cjay
Posted: Sat Jan 09, 2010 10:46 am Post subject: engine break in period |
Thinking about my first flight (hopefully not in the too distant future) I came across an old reprint from an AOPA magazine about steps for the engine break in period (for any new, rebuilt, or overhauled engine).
A couple of the highlights:
1. non-compounded oils should be used during the break-in period. Stay with it for the first 50 hours.
2. Use full rated power and RPM as much as possible and avoid ground running time to a minimum.
It goes into a description of the importance of high mean effective pressure (BMEP) and both steps above helps to properly seat the cylinder wall and piston rings.
I guess my question is how can you achieve (2) when you are just starting out and have to do quite a bit of ground runs and slow flights around the pattern?
cjay
Deems Davis
Posted: Sat Jan 09, 2010 11:07 am Post subject: engine break in period |
Good to see you back CJ!
A. minimize the ground run time. Prior to 1st flight. 1st engine start
5-10 minutes, Brake/Taxi check 5-10 minutes. Keep other engine running
to minimum. You can't eliminate it, just don't over do it with a lot of
preflight engine runs at low MP settings.
B. Notify tower (if applicable) of 1st flight and ask for orbits above
the airfield and above pattern alt. If airport is controlled most
controllers will accommodate. I operate out one of the busiest GA
airports in the US , and this was not problem. you can do this at full
power and high RPM (2500). The key is to keep the MP pressure up.
Deems Davis
N519PJ
www.deemsrv10.com
cjay wrote:
cjay
http://forums.matronics.com/viewtopic.php?p 80820#280820
luis(at)cristabelle.net Guest
Posted: Sat Jan 09, 2010 12:46 pm Post subject: engine break in period |
Full power? What speed would that give you? 170 in circles. Must
feel like a NASCAR track constanly banking. I'd rather do circles
above the airport then looking for a place to land off airport. How
long is the break in period?
Sent from my iPod
On Jan 9, 2010, at 2:04 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
start 5-10 minutes, Brake/Taxi check 5-10 minutes. Keep other engine
running to minimum. You can't eliminate it, just don't over do it
with a lot of preflight engine runs at low MP settings.
above the airfield and above pattern alt. If airport is controlled
most controllers will accommodate. I operate out one of the busiest
GA airports in the US , and this was not problem. you can do this at
full power and high RPM (2500). The key is to keep the MP pressure up.
Deems Davis
N519PJ
www.deemsrv10.com
> overhauled engine).
> cjay
speckter(at)comcast.net Guest
Posted: Sat Jan 09, 2010 12:53 pm Post subject: engine break in period |
Another option is to put a hood on your engine like the engine overhaul
places do. I barrowed one from my local engine builder. Then I did a full
power ground run with the plane tied to a tree/truck/heavy object for 3 or
more hours until the CHT's start to drop. This greatly enhances the break
in.
Gary Specketer
Kelly McMullen
Posted: Sat Jan 09, 2010 12:59 pm Post subject: engine break in period |
The ideal would be to start out with a high time IO-540 to do all of
your phase one work. Then after the first 6-12 months of flying, pull
the engine and overhaul/exchange for a fresh engine.
If your engine hasn't been broken in, ideally you don't do taxi tests,
just one ground run of a minute or two to check for leaks. Or you pay
your engine builder to run the engine 4-5 hours on their test stand to
break it in. If you do taxi tests and such with a fresh/new engine you
risk glazing the cylinder walls making break-in difficult to
impossible. You make get lucky and break in okay inspite of your
ground runs. Key part is don't let cylinders get very hot, and allow
full cool down before any subsequent run.
On Sat, Jan 9, 2010 at 11:46 AM, cjay <cgfinney(at)yahoo.com> wrote:
= --> http://forums.matronics.com
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sat Jan 09, 2010 1:06 pm Post subject: engine break in period |
Here's what Lycoming recommends
http://www.lycoming.textron.com/support/publications/service-instructions/pdfs/SI1427B.pdf
I just grabbed this off the net but I know Eci has breakin procedures as
well.
Pascal
Sent: Saturday, January 09, 2010 10:46 AM
Subject: engine break in period
pattern?
cjay
dlm46007(at)cox.net Guest
Posted: Sat Jan 09, 2010 2:04 pm Post subject: engine break in period |
For breakin I did 1.3 hours over the airport at about 24/2400; the best I
could do without running into the Class B and stay near the airport for an
immediate landing. I was operating at 3500 MSL above a TPA of 2500 MSL and
below a class B 4000 MSL. Most of the remainder of the test time was cross
country at 23/2250 at about 12 GPH. CHTs initially were 360-430F and
gradually reduced to about 360F where they went just below 360F or the top
of he green for my definition. I spent about 20+ hours doing points A B C A
with a refuel at C. The current oil consumption on the new certified
Lycoming from Vans is 1 quart every 10 -15 hours. I use a combination of
Phillips XC 20-50 and 25-65.
cjay
Posted: Sat Jan 09, 2010 2:14 pm Post subject: Re: engine break in period |
| speckter(at)comcast.net wrote: | Another option is to put a hood on your engine like the engine overhaul
in.
Gary Specketer
I'm not sure what an engine hood is, but I was thinking about constructing a simple sheet metal scoop (to simulate the upper cowl) held in place with bungee cords so I don't have to hassle with taking the cowling on and off. But I think this will only be good for the ground run up suggested in the lycoming service letter that Pascal sent.
For the flight test I'll have to follow Deems recommendation but I'm doubtful the tower will give the flexibility since I'm in the Washington ADIZ.
cjay
Posted: Sat Jan 09, 2010 2:45 pm Post subject: engine break in period |
Try calling the tower ahead of time. You know, like a week or so or
today. Give them a heads up and ask for a recomendation if they can't
acomodate yours.
Sent from my iPod
On Jan 9, 2010, at 5:14 PM, "cjay" <cgfinney(at)yahoo.com> wrote:
> overhaul
> did a full
> for 3 or
> the break
> in.
> Gary Specketer
Pascal sent.
Washington ADIZ.
cjay
http://forums.matronics.com/viewtopic.php?p 80845#280845
Posted: Sat Jan 09, 2010 3:54 pm Post subject: engine break in period |
I've missed the step where you do a lot of ground runs and
slow flight in the pattern!
My recommendation is to do one high speed run down the
runway, testing control effectiveness, taxi back, put the
pedal to the metal and go. If you really need to go slow
and taxi a lot .... just minimize it. It'll only take a
little longer to really break in.
If you had an original design that's never flown before,
then testing ground handling is critical and you want to do
that, but the -10 seems to be pretty straight forward
without surprises.
If you're a low time pilot, find an experienced one for the
first flight. Why take a chance on hurting your new baby???
If you want to stay close to the airport (good thing for the
first hour), go high overhead and make big circles,
recording whatever is on your test card. You do have a test
card, don't you???
Linn
Oh yeah .... if you get airborne on the high speed run ....
easy to do .... then just go. I'm not a fan of trying to
get the airplane back on the ground until y9our airspeed and
attitude are under control. MHO, YMMV.
cjay wrote:
cjay
ricksked(at)cox.net Guest
Posted: Sat Jan 09, 2010 6:42 pm Post subject: engine break in period |
DJ .....did you move to the east coast??? Darn I would have tried to miss the ADIZ......you can't even "fall" through that can ya?? How's the 8 doin? No ground loops happening anymore I hope.
Rick
Posted: Sat Jan 09, 2010 7:43 pm Post subject: engine break in period |
Ouch! Hard to believe they will let you do the Phase 1 in that airspace. The
requirement as I know it is that it needs to be over a none congested (on
the ground) area. I need to drive near 1 hour to go to the airport that
qualifies as I am in the Los Angeles area and it sure is congested around
here.
On a separate note- but the same topic my engine builder ran the engine for
1.7 hours- it sure isn't a breakin but I will try to do my flight early
(colder) and do the minimal necessary (read to assure I feel confortable)
with the taxi test etc.. I know Deems had issue in Arizona with an extended
wait in heat to get going and that resulted in issues for him, so I'm am
taking a lesson from Deems and will try to avoid warmer weather as much as
possible, which at the pace I'm going at we might get past the global
warming and enter the ice age again so it wont be an issue anyway.
Pascal
Sent: Saturday, January 09, 2010 2:14 PM
Subject: Re: engine break in period
> full
> or
> break
> in.
> Gary Specketer
ADIZ.
cjay
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
Posted: Sun Jan 10, 2010 9:35 am Post subject: engine break in period |
When I ordered the IO-390 for my RV-8 from Aero Sport, I had them extend bench run-in to about 11.5 hours. Cost about $1000 extra. But, the engine is now well past the most critical break-in phases. I plan to use mineral oil and high power settings for the first 50 flight hours, but proper break-in should be much less of a worry.
$.02
RV-8 #82880 N998RV
http://www.mattsrv8.com
Finishing Up...
At 10:46 AM 1/9/2010 Saturday, you wrote:
cjay
_________________ Matt Dralle
cjay
Posted: Sun Jan 10, 2010 6:00 pm Post subject: Re: engine break in period |
Matt,
That's all well and good, but I have an overhauled that is untested to date and integrated in an untested airframe, which is not the ideal flight test situation. I'm wondering why I can't run it on the ground full power for a couple hours myself? As long as I can maintain good pressure cooling (from the cowl or makeshift cooling scoop) and watch the oil temp and CHT's closely. Anyone have any suggestions how to tie the airframe down during for this type of run-up?
cjay
| Matt Dralle wrote: | When I ordered the IO-390 for my RV-8 from Aero Sport, I had them extend bench run-in to about 11.5 hours. Cost about $1000 extra. But, the engine is now well past the most critical break-in phases. I plan to use mineral oil and high power settings for the first 50 flight hours, but proper break-in should be much less of a worry.
cjay
Posted: Sun Jan 10, 2010 6:15 pm Post subject: engine break in period |
cjay wrote:
Matt,
But it's the most common.
| Quote: | I'm wondering why I can't run it on the ground full power
This is the problematic part .... you just can't get enough
air through the engine running at high power on the ground.
Anyone
| Quote: | have any suggestions how to tie the airframe down during
If you're bound and determined ..... I'd tie a bridle to the
steps and around something that won't move.
I really hope you decide to just fly it like most do.
Linn
cjay
> of a worry.
>> hours.
>> rings.
>> cjay
>> 80820#280820
http://forums.matronics.com/viewtopic.php?p 80967#280967
jump2(at)sbcglobal.net Guest
Posted: Sun Jan 10, 2010 6:56 pm Post subject: engine break in period |
How about sending it to one of the good engine ohvers and let them put it in a test cell. It'll cost you some, but now would be better then latter and have to replace your cylinders. Lycoming has a process of testing or running a new engine, You would do good to read those before you do anything.
ECI, Continental, RAM they all have a break-in program that you can get ahold of just by asking them or go on line. Or the back of your engine ovh/ maintenace manual.
And I can say they work better then running you engine on the ground for long period of time.
Patrick Thyssen
my2 cents from experience.
Date: Sunday, January 10, 2010, 8:00 PM
--> RV10-List message posted by: "cjay" <[url=/mc/compose?to=cgfinney(at)yahoo.com]cgfinney(at)yahoo.com[/url]>
Matt,
cjay
Matt Dralle wrote:
| Quote: | When I ordered the IO-390 for my RV-8 from Aero Sport, I had them extend bench run-in to about 11.5 hours. Cost about $1000 extra. But, the engine is now well past the most critical break-in phases. I plan to use mineral oil and high power settings for the first 50 flight hours, but proper break-in should be much less of a worry.
> cjay
http://forums.matronics.com/viewtopic.php?p=280967#280967<= - The RV10-List tp://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.mank you for your generous nbsp; -Matt Dralle, List Admin. [quote][b]
Posted: Sun Jan 10, 2010 7:41 pm Post subject: engine break in period |
untested airframe,
now that's concerning, breakin is the least of your issues if you don't even
know if the engine runs.. or am I misunderstanding the "untested" piece.. if
you mean experimental, it's tested, heck I have a Eci in a overhaouled
engine I know it was tested for 1.5 hours and everything was signed off as
being safe, as a minimum make sure the engine is tested.
As I mentioned before follow the Lycoming steps, 100's have gone before us
without an issue.
Sent: Sunday, January 10, 2010 6:00 PM
Matt,
cjay
> > engine).
> > around the pattern?
> > cjay
> > Read this topic online here:
Bob Turner
Posted: Mon Jan 11, 2010 12:20 pm Post subject: Re: engine break in period |
AS others have noted, when on the ground even a CS prop tends to be stalled over the inboard section, and provides very little cooling airflow into the cowl. Extended high power ground runs are generally a poor idea.
However, a "bad break in" is not completely catastrophic financially (assuming you didn't over heat anything). You'd have to pull all the cylinders and re-hone them, to break the glaze; then start again.
I think a lot of engine people would agree that the 50 hours called for by Lycoming is wildly conservative (but not harmful). For steel cylinders most of the break-in happens in the first few hours, and if it doesn't the cylinders most likely are glazed over, and another 40 hours is unlikely to help.
_________________ Bob Turner
RV-10 QB |
