Straightening warped pieces?
rv10(at)colohan.com
PostPosted: Fri Feb 12, 2010 12:57 am    Post subject: Straightening warped pieces? Reply with quote
I've finally convinced myself I can build an RV-10, and have received my tailcone kit this week.
I finished inventory, then started looking at the pieces for the vertical stabilizer.  I noticed that the VS-1008 rear spar doubler and VS-1014 L+R rear spar caps were both somewhat warped.  The warp in the spar caps is mentioned in the plans, where they say to clamp it down to avoid the warp -- but there is no mention of a warp in the spar doubler.  It bows up about 3/16" when I lay it on a flat table.
It looks like the warp is caused by the punching process.  I can flatten it out by clamping it down to the spar, but worry that building a plane with internal static stress is not the Right Thing To Do.
Should I be worried about this and try to remove the warp?  Or should I just rely on the fact that it flattens out when I cleco it to the spar?
Or, phrased differently:  how much warp in a part pre-assembly is "too much"?
Chris
(still working through questions which I suspect are old hat to all of you...)
Tim Olson
PostPosted: Fri Feb 12, 2010 4:27 am    Post subject: Straightening warped pieces? Reply with quote
I don't know how much is too much, but yeah, that's how those
parts come. They'll be fine. You can flatten them out
if you try. I wouldn't stress too much over it...If you
can flatten them so the holes match, it'll all be ok.
Tim Olson - RV-10 N104CD
much"?
Chris
you...)
davidsoutpost(at)comcast.
PostPosted: Fri Feb 12, 2010 6:46 am    Post subject: Straightening warped pieces? Reply with quote
I straightened my warped pieces on the edge of the work bench. Don't overdo it trying to get them perfect. De-burr the edges and holes and it all pulls together when you cleco it together.
David Clifford
RV-10 In Progress
Empennage Done
Engine Overhauled & Pickled
Closing up The Wings
ogdenk
PostPosted: Fri Feb 12, 2010 9:04 am    Post subject: Straightening warped pieces? Reply with quote
You will have to deal with this issue when you get to the F-1011C Horizontal Stab attach bars, they are also warped from the stamping process.  You will need to put them in a vice (I padded the jaws with leftover pieces of J-stiffener which eliminated scratches quite well) and gently bash them with a rubber mallet to straighten them out.  I am seeing the same issue right now with the aileron bracket spacers, they have a bend that won't straighten when clecoed together with the other bracket parts, which are much thinner and curve to match the spacer.  I think I will straighten them as well.
Kent Ogden
#40710 Wings
>> <davidsoutpost(at)comcast.net> 2/12/2010 9:42 AM >>>
David Clifford
RV-10 In Progress
Empennage Done
rv10flyer
PostPosted: Fri Feb 12, 2010 8:50 pm    Post subject: Re: Straightening warped pieces? Reply with quote
Keep pressure applied to the piece in the direction you want to bend then use deadblow hammer and hit within an inch or two of the vise or table that it is clamped to. Then move piece in vise or on table an inch or two at a time until it is straight. You will use this method as I did on the 8' tailcone longerons to put a 2 degree bend in them. Of course you will only hit in one place. Works well.
Wayne G.
