n395v
Posted: Tue Apr 18, 2006 3:54 am Post subject: 14V from 28V system |
I am building a 28V system and have some items that will be 14v others that can go 28 or 14V.
Is it better to use a 28-14v converter or use 2 14 V batteries in series and tap off the center?
_________________ Milt |
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Apr 18, 2006 5:49 am Post subject: 14V from 28V system |
N395V wrote:
It is much better to use a converter or, better still, an equalizer.
The problem with center tapping the batteries is that you will force the
lower battery into an undercharged state and the upper battery into an
overcharged state. You will quickly destroy the upper battery and the
lower battery will permanently suffer a loss of capacity leading to its
early failure. And when I say "early" I am talking on the order of 40
hours or less.
There are a number of companies making switching-type DC-DC converters
that are very efficient. The only problem is that they become a single
point of failure in your system. If that converter fails you have no 14V
for anything that needs it.
Better still is a battery equalizer. This device connects across your
pair of batteries and to the center tap between them, i.e. to ground, to
the center tap, and to the 28V bus. It is a converter but it maintains
the center tap at exactly 1/2 the voltage of the hot lead. The equalizer
serves three purposes:
1. it ensures that both batteries charge equally and neither overcharges
at the expense of the other;
2. it carries the load for your 14V devices ensuring that you don't
damage either battery;
3. if you lose the charging system it makes the energy from both
batteries available for your 14V loads.
And if the equalizer fails you still have the lower battery available to
provide power to your 14V loads. Sure it is hard on the batteries but it
will allow you to finish your flight without losing your 14V loads.
I have used equalizers from Sure Power Industries. Their equalizers
range from 30A to 100A. See: http://www.surepower.com/conv.html.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
n395v
Posted: Tue Apr 18, 2006 6:46 am Post subject: Re: 14V from 28V system |
Brian,
Thanks the equalizer looks just like what the Dr ordered.
Do not Archive
