Jekyll
				 Posted: Mon Apr 10, 2006 1:33 pm    Post subject: Firewall penetrations |
				Looking for some insights on installing a vertical sump IO-360 on a 7A. I ordered a TMX-IO-360 and have my FWF kit. Vans had me get the O-360 FWF with several adjustments. I installed my boost pump and filter per the Vans drawing but stopped short of plumbing the feed line from the pump to the firewall because I couldn't determine where to penetrate. The Vans drawing are for horizontal sump IOs.
 My first question was whether the gascolator was used with the IO installation. A search of old threads indicates it is optional but recommended. So I guess I'll be adding that.
 Does the Vans gascolator work with the IO engines?
 The next question is where do I penetrate the FW? The IO FWF shows the penetration more to the center than does the O-360 drawing (lower right corner at the gascolator). I'm sure many builders have crossed this bridge already so I would appreciate some hints.
 I'm thinking the gascolator and FW penetration should be per the O-360 drawing, is that right?
 Any other penetration peculiarities I should expect?
 Jekyll
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
