rashvac(at)earthlink.net Guest
Posted: Sun Mar 14, 2010 6:04 pm Post subject: Bent fuselage |
I am finally getting around to doing Van's quality control inspection on my RV-10 quick build fuselage. I have counted 43 errors or omissions. Some of these are very minor, like snap bushings not being installed, some are a little harder; having to drill out AN470 rivets to install flush rivets.
The areas of major concern, and maybe someone can enlighten me are:
1.)the bend angle in the rear of the fuselage does not match the F-1006 bulkhead and the F-1023B gussets does not match the holes in the underlying structure.
2.)it does not look like they put any twist in the 1041 or 1040 channels, so the 1050 floor pan holes do not match up with all the underlying structure especially the side channels.
Can anyone tell me if this is going to be a big problem?
3.)all of my interior sheet metal did not get machine counter sunk for the #8 screws - can you machine counter sink these parts that have nut plates behind them already?
Thanks.
Russell Shavitz
Shavitz Heating & Air Conditioning
4849 Main Street, Skokie, IL 60077
office: 847-678-1000
cell: 847-417-6622
www.shavitz.com
Phil.Perry(at)netapp.com Guest
Posted: Mon Mar 15, 2010 8:04 am Post subject: Bent fuselage |
Welcome to the new QB factory!
Actually I believe I can explain this one:
"2.)it does not look like they put any twist in the 1041 or 1040 channels, so the 1050 floor pan holes do not match up with all the underlying structure especially the side channels."
On my QB kit, there were 3-4 holes that were not drilled through the floor pans and into the side channels. I thought I had the same issue, but after digging around with a flashlight and mirror to look underneath, I could see that they left those holes untouched. The only logic I could come up with is that the twist is slightly different from fuse to fuse, so they wanted to leave those holes untouched until each of us could put our own floor boards in.
I'll bet your holes aren't drilled either. It's pretty easy to see with an inspection mirror and a small flashlight.
Phil
Posted: Mon Mar 15, 2010 1:25 pm Post subject: Bent fuselage |
I pulled my floor out and all the holes are drilled but they do not match the side channels and
the back of the fuse does not match the tailcone bulkhead there is a twist in the fuse. Is this normal and will it straighten when I install the tailcone.
ricksked(at)cox.net Guest
Posted: Mon Mar 15, 2010 6:16 pm Post subject: Bent fuselage |
Russell,
For once I'm really not trying to be a smart A** but I am really glad I didn't go the QB route. Building the fuselage was the most fun of all the kits IMHO. These problems seem to have started to crop up after Vans changed contractors in the PI. I feel for you guys who forked over the extra $ to get a product that seems to not live up to the extra cost/time value. If you have a no sh*t twist in your fuselage Russell the end result will be an airframe that is not true. The fuselage is the trunk of the tree and the wing/HS/VS incidences along with the thrust line are all established of off it. Regardless of the time involved, I would demand a new one.
Rick S.
Getting close to 100 hours.
Kelly McMullen
Posted: Tue Mar 16, 2010 2:55 am Post subject: Bent fuselage |
You will find that all the holes along the baggage floor have to be
pulled inward because they didn't put quite enough curve in the bottom
skin. Until you have the tailcone cleco'd on, you won't be able to
tell how some of the longerons line up. Finished this on my QB a
couple weeks ago.
On Mon, Mar 15, 2010 at 1:56 PM, Russell Shavitz <rashvac(at)earthlink.net> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
msausen
Posted: Tue Mar 16, 2010 2:39 pm Post subject: Bent fuselage |
My apologies... I thought you were talking about the side channels in the front floorboards... Those are the ones that were not drilled that I was referring to.
The rear baggage floors aligned for me.
BTW after attaching the tailcone, I checked the entire length of the tailcone/QB forward fuselage assembly for twist with a digital level. At the very most, it's twisted 1/10th of a degree.
Much straighter than the old-time RV's that were built with bubble levels.
Phil
