jim-bean(at)att.net Guest
Posted: Sun Jan 03, 2010 1:43 pm Post subject: AeroElectric-List: Adding an antenna to improve on the groun |
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Sun Jan 03, 2010 1:56 pm Post subject: AeroElectric-List: Adding an antenna to improve on the groun |
Problem: On the ground at KAWO (non-towered airport) I can't get Seattle
Center (and my IFR clearance) because of my RV-8 belly-mounted comm antenna. (In a high wing trainer, this is not a problem.) I have a
bubble canopy--can I add an antenna within my canopy to the existing belly
antenna with
a
combiner/splitter to my comm receiver and achieve better reception on the
ground without degrading my in the air reception/transmission? Ground plane problem with this setup? I can't easily place another antenna on
the top
fuselage. Suggestions?
Don Schmiesing
I have an antenna on my RV-8 slider which works pretty well. It is on the number
2 comm.I riveted an aluminum sheet to the aft end of the slider for a ground plane. The
cablegoes to the front of the slider. The front of the slider is about as far in
front of theshoulder harness bracket when closed as it is in back of it when open, so a loop
from the
slider to the bracket works well. The whip goes through the canopy with a rubber
grommet.
I have some pictures but they won't get through the list.
Jim Bean
martin(at)gbonline.com Guest
Posted: Tue Jan 05, 2010 3:48 pm Post subject: AeroElectric-List: Adding an antenna to improve on the groun |
Don et all,
Ten years ago when I finished my RV8,,I experienced similar problems. After
tryiing various different fixes, I finally gave up and got out my wallet
and bought a Dorne & Margolin high quality antenna and mounted it on the
bottom of my RV8. Well I could not believe the difference in performance
both on the ground and in the air. In the air I can transmit and receive
more than 100 miles clearly. Also the drag co-efficient is less than 1
knot.
Good luck.
Dick Martin
RV8 N233M
the fast one
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Tue Jan 05, 2010 4:22 pm Post subject: AeroElectric-List: Adding an antenna to improve on the groun |
Dick,
Are you referring to the Dorne & Margolin vhf com antenna P/N DM C70-1 a
straight stick antenna?
Thanks ... Jerry
Don et all,
After tryiing various different fixes, I finally gave up and got out my
wallet and bought a Dorne & Margolin high quality antenna and mounted it
on the bottom of my RV8. Well I could not believe the difference in
performance both on the ground and in the air. In the air I can transmit
and receive more than 100 miles clearly. Also the drag co-efficient is
less than 1 knot.
Good luck.
Dick Martin
RV8 N233M
the fast one
