Posted: Tue Dec 15, 2009 10:28 pm Post subject: Battery Equalizers |
At 10:12 AM 12/14/2009, you wrote:
Thanks Bob, in your response, you indicated a lack of familiarity
with battery equalizers and their functioning:
"I'd not encountered this style of "equalizer" before . . . A study
of it's ratings suggests that the device contains a switchmode power
supply designed for charging 12v batteries from a 28v source."
Does anyone else on the list have any experience with these
units? The advertising and claims suggest they're designed to extend
the lives of batteries wired in series by shuttling power between the
two batteries (bi-directionally) to ensure they always have the same
voltage. Folks use these extensively in electric vehicles and for
maintaining long strings of batteries for storing energy derived from
solar power in stand-alone systems. Anyone with some experience to
share with the list?
The term "battery equalizer" is a really broad brush
with which to draw a schematic or write a description
of how it functions.
The folks doing development work on Li-Ion aircraft
batteries have already described a host of "electronic
enhancements" to make sure that each one of the relatively
small bundles of energetic chemistry are not mistreated to
destruction . . . or worse yet, catastrophic failure.
This is a worry for the electrically enhanced vehicle
business too.
Equalization COULD be nothing more than precision
shunt regulators that prevent voltage in any single
cell from rising above some not-to-exceed levels.
It COULD be an array of such devices individually
commanded from some smart device like a micro-controller.
The "equalizer" we were discussing seems to be a single
precision power supply designed to simply offset the
effects of loading the lower half of a two battery
string. In this case, each string has twelve cells
divided into two sections . . . equalization philosophy
is therefor coarser.
The ideal "equalizer" for a pair of six-cell batteries
array might be a pair of switch-mode chargers feeding
each battery independently . . . each capable of
sourcing the highest anticipated load on each battery.
I'm not trying to be obtuse but until one identifies
and understands exactly how any particular "equalizer"
is designed to function, and matches the knowledge
with design goals for the system, sharing of experiences
may not be all that useful.
Exactly how would you like to use two 12v batteries
in a 28v system?
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
dfritzj(at)yahoo.com Guest
Posted: Wed Dec 16, 2009 10:39 pm Post subject: Battery Equalizers |
Bob,
The planned use for the battery equalizer is to allow the charge state of the two batteries in a 24V system to equalize after one battery is used (via the center tap) to run the 12V hydraulic pump. My thought is that the battery will easily supply the 20A load for 30 seconds or so to required to raise the gear, after which the equalizer will act to direct energy to it in order to bring its charge state up to equal that of the other battery. The particular unit I've chosen is called PowerCheq and appears to be designed for just such an application. It's produced by a company called Power Designers, here's a link to the manual for the unit:
http://www.evsource.com/datasheets/powercheq/powercheq_operations_manual.pdf
and here's a link to a white paper on its design and testing:
http://www.fleetcareequipment.com/files/phatfile/PowerCheqPaper_MotivePower.pdf
I'm not a Double-E, so I welcome comment from you and others out there regarding the usefulness of such a beast.
Dan
bgray(at)glasair.org Guest
Posted: Wed Dec 16, 2009 11:10 pm Post subject: Battery Equalizers |
I’ve come into this thread on the back end, but why not just change the hydraulic powerpac to 24V?
Bruce
www.Glasair.org
Posted: Sun Dec 27, 2009 11:01 am Post subject: Battery Equalizers |
I'm not a Double-E, so I welcome comment from you and others out there regarding the usefulness of such a beast. |
Dan,
I've been pondering your request. I'm having
trouble wrapping my head around a design task
that increases weight, complexity and cost
of ownership to side-step an ordinary procurement
task to swap 14v equipment out in favor of 28v
equipment.
I suspect there are few if any folk who have
implemented the equalized split battery architecture
to achieve a quasi-dual voltage system. My only
experience with a tapped battery scheme involved
a pusher design that needed electric augmentation
of cooling on the ground. The builder ran a pair
of 14v fans off the top battery . . . another
pair on the bottom battery.
Unfortunately, the airplane crashed before
the wisdom of the experimental architecture could
be evaluated.
You're a the leading edge of the investigation
for what you've proposed. Were it my airplane, I
would swap the parts out and stay with an all
28v system.
Bob . . . [quote][b]
Posted: Tue Dec 29, 2009 3:53 pm Post subject: Battery Equalizers |
Bob et al,
I appreciate the architecture advice and will take it into consideration. Unfortunately, I'm on a work-driven building hiatus that'll probably keep me from doing any work on the Velocity for at least a couple years, so I won't be able to give any solid feedback on the usefulness of a battery equalizer in this setup for a while. In the meantime, I can do a quick trade study to look at the cost and parts count between the multiple bus setup and replacing the hydraulic power pack and associated control circuits.
I don't know if you looked at the link to the white paper in my previous post or not, but in it the author shows significant experimental improvement in battery life using an equalizer in a series string of batteries. As I need a 24V system in my aircraft anyway and will be using two batteries in series, it makes sense to me to take advantage of these improvements if in fact the claims are true. Have you (or anyone on the list) looked at the white paper and/or have any knowledge or experience in the use and efficacy of these equalizers (regardless of whether I keep my multi-bus setup or not)?
Dan
Posted: Tue Jan 05, 2010 3:30 pm Post subject: Battery Equalizers |
At 05:26 PM 12/29/2009, you wrote:
Bob et al,
Dan,
The IDEAL equalizer will, no doubt, make the 12v tap
on a 24v battery look transparent to the rest of
the system . . . including batteries.
By "ideal" we mean equalizers that are about as
capable as the batteries themselves . . . very
low impedance and capable of carrying what ever
loads are imposed at the tap.
As soon as you choose an equalizer smaller than
anticipated loads, then the lower battery MUST
make up the difference. Yes, it's just for a short
time and the too-small equalizer will fix things
back up once the loads go away. Nonetheless, this
means that the bottom half of the battery is
treated differently than the top half.
Terrible thing to do? Don't know. I have no experience
with it in the distinctly aviation environment
where batteries are protected against deep cycle
and monitored for minimum capacity. How does one
integrate a less than idea equalizer into the
battery maintenance protocols?
My gut feeling is that you'll be happier in the long
run with a conversion of your 14v hardware to 28v
hardware and forget the equalizer. But should you
choose to conduct this experiment, you will become
the go-to guy for guidance on how good an idea it
is.
Posted: Sat Jan 09, 2010 2:05 pm Post subject: Battery Equalizers |
Thanks Bob,As I mentioned, it'll be a while before I can get back to work on the Velocity, but when I do, I'll report whether I decide to maintain the center-tap scheme or not and how well it works if I do.
Dan
Posted: Sat Jan 09, 2010 5:17 pm Post subject: Battery Equalizers |
Very good! Hope your project doesn't
have to languish too long!
