		Roger Lee
				 Posted: Mon Jan 18, 2010 3:21 pm    Post subject: oozing valve covers |
				Hi Guys,
 I'm doing a little survey. How many of you with a 912 ul, uls or 914 have one or more valve covers that ooze oil? Not necessarily a drip, but a little oozing so when you wipe the bottom of the cover it leaves oil on your finger. You may not even see it at times or if you have a cowling the high speed air coming through the cowling just makes a little mess on the belly of the plane. If you can let me know this info it is going to Rotax.
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		lgold(at)quantum-associat Guest
				 Posted: Mon Jan 18, 2010 4:55 pm    Post subject: oozing valve covers |
				Roger,
 I have one valve cover on my 912ULS that leaks a little oil.
 Occasionally a drop hits the muffler and we smell it in the cockpit.
 Les
		kevann(at)gotsky.com Guest
				 Posted: Mon Jan 18, 2010 6:56 pm    Post subject: oozing valve covers |
				I asked about this at a Rotax service class I attended in Vernon, B.C.
 They said they have a slab of glass that they will use as a flat surface to
 lay a piece of fine abrasive paper on and sand the mating surface of the
 valve cover.
 I have yet to try it.
 Kevin
		Roger Lee
				 Posted: Mon Jan 18, 2010 8:16 pm    Post subject: Re: oozing valve covers |
				I have been doing the sanding. Use a piece of 220 grit. Lay the cover flat and as you sand rotate it. It works some times and sometimes not at all. They now recommend 105 in/lbs for valve covers verses the old 90 in/lbs and instead of a dry "O" ring you can use some Loctite 518 or even some Loctite 5910. You don't need much.
Tucson, Az.
Cell 520-349-7056 |
		Dick Maddux
				 Posted: Tue Jan 19, 2010 5:02 am    Post subject: oozing valve covers |
				Roger,
   I have the oozing on my 912UL. Like you said, it is not much, but it is there and I wipe it down whenever I have the cowl open. I never thought much about it as my prior engines were Lyc/Cont which is kind of like a Harley and that generally came with the territory.
                                          Dick Maddux
                                          Kitfox 4
                                          Milton,Fl
		Thom Riddle
				 Posted: Tue Jan 19, 2010 5:12 am    Post subject: Re: oozing valve covers |
				Of the three airplanes I've owned with 912UL engines and the many I've worked on, never once had the oil ooze problem you asked about.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		rampil
				 Posted: Tue Jan 19, 2010 5:54 am    Post subject: Re: oozing valve covers |
				I have opened my 912 valve covers a few times and I have not yet
 had and leak or seepage.
 On the other hand, I do have a small ooze from the front of my
 gear box, just enough that I need to clean my windscreen every
 4-5 hours
		Ollie Washburn
  Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
				 Posted: Tue Jan 19, 2010 6:32 am    Post subject: oozing valve covers |
				Yes, all 4 of mine ooze oil. I put in all new O rings at Rotax's hefty price but they still leaked. Haven't tried the sandpaper route yet. 600+ hrs on the engine.Ollie   Central FL
  On Mon, Jan 18, 2010 at 6:21 PM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
 [quote] --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
  Hi Guys,
  Roger Lee
  Tucson, Az.
  Light Sport Repairman - Maintenance Rated
  Rotax Repair Center
  520-574-1080
 http://forums.matronics.com/viewtopic.php?p=282149#282149
  -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
  le, List Admin.
  _________________ Ollie RV6-A & Rans S7S
  Central FL |
		lucien
  Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
				 Posted: Tue Jan 19, 2010 7:06 am    Post subject: Re: oozing valve covers |
				Don't mean to jump in, but want to ask: Back in the bad old days when I lived under the hoods of my cars, I always took leaking valve covers to indicate possible warping of the heads themselves rather than the covers (as long as the hold-down bolts weren't being overtightened that is). Especially on my air-cooled motorcycles, this was the case more often than not.
 I'd be curious to know if in the cases where the covers are starting to leak if any flatness measurements are being taken on the heads as well to see if this might be the cause?
 Fortunately, my 912 is still leak-free at about 380 hours. But of course, I'm still on pins and needles waiting for the day when something starts dribbling out somewhere...... and how much that'll cost me......
 LS
  _________________ LS
Titan II SS |
		Roger Lee
				 Posted: Tue Jan 19, 2010 8:05 am    Post subject: Re: oozing valve covers |
				These oozing issues seem to be popping up when you get some hours on the plane. If you try the sanding method you will see the uneven surface of the valve cover. Once you make a few strokes you will see shiny spots where the sandpaper has done its job, but you will also see some dull spots and these are low spots on the cover casting. Sand until the entire mating surface is shiny. It doesn't take a number of strokes. This isn't a sure fire fix either. We are trying a few sealants to see which works well. Loctite 574 and 5910 show a lot of promise. I'll keep you posted. I am trying to get a better handle on how far reaching the oozing is on the valve covers and we are trying to make sure Rotax stays informed..
Tucson, Az.
Cell 520-349-7056 |
		lucien
				 Posted: Tue Jan 19, 2010 8:40 am    Post subject: Re: oozing valve covers |
				 	  | Roger Lee wrote: | 	 		  | These oozing issues seem to be popping up when you get some hours on the plane. If you try the sanding method you will see the uneven surface of the valve cover. Once you make a few strokes you will see shiny spots where the sandpaper has done its job, but you will also see some dull spots and these are low spots on the cover casting. Sand until the entire mating surface is shiny. It doesn't take a number of strokes. This isn't a sure fire fix either. We are trying a few sealants to see which works well. Loctite 574 and 5910 show a lot of promise. I'll keep you posted. I am trying to get a better handle on how far reaching the oozing is on the valve covers and we are trying to make sure Rotax stays informed.. |
 Ah, ok so unevenness is showing up on the cover then?
 also, speaking of leaks..... Are there other places that the 912 series eventually springs leaks over time? I'm curious about if they do start to leak when they get on in hours and where the leaks typically occur.
 Like I said, I'm used to my old cars and motorcycles where oil coming out of somewhere is just normal after a while (not to mention looking under the cowling of a lyc/continental here and there).....
 Plus a friend of mine has a 912ULS with about 600 hours on it with a considerable leak at the front. Most of it seems to be coming out where the starter attaches to the housing on the engine. It's bad enough to wet the engine and get onto the plane after a while.
 He's going to pull it to have it repaired soon (and I plan to help him pull the motor), but I'm curious what I'm in for too as I put hours on mine
 LS
Titan II SS |
		Thom Riddle
				 Posted: Tue Jan 19, 2010 8:52 am    Post subject: Re: oozing valve covers |
				None of my 912UL engines, each with over 700 hours, ever had any leaks anywhere. That said, I was super conscientious about monitoring temperatures and making sure none ever got near the max allowable.
Buffalo, NY (9G0)
- Anonymous |
		Roger Lee
				 Posted: Tue Jan 19, 2010 9:29 am    Post subject: Re: oozing valve covers |
				The starter does have an "O" ring and it's fairly easy to replace. Part 250-140. It is a 24.4 mm X 3.10 mm. Maryland Metrics is a good place to buy metric "O" rings if you aren't locked into genuine Rotax parts and 1/3 the price. Very unusual for this to part to leak. Check the screws and see if they are tight.
 https://ssl.perfora.net/metricshop.com/rfq.htm
 http://mdmetric.com/or/fpm80oringsizelisting.pdf
 The only places I have really seen leak are the valve covers (usually an ooze), the oil cooler where the lines attach (these nuts need a wrench put on them once in a while to double check the tightness) and the gearbox (just needs to be re-sealed with Loctite 5910).
 I have tracked down a few oil seeps that was thought to be coming from one place and it was really from somewhere else because of the high speed air flowing through and depositing it somewhere else. This is quite common to to miss this diagnosis.
Tucson, Az.
Cell 520-349-7056 |
		Float Flyr
				 Posted: Tue Jan 19, 2010 5:05 pm    Post subject: oozing valve covers |
				Not sure on the Rotax but on the lycoming when they give a torque range it is always recommended that you use the lowest possible torque.  That keeps the metal in the engine from stretching or warping.
 Noel
 From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of catz631(at)aol.com
  Sent: January 19, 2010 9:32 AM
  To: rotaxengines-list(at)matronics.com
  Subject: Re: oozing valve covers
 Roger,
                                         Dick Maddux
                                         Kitfox 4
                                         Milton,Fl
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RotaxEngines-List  | 	  0123456789
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		rickofudall
				 Posted: Tue Jan 19, 2010 5:51 pm    Post subject: oozing valve covers |
				For what it's worth, a very long time ago while P & M ing about leaky rocker box screws an old time Harley mechanic told me to always make sure the o-ring groove was absolutely clean and dry. His reasoning was that fluids are incompressible and when caught behind the o-ring, the oil wouldn't give but the o-ring would, creating a path for a leak to start. Seems to work no matter the reasoning.
 Rick Girard
 On Tue, Jan 19, 2010 at 7:04 PM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
 Noel
 From: owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com) [mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of catz631(at)aol.com (catz631(at)aol.com)
  To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
 Roger,
                                         Dick Maddux
                                         Kitfox 4
                                         Milton,Fl
   012 34567 89
		Float Flyr
				 Posted: Tue Jan 19, 2010 6:00 pm    Post subject: oozing valve covers |
				If you want to see oil consumption and the more than occasional drop blowing
 around just check out any radial!
 Noel
Kitfox III-A
		peterlthomson(at)gmail.co Guest
				 Posted: Wed Jan 20, 2010 6:59 am    Post subject: oozing valve covers |
				500hrs, no oil leaks, runs cold
 Peter
 CH710SP/912ULS
		Roger Lee
				 Posted: Wed Jan 20, 2010 6:06 pm    Post subject: Re: oozing valve covers |
				The oil leaks that I'm talking about don't come from an over heat or a hot engine. They are vibration caused or the cast valve covers have high and low spots.
 I think I have a good solution that seems to be working well. Sand the valve covers on a flat surface with some 220 grit to make sure the surface is flat all the way around the valve cover. Don't be afraid it takes more than a couple of strokes. Clean the "O" ring groves and mating metal surfaces with a solvent. The put the "O" rings in place and coat them with Loctite 574 (orange), both the "O" ring side and the engine mating surface. You do not need to glob it on, but a film around both surfaces and the small "O" ring in the center where the valve cover screw goes through. Them re-mount the valve cover and torque to 115 in/lbs. The normal torque is 105 in/lbs so the additional 10 in/lbs won't hurt anything. So far very good success.
Tucson, Az.
Cell 520-349-7056 |
