Kelly McMullen
Posted: Fri Jan 29, 2010 7:02 am Post subject: Fuel Valve |
Is the Andair still considered the best setup? I understand that Van's
supplied valve is significantly improved from original. Cost vs better
function? Anyone flying with Van's improved valve? Just trying to
asses how many "improvements" I want to do vs time and cost to do
them.
Kelly
40866
QB fuse
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Fri Jan 29, 2010 7:31 am Post subject: Fuel Valve |
Disregard...after reviewing archives, it appears that even the newer
valve isn't good for much more than 300 hrs.
On Fri, Jan 29, 2010 at 8:01 AM, Kelly McMullen <apilot2(at)gmail.com> wrote:
them.
Kelly
40866
QB fuse
KCHD |
Phil.Perry(at)netapp.com Guest
Posted: Fri Jan 29, 2010 7:40 am Post subject: Fuel Valve |
Thanks for the research, Kelly..
I'll dig a little deeper into my wallet now.
Good thing it's payday.
If you get a minute, do you mind sharing those previous threads? I'd
like to take a walk through them.
Phil
Posted: Sat Jan 30, 2010 12:52 pm Post subject: Fuel Valve |
To piggy back on Kelly's question...
I know the part number that most people are using for the Andair valve
is fs20x7...
Question: What extension length is required for the tunnel? And can you
trim down the extension if it's too long? I'm planning on Geoff's panel
an console; if that matters.
Finally, what fittings seem to be the standard? Van's fittings are 1/4"
female on the valve. I'm guessing that's what everyone is using too?
Phil
rleffler
Posted: Sat Jan 30, 2010 1:47 pm Post subject: Fuel Valve |
I used about 3" of the extension. I have the newer valve location which is
lower than the original location. I ordered the FS20x7-T, which have male
AN-6 fittings. The new elbow fittings make installing the fuel valve much
easier. Also, don't cross the fuel lines per the plans. The andair valve
doesn't require that.
You can see some of my photos here:
http://www.mykitlog.com/users/display_log.php?user=rleffler&project 60&cate
gory=0&log=95897&row=7 and
gory=0&log=89805&row=51 .
I'm using Geoff's center arm rest console, so there was some additional
creative engineering that had to be done. If you are installing this as
well, I just finished the install manual and posted them to Geoff's site.
It can be found here: http://aerosportproducts.com/doc.htm If you are just
using Geoff's instrument panel, that doesn't impact the fuel valve
installation.
bob
_________________ Bob Leffler
N410BL - Phase I
n223rv(at)wolflakeairport Guest
Posted: Sat Jan 30, 2010 2:54 pm Post subject: Fuel Valve |
I purchased the 6" extension and used about 1/2 of it. It is an
extrusion and yes, you cut it to any length you need then install the
end fittings to mate to the valve and selector.
which is
have male
valve much
valve
additional
this as
site.
are just
installation.
bob
