occom
Posted: Thu Dec 10, 2009 2:59 am Post subject: Lead plating (was EGTs are killing me) |
I have read this many times (mostly here and Rotax list) and I'm not sure this isn't one of those oft retold myths. I understand that lead compound deposits are bad in the combustion chamber, exactly where Decalin is working to counteract it but is there any documentented photographic evidence of this "plating" occurring in the bottom of a two stroke rotax and actually causing a problem, or a failure?
Rotax doesn't mention bottom end troubles from it that I can find and I can imagine a couple of small benefits. Colour me skeptical on this one, but I'd love to see evidence of it.
dave
Posted: Thu Dec 10, 2009 2:18 pm Post subject: Re: Lead plating (was EGTs are killing me) |
Simple solution is to use reg grade gas.
Our 582s and 912 ul do not need over 87 octane.
Some just wanna be one of the boys buying avgas at the airport ?
No idea But I do operate from my own strip and I have supply her already. In Summer I buy at marinas and I have bought at airports before from the maintenance guys that use reg gas for lawnmowers, vehicles etc. I have used AVgas a few times but it is like 30 % or more expensive as well.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Roger Lee
Posted: Thu Dec 10, 2009 2:27 pm Post subject: Re: Lead plating (was EGTs are killing me) |
You are way ahead of the game to get away from 100LL in a 2 stroke. Regular auto gas is much better. The lead over time is a killer. Yes it works, but you'll have more maint. issues later as you get more time on the engine. This question is always ask in Rotax maint. schools and Rotax would rather see auto gas, too.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
dave
Posted: Thu Dec 10, 2009 2:33 pm Post subject: Re: Lead plating (was EGTs are killing me) |
Thanks Roger.
Hey what is your thoughts on NKG from Rotax verus the auto parts store plugs?
I got 100 to 150 hours out of mine in 582s with oil injection
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Thu Dec 10, 2009 5:25 pm Post subject: Re: Lead plating (was EGTs are killing me) |
| dave wrote: | Thanks Roger.
I got 100 to 150 hours out of mine in 582s with oil injection |
I get NGKs from the auto parts store.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Dick Maddux
Posted: Fri Dec 11, 2009 4:41 am Post subject: Lead plating (was EGTs are killing me) |
Dave,
I read an article, a while back, on a British Rotax 912 site that did show pictures of the lead accumulation all over the rods and inside the gearbox of a 912 as a result of using avgas.Unfortunately, I can't relocate that site. It was a terrific article on the care and feeding of the 912 written by a man named Conrad I believe. The pictures were great. It also had a great picture of damage to the valve spring area caused by a collapsed lifter as a result of air intrusion into the oil system. It hammered home to me the value of doing the lifter check as part of the purge if you have to break open the oil system.
Dick Maddux
Fox 4
Rotax 912
Milton,Fl
Roger Lee
Posted: Fri Dec 11, 2009 4:58 am Post subject: Re: Lead plating (was EGTs are killing me) |
Hi Dave,
If the NGK numbers are the same then it's the same plug. i.e. DCPR8E for a Rotax 912ULS is the same plug regardless if it comes from Rotax, a motorcycle shop, a marine shop or an auto parts store. For the longest time I was getting my NGK plugs from "Marine Discount" on the web. They used to be a lot cheaper. I usually by 32 plugs at a time.
Tucson, Az.
Cell 520-349-7056 |
dave
Posted: Fri Dec 11, 2009 5:02 am Post subject: Re: Lead plating (was EGTs are killing me) |
Roger ,
I was referring to the on going debate of the NGK B8Es or BR8ES
Rotax supplied are solid tipped and gapped .018
Auto parts one have alum tip Screw ons plus they gapped at .03 to 035
The Solid tipped outlast the Alum tipped ones by 4 to 6 times I find.
Dave
akflyer
Paul A. Franz, P.E.
Posted: Fri Dec 11, 2009 12:37 pm Post subject: Lead plating (was EGTs are killing me) |
On Fri, December 11, 2009 4:38 am, Catz631(at)aol.com wrote:
| Quote: | Dave,
site.
Perhaps this article?
<http://www.conairsports.co.uk/downloads/912%20maintenance%20article%20-%20inc%20carb%20bal.pdf>
Or as a TinyURL:
<http://preview.tinyurl.com/yda53ld>
Those are the first ever photos I've seen of any kind of deposits in the relatively
cooler bottom end. After 1000 hours, still not much there compared to the deposits on
the valves.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
"The powers delegated by the proposed Constitution to the federal
government are few and defined. Those which are to remain in the
State governments are numerous and indefinite."
-- James Madison, Federalist No. 45
"I think we have more machinery of government than is necessary, too
many parasites living on the labor of the industrious."
-- Thomas Jefferson
Norman Mattoon Thomas (November 20, 1884 to December 19, 1968) was a
leading American socialist, pacifist, and six-time presidential
candidate for the Socialist Party of America. The Socialist Party
candidate for President of the U.S., Norman Thomas, said this in a
1944 speech:
"The American people will never knowingly adopt socialism. But,
under the name of "liberalism," they will adopt every fragment of
the socialist program, until one day America will be a socialist
nation, without knowing how it happened!"
He went on to say: "I no longer need to run as a Presidential
Candidate for the Socialist Party. The Democrat Party has adopted
our platform."
"The problem with socialism is that you eventually run out of other people's money."
~~Margaret Thatcher~~
"Liberty must at all hazards be supported. We have a right to it,
derived from our Maker. But if we had not, our fathers have earned
and bought it for us, at the expense of their ease, their estates,
their pleasure, and their blood."
-- John Adams, A Dissertation on the Canon and Feudal Law, 1765
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Dick Maddux
Posted: Sat Dec 12, 2009 7:53 am Post subject: Lead plating (was EGTs are killing me) |
Paul,
That was the excellent article is was referring to
Dick Maddux
Fox 4
912UL
Milton,Fl
Rich L
Posted: Sat Dec 12, 2009 9:18 am Post subject: Re: Lead plating (was EGTs are killing me) |
Please tell me I dont need screw on caps on the dcpr8e plugs on a 912uls. I have always just used the threads and they seem to fit tight. I tried to get one of my plug wires on a plug with the cap on and it didnt fit!!!!!!!
Roger Lee
Posted: Sat Dec 12, 2009 5:17 pm Post subject: Re: Lead plating (was EGTs are killing me) |
Hi Rich,
The 912 uses just the thread end and no cap for its plugs.
The DCPR8E plugs come with caps on, but you just unscrew them and bare the threads. There is a DCPR8E plug out there that the caps don't come off. A friend of mine accidentally bought some once at a motorcycle shop. I don't know exactly the difference on these plugs either, but I'm sure there is something different.
Hi Dave,
I would stick with what Rotax recommends. You can't go wrong there. There is a reason Rotax wanted that type of plug. I do not know exactly why, but I'm sure they didn't just pull it out of a hat. You can buy NGK's of the type you need at other locations other than Rotax. NGK made two different plugs for a reason and if they were the same then why didn't they just make the one?
Just thinking out loud here:
Somethings Rotax are certainly more costly, but some items are costing only pennies for the number of hours people fly yet they skimp on a certain part. Kind of like not changing oil or plugs when your supposed to. The owners save pennies and then wonder down the line why something happened. Must have been Rotax's fault....
If you read about Rotax engine failures the largest majority by far is owner caused because some owners want to be experimenters and just don't see why Rotax would do something a certain way or think one item is interchangeable with another. If you want to do that sort of experimentation then I think it is ok, just take the consequences and don't point fingers or complain. If I know positively an item is identical I might use it, but if I'm not 110% sure I stick with the Rotax recommendation.
I just try to keep all my clients in the air and not cause any dead sticks or (MIF'S) failures.
MIF: mecahnic induced failure
I'm sure everyone here has a personal view on this type of issue.
Tucson, Az.
Cell 520-349-7056
dave
Posted: Sun Dec 13, 2009 3:15 am Post subject: Re: Lead plating (was EGTs are killing me) |
Roger,
Very well said. And heck I am not happy with some of the Rotax prices but I will say that Rotax parts do seem to perform well overall.
The rebuilt cranks always come back for a new rotax crank,
the cheap plugs get swapped out every 10 to 20 hours -- the rest of us go 100 to 150 hours.
See how long a sno mo 40 $ piston last running at 6000 rpm but the Rotax ones cost 240 $ but seem to make it.
etc etc etc
same as oils, I have just under 10 regulars at my strip with Rotax 2 strokes and in 10,000 hours of flying in last 10 years no one uses pennzoil or synthetics but we all use castrol super 2 stroke, Bombardier oil or Shell Advance. We all use Regular grade gas- with (ethanol in the last 3 years) And I am happy to say that no Forced approaches from engine failures have happened with us. We have had 2 prop failures only and now most guys use safety cables.
btw - Nothing wrong with pennzoil it just not readily availble to us .
Dave
