float drops, as I'm sure you know.
Lynn Matteson
| Quote: | Lynn, Tell me more about the float switch problems you experienced. I have one in my header tank, and the damn thing won't work. I pulled it out checked it with continuty meter. It seemed to work again . I put it back in and again it doesn't work. The switch is hooked to ground to close and complete the circuit with power directly to the warning light. The light stays lit. The circuit is complete all the time. I know I haven't got the switch in upside down. It has to be a magnetic switch of some kind as the pivoting float cannot, and does not attach by wire. I think the magnet must be too weak to work when installed in the tank for some reason.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Lynn Matteson
Lynn...good story!
Travis Rayner
Mobile, AL
ADI-II Autopilot
= --> h
ber is the Annual List Fund Raiser. Click on
-= * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
ronics List Features Navigator to browse
s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Dick Maddux
Posted: Thu Nov 05, 2009 6:00 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Pat,
I too am using the low fuel warning system provided by Lowell at [url=Highwing LLC]Highwing LLC[/url]. It is a very nice unit that attaches just above the header tank on the vent line. It is light as a feather and includes a dash mounted warning light that warns when the header is not filling (giving you about 15-20 min warning to dry tank) I have had it about a year now and am glad to have it!
Dick Maddux
Fox 4
Milton,Fl
lstaley
Posted: Thu Nov 05, 2009 6:35 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Pat,
Wish I had one of those on my Kitfox5 when I my plane ran out of fuel with both sides showing 3/4 of fuel.
Little off topic but am replacing windshield and side windows. Does anyone know what thickness on the windshield and the side windows I should be using? Also what type of material should I use? Will one sheet 4x8 cover both of these?
LeRoy
Kitfox 5
Wheatland,Mo.
Lynn Matteson
Posted: Thu Nov 05, 2009 7:31 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Ok, Dorsal, I gotcha...
Lynn Matteson
On Nov 4, 2009, at 6:32 PM, Dorsal wrote:
> Lynn
N369LM |
Pat Reilly
Posted: Thu Nov 05, 2009 4:37 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Dick, Thanks for info. Hell, I have a Lowell Fitt trim tab, Lowell Fitt radiator shutters and a Lowell Fitt bush gear. Might as well make it a Lowell Fitt sweep and use his header tank fuel warning system too. I haven't flown mine yet, but that bush gfear is awesome! Lowell was apoligizing for the fairing fit up. I don't know how you could get it any closer. The fairing fit up was as close to perfect as possible.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Nov 5, 2009 at 7:21 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
[quote] Pat,
I too am using the low fuel warning system provided by Lowell at Highwing LLC. It is a very nice unit that attaches just above the header tank on the vent line. It is light as a feather and includes a dash mounted warning light that warns when the header is not filling (giving you about 15-20 min warning to dry tank) I have had it about a year now and am glad to have it!
Dick Maddux
Fox 4
Milton,Fl
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
Pat Reilly
Posted: Thu Nov 05, 2009 4:44 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Leroy, I saw a Barnstormer ad from a Staley from MO, can't remermberr 1st name, looking for an NSI engine. I gave the name and # to a friend of mine with an engine for sale. That wasn't you, was it? I made my winshield and cabin top a 2 pieceer with the cabin top tinted and the windshield out of a softer heavier thicker plastic of somekind, I would be afraid to recommend the windshield material until it proves it self. Was easy to work with, but the stressed portion at top corners has stress marks in it already.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Nov 5, 2009 at 8:32 AM, Teresa Staley <tstaley(at)centurytel.net (tstaley(at)centurytel.net)> wrote:
[quote] Pat,
LeRoy
Kitfox 5
Wheatland,Mo.
