dean.psiropoulos(at)veriz Guest
Posted: Sun Apr 16, 2006 8:32 pm Post subject: Alternator B Lead protection |
Lectric Bob:
I'm using a version of your Z-12 architecture modified for a single 60 AMP
alternator (no backup YET, after the airplane flies I'll add an SD- . My
question has to do with alternator B lead fusing and I'll get right to the
point.....
Is it really necessary to put a fuse, breaker or ANL in this circuit?
My thinking on this goes as follows:
1) The B lead would be routed from the alternator to the contactor on the
engine side of the firewall only (no heavy wire inside the cockpit).
2) I'm using an 8 gauge Tefzel wire provided in Van's wiring kit.
3) An 8 gauge Tefzel wire will experience appx 30 degree (C) temperature
rise at the 60 amps provided by the alternator at maximum output.
4) Even sitting next to a 200 degree (F) engine crankcase the temperature
rise on the wire should be within the capability of the wire insulation.
5) Even under extreme charging circumstances the full 60 amps of the
alternator will not be flowing in the wire for long periods, limiting the
duration of the temperature rise and insulation stress
6) B&C 60 amp externally regulated alternator with LR-3 reg/OV protect
The only condition that I can think of that might cause trouble and where a
fuse/breaker/ANL would mitigate a possible hazard is:
An alternator fault that allows a dead short between the battery positive
and crankcase ground through the alternator windings and the B lead. This
could burn up the windings in the alternator and possibly melt the B lead.
Is this the scenario that the ANL on the B lead is designed to mitigate?
What are the probabilities that such a scenario would occur in the field?
Any experience with this type of fault in 40 years of working on spam cans?
Would you advise against leaving this ANL out or is it just "extra
insurance" for some other scenario I'm missing? Thanks.
Dean Psiropoulos
RV-6A N197DM
Crimping and soldering
nuckollsr(at)cox.net Guest
Posted: Mon Apr 17, 2006 5:11 am Post subject: Alternator B Lead protection |
At 12:25 AM 4/17/2006 -0400, you wrote:
<dean.psiropoulos(at)verizon.net>
Lectric Bob:
point.....
Cars don't do it . . . and if you're comfortable with that in your
airplane too . . . you don't need to do it there either. But I believe
there was a recent case where a car caught fire in a parking lot . . .
don't recall the extent of the damage but I think the story cited
some form of failure in the alternator. Now, in all fairness, that
might have been a soft fault wherein b-lead protection would not
have opened and stopped progress of the event. Without detailed
analysis we're left with best hypothesis supported by what we hope
is good common sense and lots of experience. Unfortunately, it doesn't
take too many fertilizations of myth and bad science to turn
a perfectly understandable event into Scary Story version 1456.3
useful only for hangar flying over a pitcher of suds.
| Quote: | My thinking on this goes as follows:
That's it. Rare and in fact, I've not heard of one in many moons
with our customers. But the folks at Kelly see them come in from
time to time.
| Quote: | What are the probabilities that such a scenario would occur in the field?
I prefer not to deal in probability slicing. If the risks are not
zero -AND- potential for hazard under the fault condition is high,
then I prefer to design in plan-b hazard mitigation.
It's your airplane and I would not propose to dictate design
philosophies to you.
