lstaley
Posted: Thu Nov 05, 2009 7:06 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Pat,
Yes your friend called but I haven't had time yet to respond. I just learned this afternoon that the 5's windshield and the other part behind this are two pieces. Only need to replace the rear section.
Thanks for your info and response.
LeRoy
bw12345(at)sbcglobal.net Guest
Posted: Fri Nov 06, 2009 3:31 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
My sight gages also show a lot of fuel when in fact there isn't. Is there a fix to this ploblem so there can be relied on?
BOB
--- On Thu, 11/5/09, Teresa Staley <tstaley(at)centurytel.net> wrote:
Subject: Re: Re: Fuel Flow Problems, Again! (Vixen, Series-5)
Date: Thursday, November 5, 2009, 9:32 AM
Pat,
Wish I had one of those on my Kitfox5 when I my plane ran out of fuel with both sides showing 3/4 of fuel.
Little off topic but am replacing windshield and side windows. Does anyone know what thickness on the windshield and the side windows I should be using? Also what type of material should I use? Will one sheet 4x8 cover both of these?
LeRoy
Kitfox 5
Wheatland,Mo.
| [quote][b]
Fox5flyer Guest
Posted: Fri Nov 06, 2009 4:18 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Bob, many of the sight gauges on Kitfoxes have a small nylon restrictor in the bottom part that has a tiny hole in it to allow fuel through. It's purpose is to dampen large fuel level fluctuations during turbulence. If you have these, it's possible they may be plugged. Easy to check. I removed mine as I found that they weren't necessary. That was seven years ago and I haven't found any reason to replace them.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
KeysFox
Posted: Sat Nov 07, 2009 6:09 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Sent from my Verizon Wireless BlackBerry
_________________ B Jones
N154K
443-480-1023 |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sun Nov 08, 2009 5:20 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
All the fuel upgrades were completed yesterday...including remounting the engine after the Alternator Drive Coupling replacement. The mods to the fuel system seem to have taken care of the problem. I will post a few pictures as soon as I find the camera!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
Pat Reilly
Posted: Tue Nov 10, 2009 3:08 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
KFer's., I can't speak of Murle's product quality, but I would like to vouch for his customer support. He sent $600 worth of Poly Fiber covering product to me with an invoice, no deposit, prior payment or prior business transaction.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Nov 9, 2009 at 9:56 PM, Michael Gibbs <MichaelGibbs(at)cox.net (MichaelGibbs(at)cox.net)> wrote:
[quote]--> Kitfox-List message posted by: Michael Gibbs <MichaelGibbs(at)cox.net (MichaelGibbs(at)cox.net)>
Guy sez:
| Quote: | Check out Highwing LLC. They also have a sensor and have a better quality reputation than Murle.
I'm curious about this comment, Guy. Are you aware of quality issues with Murle's parts?
Mike G.
N728KF, Kitfox IV-1200 Speed====================
he Contribution link below to find out more about
lder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
-Matt Dralle, Li - The Kitfox-List Email Forum -
fox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List< - MATRONICS WEB FORUMS -
= --> h
