bakerocb
Posted: Wed Jan 20, 2010 11:47 am Post subject: ONGOING DISCUSSION |
1/19/2010
Hello Jim, Good to hear from you.
You ask: "Does the following item (a) possibly relieve one from compliance
with the 24 calendar month criteria if the aircraft involved never operates
under "IFR conditions" in controlled airspace?"
| Quote: | "14 CFR 91.411 (a) No person may operate an airplane, or helicopter, in
controlled airspace under IFR unless-
(1) Within the preceding 24 calendar months, each static pressure
system, each altimeter instrument, and each automatic pressure altitude
reporting system has been tested and inspected and found to comply with
appendices E and F of part 43 of this chapter;"
{Response} Just avoiding all "IFR operations in controlled airspace" is not
sufficient
to relieve one of the 14 CFR required periodic transponder checks. Let's see
if we can figure out why.
1) First, while operating in what airspace must one's aircraft be
"........equipped with an operable coded radar beacon transponder......"?
Paragraph 91.215 (b) answers that question:
"91.215 (b) All airspace. Unless otherwise authorized or directed by ATC, no
person may operate an aircraft in the airspace described in paragraphs
(b)(1) through (b)(5) of this section, unless that aircraft is equipped with
an operable coded radar beacon transponder .........."
So if one avoids flying in any of the transponder required airspace as
described in (b) (1) through (b) (5) then one does not need a transponder.
But if one flys, even under VFR, in any of that described airspace then they
must have an operable transponder installed. Note that the airspace below
10,000 feet MSL and within 2,500 feet of the surface is not transponder
required airspace. See 91.215 (b) (5) (i).**
2) What kind of transponder must we part 91 pilots have to fly in that
transponder required airspace? 91.215 (a) answers that question:
"91.215 (a) All airspace: U.S.-registered civil aircraft. For operations not
conducted under part 121 or 135 of this chapter, ATC transponder equipment
installed must meet the performance and environmental requirements of any
class of TSO-C74b (Mode A) or any class of TSO-C74c (Mode A with altitude
reporting capability) as appropriate, or the appropriate class of TSO-C112
(Mode S)."
3) Does that 91.215 (a) required installed transponder have to have any kind
of a periodic test? 91.413 answers that question:
"91.413 ATC transponder tests and inspections.
(a) No persons may use an ATC transponder that is specified in 91.215(a),
121.345(c), or §135.143(c) of this chapter unless, within the preceding 24
calendar months, the ATC transponder has been tested and inspected and found
to comply with appendix F of part 43 of this chapter; and..............."
4) When are we required to operate the 91.215 (a) required transponder that
has been tested as required by 91.413? Paragraph 91.215 (c) answers that
question:
"91.215 (c) Transponder-on operation. While in the airspace as specified in
paragraph (b) of this section or in all controlled airspace, each person
operating an aircraft equipped with an operable ATC transponder maintained
in accordance with §91.413 of this part shall operate the transponder,
including Mode C equipment if installed, and shall reply on the appropriate
code or as assigned by ATC."
5) Note that the term IFR has not even come up yet in the questions and
answers in 1, 2, 3, and 4 above. So what is the big deal about transponders
and IFR controlled airspace?
The big deal is the requirement in 91.411 of complying with Appendix E as
well as Appendix F of Part 43 for a transponder used in IFR operations in
controlled airspace. See here:
"91.411 Altimeter system and altitude reporting equipment tests and
inspections.
(a) No person may operate an airplane, or helicopter, in controlled airspace
under IFR unless-
(1) Within the preceding 24 calendar months, each static pressure system,
each altimeter instrument, and each automatic pressure altitude reporting
system has been tested and inspected and found to comply with appendices E
6) So if we have an aircraft with an engine-driven electrical system how do
we get out from under the 91.411 or 91.413 every two year transponder
checks? We could:
A) Never fly (VFRor IFR) within the 91.215 (b) transponder required
airspace. Then you will not be be required to either have a transponder or
have it checked if you do have one. If you do have a transponder installed,
but it has not been checked you are forbidden from operating it.
B) Fly only VFR within the 91.215 (b) permitted airspace -- below 10,000
feet MSL or within 2,500 feet above the surface. There you will not be be
required to either have a transponder or have it checked if you do have one.
If you do have a transponder installed, but it has not been checked you are
C) Fly IFR only in Class G uncontrolled airspace, if you can find some.
There you will not be required to either have a transponder or have it
checked if you do have one. If you do have a transponder installed, but it
has not been checked you are forbidden from operating it. You don't even
have to be in contact with ATC.
I think that item C above is largely theoretical in nature. Supposedly the
low altitude IFR charts show the uncontrolled Class G airspace below 14,500
MSL in brown. It has been quite awhile since I've flown out west where there
was still some brown showing, but there wasn't much left. All airspace above
14,500MSL is Class E air space and therefore considered controlled.
So you can see that it is possible to avoid the 14 CFR required periodic
transponder checks, but not very practical unless maybe you are an ag pilot
operating locally.
Comments or questions?
OC
**PS: See 91.215 (b) (2). I note that KHWY is within 30 miles of KIAD which
is listed in Appendix D, Section 1 to Part 91. Therefore airplanes operating
out of KHWY are required to have operable transponders.
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
bakerocb
Posted: Thu Jan 21, 2010 4:48 am Post subject: ONGOING DISCUSSION |
1/21/2010
Hello Raymond, You wrote; "Q. Who can test and inspect to verify compliance
with E and F of the
chapter?"
{Response} The entities qualified to perform the 14 CFR Part 43 Appendicies
E and F tests required by 14 CFR paragraphs 91.411 and 91.413 are listed in
those paragraphs. They can be readily accessed at this web site by clicking
on Regulations & Policies:
http://www.faa.gov/
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 12:59:27 PM PST US
Subject: Re: AeroElectric-List: ONGOING DISCUSSION
Q. Who can test and inspect to verify compliance with E and F of the
chapter?
Raymond Julian
Kettle River, MN.
