sportav8r(at)gmail.com Guest
Posted: Mon Mar 15, 2010 11:03 am Post subject: Mystery of the low CHT solved |
Cause of my recent low (190-210*F) CHT's on #4 cylinder, with normal pre-start readings and normal EGT's and power in flight, was just what one might suspect before even pulling the cowl - a faulty sensor; in this case, dangling free of the cylinder head, leaning against the intake manifold tube.
What's curious is how the twist and lock spring-loaded connector came loose on this bayonet probe: the tiny spot-welded pin that protrudes radially from the side of stainless barrel that screws into the cylinder head, which the probe cap is slotted to lock upon, fell out of its hole. I will find out soon if I need to buy a whole new sensor or just the mounting assembly. These probes are 12 years old and have 750 hours on them. I see no way to anticipate or detect this kind of failure before it happens. Fortunately, it's not a big safety-of-flight item to suddenly get a low CHT reading if the engine is still making normal power.
Off to call GRT and see what's available in the way of spare parts...
-Stormy
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
Posted: Mon Mar 15, 2010 1:23 pm Post subject: Mystery of the low CHT solved |
"Here. Let me Google that for you..."
Answered my own question with a trip to the GRT website - they sell replacement screw-in bayonet probe adapters for 5 bucks. I'll be good to go when the mail runs later this week.
-Stormy
On Mon, Mar 15, 2010 at 11:36 AM, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote] Cause of my recent low (190-210*F) CHT's on #4 cylinder, with normal pre-start readings and normal EGT's and power in flight, was just what one might suspect before even pulling the cowl - a faulty sensor; in this case, dangling free of the cylinder head, leaning against the intake manifold tube.
-Stormy
st" target="_blank">http://www.matronics.com/Navigator?RVSouthEast-List
tp://forums.matronics.com
| [b]
Larry Bowen
Posted: Mon Mar 15, 2010 9:59 pm Post subject: Mystery of the low CHT solved |
In case you or someone else missed the reference to "let me google that for you"
See http://lmgtfy.com. Or in this example:
http://lmgtfy.com/?q=cht+bayonet+probe+adapters
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
On Mon, Mar 15, 2010 at 4:51 PM, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote] "Here. Let me Google that for you..."
-Stormy
| Quote: | Cause of my recent low (190-210*F) CHT's on #4 cylinder, with normal pre-start readings and normal EGT's and power in flight, was just what one might suspect before even pulling the cowl - a faulty sensor; in this case, dangling free of the cylinder head, leaning against the intake manifold tube.
-Stormy
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
