Louie928
Joined: 15 Nov 2009 Posts: 32 Location: Mosier, OR USA
Posted: Sat Dec 05, 2009 12:34 pm Post subject: Re: I don't understand... |
Jim,
Your point about the criticality of the hole size for these AN3 bolts is important and has been bothering me in that it seems to have been largely ignored by Zenith. AC 43-13 has a paragraph on the importance of bolt fit especially in "primary connecting elements". It says, " Generally, it is permissible (to measure the hole) to use the first-letter size drill size larger than the nominal bolt diameter,...". For AN3 bolts there is no next letter size larger since size A is 0.234". So what is the maximum hole size for an AN3 bolt? AC 43-13 says if the fit is too loose to ream out to the next larger bolt size. Is that permissible here? Seems like an AN4 bolt may remove too much of the cap material, and if very many had to be used the weight would increase too much. Ream the "too big" hole and make a thin wall bushing from 6061-T6 sized for light press fit in the reamed hole and for the AN3 bolt? Maybe I'm being too anal about this and should just go ahead and bolt it together sloppy holes and all.
| stormyflight(at)yahoo.com wrote: |
<snip> Also, hole quality is critical since the bolts don't squish to fill the hole. My comment was just saying that if done right, it works just as well as a rivet and there should be no tendency to come loose (no re-torquing required). There are also some non-driven rivets that we use a lot called Hyloks which are set using wrenches. A little pricey at about $5 each, but would definitely do the job.
Jim
_________________ Louis W. Ott
601XL-B Corvair |
z601b(at)anemicaardvark.c Guest
Posted: Sat Dec 05, 2009 12:55 pm Post subject: I don't understand... |
Forgive me for barging into the middle of your conversation, but in my drill
index, the letter size drills continue on up in diameter to "Z." I would have
thought the next letter size larger would be "B."
Or do I totally misunderstand your statement?
On Saturday 05 December 2009 14:34, Louie928 wrote:
Jim,
ahead and bolt it together ! sloppy holes and all.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
bryanmmartin
Posted: Sat Dec 05, 2009 1:50 pm Post subject: I don't understand... |
The next "letter" size drill bit larger than an A3 bolt would be a #12 at 0.189". Letter drill bits start at A (0.234") and go up in size to Z (0.413"). Numbered drill bits start at #1 (0.228") and go down in size to #80 (0.0135").
Jim,
Your point about the criticality of the hole size for these AN3 bolts is important and has been bothering me in that it seems to have been largely ignored by Zenith. AC 43-13 has a paragraph on the importance of bolt fit especially in "primary connecting elements". It says, " Generally, it is permissible (to measure the hole) to use the first-letter size drill size larger than the nominal bolt diameter,...". For AN3 bolts there is no next letter size larger since size A is 0.234". So what is the maximum hole size for an AN3 bolt? AC 43-13 says if the fit is too loose to ream out to the next larger bolt size. Is that permissible here? Seems like an AN4 bolt may remove too much of the cap material, and if very many had to be used the weight would increase too much. Ream the "too big" hole and make a thin wall bushing from 6061-T6 sized for light press fit in the reamed hole and for the AN3 bolt? Maybe I'm being too anal about this and should just go ahead and bolt it together !
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
afterfxllc(at)aol.com Guest
Posted: Sat Dec 05, 2009 3:14 pm Post subject: I don't understand... |
Guys
You are making too big a deal out of this. If the hole is sloppy drill it one bolt size bigger. But everyone here has someone close that has a rivet gun so get on the RV list and see if you can find someone to help you set the rivets. After the prep is done it only takes 20 mins to re rivet the spar. What we are looking for here is the clamping force more than shear.
Jeff
Louie928
Posted: Sat Dec 05, 2009 4:12 pm Post subject: Re: I don't understand... |
I was trying to find a way to judge whether a hole diameter would be too large for a AN3 bolt. Using the AC 43-13 method doesn't exactly work because there is no letter size drill under size A. Carrying over to the same method using number drill sizes as a gauge for acceptable hole size for AN3 bolt should work. Looks like if a #11 drill slides through with clearance, then a AN4 bolt should be used.
| z601b(at)anemicaardvark.c wrote: | Forgive me for barging into the middle of your conversation, but in my drill
Jim,
Do not archive.
Jim B Belcher
A&P/IA
601XL-B Corvair |
Afterfxllc(at)aol.com Guest
Posted: Sat Dec 05, 2009 4:58 pm Post subject: I don't understand... |
A # 11 will slide thru and a # 10 should be tight.
JohnDRead(at)aol.com Guest
Posted: Sat Dec 05, 2009 8:45 pm Post subject: I don't understand... |
There is a number drill that is 0.189 dia, that would be a good fit for an AN3 bolt.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 12/5/2009 5:15:50 P.M. Mountain Standard Time, louieo(at)gorge.net writes:
| Quote: | --> Zenith601-List message posted by: "Louie928" <louieo(at)gorge.net>
| Quote: | Forgive me for barging into the middle of your conversation, but in my drill
> Jim,
Do not archive.
Jim B Belcher
A&P/IA
Louis W. Ott
601XL beginner Quick Build
http://forums.matronics.com/viewtopic.php?p=276387#276387===============================================
_nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== Use the ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
Posted: Sat Dec 05, 2009 11:10 pm Post subject: I don't understand... |
3/16 = .1875
#12 = .1890
#11 = .1910
#10 = .1935
n4546v(at)mindspring.com Guest
Posted: Sun Dec 06, 2009 8:35 am Post subject: I don't understand... |
I'm not a 601 builder, but I drill a lot of holes. I measured several AN3 bolts furnished by ZA last night. Smallest was .187 and the largest was .1885.
One way to help visualize slop is instead of diameter over, picture how much over per side. For example, if your hole is .003 oversize, that's .015 of space on each side of the bolt.
And you already know this but......don't just believe the the size drill you buy will bore the stated size. Many are poorly ground with uncentered points. And your technique makes a difference. Measure test holes, not the bits.
A guy came into my plant and asked "how can I make this bit drill oversize?" That's easy, let me sharpen it.
I am adding metric diameters to the list below. They are available for about the same money,
Randy, Las Vegas
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Dec 06, 2009 3:13 pm Post subject: Re: I don't understand... |
Just a minor correction, I'm sure you meant .0015 per side.
Dan
[quote="n4546v(at)mindspring.com"]do not archive
_________________ Scratch building XL with Corvair Engine |
Posted: Sun Dec 06, 2009 4:17 pm Post subject: I don't understand... |
Thanks Dan, right you are, .0015 it is!
Randy, Las Vegas
