tdawson-townsend(at)auror Guest
Posted: Wed Mar 17, 2010 5:45 pm Post subject: Protective covers? |
I was thinking of making one or two little protective covers for my AOA pressure ports using a couple of suction cups with a “Remove before Flight” tag hanging off.
Overkill, or useful?
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
Ron.McGann(at)ausawd.com Guest
Posted: Wed Mar 17, 2010 6:01 pm Post subject: Protective covers? |
Don’t have an opinion on the static ports. But I highly recommend a cover or preflight on the fuel vent lines. I had a wog crawl into the line and completely seal the vent – noticeable by a profound sucking noise when the fuel cap is removed. Having seen the consequences of a blocked vent (a badly crushed tank), I check the vent line is clear every flight.
Cheers
Ron
VH-XRM flying in Oz
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Thursday, 18 March 2010 12:39 PM
Subject: Protective covers?
TDT
Tim Dawson-Townsend
40025
[quote] Quote: | [b]http://www.matronics.com/Navigator?RV10-List | 012345678
gengrumpy(at)aol.com Guest
Posted: Wed Mar 17, 2010 6:05 pm Post subject: Protective covers? |
Gotta ask for the rest of the list, Ron.
What's a wog????
grumpy
On Mar 17, 2010, at 9:00 PM, McGann, Ron wrote:
[quote]Don’t have an opinion on the static ports. But I highly recommend a cover or preflight on the fuel vent lines. I had a wog crawl into the line and completely seal the vent – noticeable by a profound sucking noise when the fuel cap is removed. Having seen the consequences of a blocked vent (a badly crushed tank), I check the vent line is clear every flight.
Cheers
Ron
VH-XRM flying in Oz
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Dawson-Townsend,Timothy
TDT
Tim Dawson-Townsend
40025
2[/b]
Posted: Wed Mar 17, 2010 6:32 pm Post subject: Protective covers? |
A bent pipe cleaner (W) poked into the vent will keep out critters. Mud daubers are a problem here in the SE, and the pipe cleaners work. You don't even have to remove them for flight.
Linn
McGann, Ron wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Cheers
Ron
VH-XRM flying in Oz
Subject: RV10-List: Protective covers?
TDT
Tim Dawson-Townsend
40025
2 [b]
dlm46007(at)cox.net Guest
Posted: Wed Mar 17, 2010 7:35 pm Post subject: Protective covers? |
another reason to have two holes per vent line. I have the normal vent lines beveled forward and inside the fairing I have a #50 hole drilled in the backside of the vent line. This is in a protected area in case impact ice or snow would clog the normal vent.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John
Sent: Wednesday, March 17, 2010 7:05 PM
Subject: Re: Protective covers?
What's a wog????
grumpy
Quote: | Don’t have an opinion on the static ports. But I highly recommend a cover or preflight on the fuel vent lines. I had a wog crawl into the line and completely seal the vent – noticeable by a profound sucking noise when the fuel cap is removed. Having seen the consequences of a blocked vent (a badly crushed tank), I check the vent line is clear every flight.
Cheers
Ron
VH-XRM flying in Oz
TDT
Tim Dawson-Townsend
40025
2[/b]
| 3 [quote][b]
Posted: Wed Mar 17, 2010 7:55 pm Post subject: Protective covers? |
Aussie slang for any creepy crawley, bug, critter, insect etc. There are also a number of politically incorrect definitions that I won’t go in to, but none in that category will fit inside the vent line J.
Cheers
Ron
Sent: Thursday, 18 March 2010 1:05 PM
What's a wog????
grumpy
Cheers
Ron
VH-XRM flying in Oz
TDT
Tim Dawson-Townsend
40025
Quote: | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution =========== |
0123456789 Quote: | http://www.matronics.com/Navigator?RV10-List | 0 Quote: | http://www.matronics.com/Navigator?RV10-List | 1 Quote: | http://www.matronics.com/Navigator?RV10-List | 2 Quote: | http://www.matronics.com/Navigator?RV10-List | 3 Quote: | http://www.matronics.com/Navigator?RV10-List | 4 Quote: | http://www.matronics.com/Navigator?RV10-List | 5 Quote: | http://www.matronics.com/Navigator?RV10-List | 6
Posted: Thu Mar 18, 2010 5:35 am Post subject: Protective covers? |
Oh, I get it.
Like American politicians!
grumpy
On Mar 17, 2010, at 10:52 PM, McGann, Ron wrote:
[quote]Aussie slang for any creepy crawley, bug, critter, insect etc. There are also a number of politically incorrect definitions that I won’t go in to, but none in that category will fit inside the vent line J.
Cheers
Ron
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Miller John
What's a wog????
grumpy
Cheers
Ron
VH-XRM flying in Oz
TDT
Tim Dawson-Townsend
40025
0123456789
msausen
Posted: Thu Mar 18, 2010 8:06 am Post subject: Protective covers? |
This is one of those things that has always intrigued me. Has anyone done the math on if an #50 hole can provide the volume of air to offset 10+ gallons per hour?
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: Wednesday, March 17, 2010 11:31 PM
Subject: RE: Protective covers?
What's a wog????
grumpy
Cheers
Ron
VH-XRM flying in Oz
TDT
Tim Dawson-Townsend
40025
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0123href="http://forums.matronics.com">http://forums.matronics.comhttp://www.matronics.com/con[/b] [/quote]4
rv10free2fly(at)yahoo.com Guest
Posted: Thu Mar 18, 2010 3:57 pm Post subject: Protective covers? |
I like Tim's check valve idea in case the vent line becomes blocked.
'Onya' (Aussie for good on you) again Tim.
Pat
From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Sent: Fri, 19 March, 2010 12:23:49 AM
Michael
What's a wog????
grumpy
Cheers
Ron
VH-XRM flying in Oz
TDT
Tim Dawson-Townsend
40025
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0123href="http://forums.matronics.com">http://forums.matronics.com http://www.matronics.com/con4
5
mregoan(at)hispeed.ch Guest
Posted: Thu Mar 18, 2010 9:56 pm Post subject: Protective covers? |
The sensors have to be extremely sensitive to measure the change in pressure associated with a change in AOA, so putting a suction cup over the AOA port might have a negative effect on the calibration of the sensor(s). Just a thought, I don’t know the system or components.
Gordon Anderson
#41015, Switzerland
Empennage
Sent: 18 March 2010 02:39
TDT
Tim Dawson-Townsend
40025
dmaib(at)mac.com Guest
Posted: Fri Mar 19, 2010 8:23 pm Post subject: Protective covers? |
A suction cup won't work anyway, because the hole in the wing won't let you get any suction! I felt like a real dummy when I figured out why the little suction cups I bought to cover the upper and lower AFS ports would not stick to the wing. Duh!
David Maib
40559
Flying
Gordon Anderson
#41015, Switzerland
Empennage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Dawson-Townsend,Timothy
TDT
Tim Dawson-Townsend
40025
0123456789
