occom
Posted: Fri Dec 11, 2009 2:27 am Post subject: Lead plating (was EGTs are killing me) |
I understand all that but after hearing of lead plating destroying bottom
ends a few times I just wanted to know if this isn't one of those stories
everyone hears and assumes to be true. It sounds a little unlikely to me and
I was hoping someone could point to a definitive source of evidence.
Lion8
Posted: Fri Dec 11, 2009 6:15 am Post subject: Lead plating (was EGTs are killing me) |
I use NGK's, however be certain that the plug caps do not screw on or off. Make certain also that these caps are of a bronze color and not aluminum. If you use auto plugs with screw on aluminum end caps, they WILL arc inside the cups and burn the inside of the cups and blacken the inside. You will eventually lose electrical contact with these type plugs. -Lion8
_________________ Tom (Lion8), Currently Flying an LSA Trike
Rebuilding a Kitfox IV Speedster
Southern New Jersey |
dave
Posted: Sat Dec 12, 2009 4:21 am Post subject: Re: Lead plating (was EGTs are killing me) |
| Lion8 wrote: | I use NGK's, however be certain that the plug caps do not screw on or off. Make certain also that these caps are of a bronze color and not aluminum. If you use auto plugs with screw on aluminum end caps, they WILL arc inside the cups and burn the inside of the cups and blacken the inside. You will eventually lose electrical contact with these type plugs. -Lion8
you mean like this and wearing a flat side on the alum tip ?
http://www.cfisher.com/ngk/
http://www.cfisher.com/ngk/tipsblack.htm
Why plugs are not the same
http://www.cfisher.com/ngk/ngkgap.htm
The ground electrode it longer and won't adjust the same.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 12, 2009 11:06 am Post subject: Lead plating (was EGTs are killing me) |
Rich,
You are exactly right. We are talking apples and oranges here. I bought
some plugs once that didn't have the removable screw caps. Unusable in the
912. I always had to remove the caps to fit under the wire connectors.
Lowell Fitt
Cameron Park, CA
Second Build Model IV-1200 R-912 UL
Waiting for fabric for the final covering project and working on a major
related project.
Rich L
Posted: Sat Dec 12, 2009 7:46 pm Post subject: Re: Lead plating (was EGTs are killing me) |
Thanks Roger
I thought I was OK but when I went to the Rotax Illistrated Parts Cat., it showed the plugs with the caps on.
