Posted: Tue Feb 09, 2010 7:57 am Post subject: Learning to fly a Kolb |
Gentlemen (and a couple of ladies) C
Not that I want to get in the middle of your shootin' match C but I am curious about something else.
One of the biggest reasons I chose to build a Kolb Mark III is because it was reported to be "easy to fly" C among a few other attributes I wanted.
I would consider my flying experience as "light to moderate". I've flown a Piper Cherokee C a few Cessnas (150's & 172's) C my own Cessna 172's (about 500 hours combined C in my own 172's). Along with my factory-iron flying C I've got around 20 or so hours dual with an instructor in a Quicksilver trainer.
So C my total flying experience comes in around 600 hours C give or take.
Now C compared to many of you C that's just chump change. Some of you'ze guys have thousands of hours in all kinds of aircraft. Some have less.
My question is; how difficult was it for you to learn to fly your Kolb? Would you really say your learning experience to fly your Kolb was "easy"? (self taught or instructor taught)
I will be taking be formal training C I guarantee that!! I'm not risking destroying my Kolb or myself ASSUMING anything. (I crashed an ultralight once C assuming a few hours of Cessna dual was "good enough". Wrong!!) I won't do THAT again!!
My question is; Is it easy to learn to fly your Kolb?
Mike Welch
MkIII
Hotmail: Free C trusted and rich email service. Get it now. [quote][b]
herbgh(at)nctc.com Guest
Posted: Tue Feb 09, 2010 8:25 am Post subject: Learning to fly a Kolb |
I took a few hours of dual in a 150...jumped in the MkIII that I had back in the late 90's and never looked back.. The MKIII was easier for me to fly than my Firefly...Herb
At 09:56 AM 2/9/2010, you wrote:
[quote]Gentlemen (and a couple of ladies),
Not that I want to get in the middle of your shootin' match, but I am curious about something else.
One of the biggest reasons I chose to build a Kolb Mark III is because it was reported to be "easy to fly", among a few other attributes I wanted.
I would consider my flying experience as "light to moderate". I've flown a Piper Cherokee, a few Cessnas (150's & 172's), my own Cessna 172's (about 500 hours combined, in my own 172's). Along with my factory-iron flying, I've got around 20 or so hours dual with an instructor in a Quicksilver trainer.
So, my total flying experience comes in around 600 hours, give or take.
Now, compared to many of you, that's just chump change. Some of you'ze guys have thousands of hours in all kinds of aircraft. Some have less.
I will be taking be formal training, I guarantee that!! I'm not risking destroying my Kolb or myself ASSUMING anything. (I crashed an ultralight once, assuming a few hours of Cessna dual was "good enough". Wrong!!) I won't do THAT again!!
Mike Welch
MkIII
Hotmail: Free, trusted and rich email service. now.
Posted: Tue Feb 09, 2010 8:30 am Post subject: Learning to fly a Kolb |
Really easy bird but you should aim your nose at the point you want to land, not out yonder somewhere like a cessna.Any taildragger symptoms will be exaggerated if you jack it up on longer legs or put too much toe-in.
(guilty on both counts)
BB
On 9, Feb 2010, at 10:56 AM, Mike Welch wrote:
| Quote: | Gentlemen (and a couple of ladies),
Mike Welch
MkIII
Hotmail: Free, trusted and rich email service. Get it now. | Quote: |
Posted: Tue Feb 09, 2010 8:52 am Post subject: Learning to fly a Kolb |
You will find that your MKIII IS easy to fly (assuming you built it right). There are a few differences that can bite you. First the high trust line will get you if you try a "crow hop". Chopping the power right after takeoff will result in severe pitch up trim just when you don't want it. Then if you then add power to recover from your unintended no power climb you will get the reverse. If you just take off normally you will easily adjust to prower/trim changes.
The second most common issue is landing too high. You Cessna experience will count against you. Also Kolb flaps are very useful but powerful and will aggravate your Cessna training even more. Fly the plane with some power to what will feel like inches off the ground then cut the power. Use power on approach to make your MKIII fly like a Cessna landing and you will have no problems. SLOWLY learn to land with less power. Then after getting very comfortable you can try flaps. Landing with full flaps and no power is a highly skilled maneuver that I still can't get right.
Rick Neilsen
Redrive VW Powered MKIIIC
Posted: Tue Feb 09, 2010 9:43 am Post subject: Learning to fly a Kolb |
Rick C
Thanks for the pointers. I'm very familiar with the high thrust line tendencies. The Quick 2-seater I flew had the Rotax 582 top-mount. Pretty much the same reaction.
My private pilot flight instructor C decades ago C told me "Slow power changes"!!! "We aren't trying to scare the civilians" C he'd say. I make gradual throttle changes.
During my U/L training C I got to where I liked to chop the power (remember..slowly) C drop the nose C and grease it in. I got to the point where my instructor and I carried on a casual conversation C all the while C while I flew in for a landing C but didn't touch down C instead C I flew 3 feet off the runway for it's entire length C and we talked about fishing the whole time. When I got to the end C I'd throttle up C climb out C and do it again. Got so relaxed at landings C they were like 2nd nature.
When I was a heckava lot younger (35 years ago) I used to hang glide. Flaring too high isn't going to be a problem. That part seems pretty easy.
Thanks for the input.
BTW C For those that kept track; I put my MkIII construction on hold last spring C due to the construction of my house (1200' from the local airport). I've virtually finished building my house C break time is over C and I feel the urge to get back to work on the plane. My plan is get it done by early summer.
The plane is fully painted C except for stripes. The engine is practically ready to fire up. Just some minor hook-ups to complete C and install my "already built" instrument panel.
Mike Welch
Subject: Re: Learning to fly a Kolb
Date: Tue C 9 Feb 2010 11:52:14 -0500
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Verdana;font-size:10pt;} Mike
Rick Neilsen
Dana
Posted: Tue Feb 09, 2010 10:20 am Post subject: Learning to fly a Kolb |
Mike the combination of your Cessna and Quicksilver experience means you'll have no trouble with your Kolb. If anything, get an hour or two in a Cub to get the hang of flying a taildragger.
My experience was similar (except my plane was a T-Craft, so the taildragger issue didn't exist), and I just got in my UltraStar and flew it, no problem.
You'll need to get a tailwheel endorsement anyway if you don't already have one or have tailwheel solo time before some cutoff date.
-Dana
Mike Welch
MkIII
When you were born, you cried and the world rejoiced...
Live your life so that when you die, the world cries and you rejoice.
-- Cherokee saying [quote][b]
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Tue Feb 09, 2010 11:20 am Post subject: Re: Learning to fly a Kolb |
My $.02 worth
Get some time in a cub and learn how to wheel land it.
Jason
MKIII
Portland, OR
[quote="mdnanwelch7(at)hotmail.co"]Gentlemen (and a couple of ladies) C
� Not that I want to get in the middle of your shootin' match C but I am curious about something else.
� One of the biggest reasons I chose to build a Kolb Mark III is because it was reported to be "easy to fly" C among a few other attributes I wanted.
� I would consider my flying experience as "light to moderate".� I've flown a Piper Cherokee C a few Cessnas (150's & 172's) C my own Cessna 172's (about 500 hours combined C in my own 172's).����� Along with my factory-iron flying C I've got around 20 or so hours dual�with an instructor�in a Quicksilver trainer.��
� So C my total flying experience comes in around 600 hours C give or take.
� Now C compared to many of you C that's just chump change.� Some of you'ze guys have thousands of hours in all kinds of aircraft.� Some have less.
� My question is; how difficult�was it for you to learn to fly your Kolb?� Would you really say your learning experience to fly your Kolb was "easy"?��(self taught or instructor taught)
� I will be taking be formal training C I guarantee that!!� I'm not risking destroying my Kolb or myself ASSUMING anything.��� (I crashed an ultralight once C assuming a few hours of Cessna dual was "good enough".�� Wrong!!)� I won't do THAT again!!
� My question is; Is it easy to�learn to fly your Kolb?
Mike Welch
MkIII
Ralph B
Posted: Tue Feb 09, 2010 12:04 pm Post subject: Re: Learning to fly a Kolb |
There is a tendency to flare by pulling the stick all the way back on landing for pilots who have flown large aircraft. Try to resist this and fly the plane to the ground. Light planes have more drag and will lose speed faster. Pulling back will stall it quicker and then damage the gear. Sometimes it helps to actually put the stick forward and dive it in to keep the speed up. This is somewhat unnerving and pilots want to resist this, but it will keep from bending things. I do this in heavy winds. No need for using flaps on the first flights.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Feb 09, 2010 12:17 pm Post subject: Re: Learning to fly a Kolb |
To chime in with my .02,
If the Mark III flies anything like my FS II did, the quicksilver training is probably going to be of the most value. It'll fly closer to that plane by far than it will the big iron.
My FSII I basically just jumped in and went flying. Probably not what I'd recommend to someone else. But as soon as I got used to the tailwheel handling and flew the tail a bunch of times up and down the runway I pretty much just blasted off and went round the patch in it.
I did do a couple of crow hops down the runway first at which point I discovered that once airborne the plane flew almost exactly like my old quicksilver did. So off I went.
I did wheel landings about 95% of the time and if I bounced it a bit, some forward stick would glue it onto the runway. Big bounces of course I'd go around with smooth power applications and back pressure on the stick.
It does fly like a low-inertia design, not a lot of hang time in the flare and you do kind of drive it onto the runway. The Mark III may fly a little different, tho.
LS
_________________ LS
Titan II SS |
Steve Simmons
Posted: Tue Feb 09, 2010 1:17 pm Post subject: Learning to fly a Kolb |
It is funny, when I wanted to learn to fly the Firstar, I got the basic
power settings from the ex owner and since I did not have access to anyone
else that I knew of to teach me with a Kolb I went out with one of my
friends and did 30 to 40 T/O and landings on a old 7AC then started crow
hopping, after about five or six trips up and down the runway I powered up
and took off to my surprise the little bird flew and landed just like the
old DC3 I use to fly freight in, perfect 3point landings and no bad habitat.
By the way it was not because of the pilot it just felt natural.
Posted: Tue Feb 09, 2010 3:40 pm Post subject: Learning to fly a Kolb |
Wouldn't it be better to comment on MKIII flight characteristics if you were
qualified in that particular aircraft?
john hauck
MKIII
_________________ John Hauck
Titus, Alabama |
Posted: Tue Feb 09, 2010 3:53 pm Post subject: Learning to fly a Kolb |
| Quote: | By the way it was not because of the pilot it just felt natural.
Steve S/Gang:
Kolbs are beautiful, gentle, comfortable little airplanes to fly. As you so
well put, "have a natural feel."
Some new guys have difficulty with Kolbs because they don't fly the
airplane. Kolbs do not fly by themselves.
Stick to the basics, keep it above the stall, and it won't fall through on
short final.
Like any other fixed wing, won't fly below the stall. Lowering stall speed
doesn't help. Keeping aircraft above stall speed does.
All Kolb models do well with wheel landings and three point full stall
landings. It isn't the aircrafts fault if you can't fly.
So simple, so basic. If it was anything more, I couldn't do it.
john hauck
Titus, Alabama |
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Tue Feb 09, 2010 5:23 pm Post subject: Re: Learning to fly a Kolb |
Hello...Here is my 2 cents worth....As Rick said ,fly it right down to the ground...and I use flaps always...I maintain 55 mph all the way to the ground then level off and let it settle...and I mean inches from the ground...also if you are the one test flying it,go up with someone in your 172 and have then put the airplane way out of trim with them holding it level so when you take it you get the feel of it out of trim and deal with it ...that way if you get up with your Kolb,you will automatically have a feel for a problem....Just a thought....
Good luck !
chris ambrose
M3X/Jab
N327CS 98.0hrs
Posted: Tue Feb 09, 2010 5:29 pm Post subject: Learning to fly a Kolb |
Lucien/Gang:
Sorry to be a "spring butt", but sometimes I feel it necessary to qualify
some of the comments made on the Kolb List.
Mike Welch probably isn't looking for comments from someone with limited
Kolb experience, and no MKIII experience, to give him ideas on what to
expect when flying a MKIII.
Since you are not MKIII qualified, and he isn't looking for FSII flight
characteristics, your comments might lend more harm than good.
I find most of your comments on the Kolb List are information you pick up
from other sources, and not necessarily your own personal, hands on
experience. Some of it is good, and some of it is not so good. You come
across as a fair weather flyer, rather than a well rounded all weather VFR
pilot. To be an accomplished Kolb pilot, I believe it is necessary to
experience and feel comfortable controlling the aircraft in uncomfortable
weather. During my flying career it has always been very easy to get caught
out in bad weather, not matter what I was flying.
| Quote: | From my own personal experience, a J3 Cub and Aeronca Champ have similar
flight characteristics and feel, to those of the MKIII. Probably because of
similar weight, airspeed, airfoil, and tube and fabric construction, not
tube and sails.
I have never flown any other ultralight than a Kolb or Bert Howland's H2
Honey Bee. So I am not qualified to comment on how a Quicksilver flies,
although I have watched them fly and listened to many pilots that fly them.
Based on those comments, they do not fly like a Kolb.
john hauck
Titus, Alabama |
Dana
Posted: Tue Feb 09, 2010 6:13 pm Post subject: Learning to fly a Kolb |
At 08:29 PM 2/9/2010, John Hauck wrote:
| Quote: | | I have never flown any other ultralight than a Kolb or Bert Howland's H2 Honey Bee. So I am not qualified to comment on how a Quicksilver flies, although I have watched them fly and listened to many pilots that fly them. Based on those comments, they do not fly like a Kolb. |
John,
You're correct that Quicksilver flies nothing like a Kolb. However, for a pilot used to flying Cessnas or similar, the low speed and inertia of a Quick will give a prospective Kolb pilot a taste of that kind of behavior, enough to give a Cessna driver a good chance of getting his new Kolb up and down without bending it (though some Cub or similar tailwheel time would be a good idea too). It's a lot easier to find somebody instructing in a 2 seat Quicksilver than a Kolb.
Of course I've never flown a MKIII, only my US and my friend's FSII, so all I can do is extrapolate there.
-Dana
Sometimes it is easier to beg forgiveness than get permission. [quote][b]
Posted: Tue Feb 09, 2010 7:54 pm Post subject: Learning to fly a Kolb |
Gentlemen C
Yes C as John pointed out C I was more specifically asking about the actual learning and flying of a Kolb MkIII. Without a doubt C a few Firestar comments couldn't hurt C but it is my MkIII that I hope to learn to fly this summer.
Thanks.
Mike Welch
MkIII
Hotmail: Trusted email with Microsoft’s powerful SPAM pget='_new'>Sign up now. [quote][b]
Steve Simmons
Posted: Tue Feb 09, 2010 7:55 pm Post subject: Learning to fly a Kolb |
I have got a MarkIIIC but it is not flyable yet, hopefully next month I had
a firefly for about a year so I have more time if the firefly than the mark
III. I have about 30 minutes in a MarkIII with Steve Green so I have a lot
to learn yet.
ces308
Posted: Tue Feb 09, 2010 8:24 pm Post subject: Re: Learning to fly a Kolb |
Mike ,,if you are ever near Houghton Lake ,Mi, I would be happy to give you some time in a M3X....it's not hard...just different...
chris ambrose
M3X/Jabiru 98.0+ hrs
N327CS
ces308
Posted: Tue Feb 09, 2010 8:32 pm Post subject: Re: Learning to fly a Kolb |
Mike....check out my videos on you tube...search ces308 and they will come up.
chris ambrose
Posted: Tue Feb 09, 2010 10:30 pm Post subject: Learning to fly a Kolb |
Steve S/Gang:
Hated to see Steven G sell his MKIII. We made several long flights
together, the last was out to Monument Valley, Utah, a few years ago.
I had only flown Ultrastar and Firestar, when I crawled in the old Kolb
factory MKIII up at Homer's in Feb 1991. Dennis Souder took me for an
impressive ride around the patch, demonstrated an ultra steep full flap
approach, not on the grass strip, but on the short piece of grass next to
the hanger. After I got my heart out of my throat, Dennis hopped out and I
went flying with zero MKIII stick time. Kolbs are easy to fly, but you have
to have some air sense and air speed. Get below the stall and the Kolb will
fall. There is no such thing as "Kolb Quit". There are some folks that
can't fly though.
john hauck
Titus, Alabama |
