yakplt(at)yahoo.com Guest
Posted: Thu Apr 01, 2010 2:53 pm Post subject: How it is in England |
Richard Goode, can you comment on this please?
So, a YAK-50 flying straight and level goes dead at 600 hours? NICE! What the heck, over?
Mark Bitterlich
United Kingdom
Civil Aviation Authority
Issue Date: 18 September 2009
MANDATORY PERMIT DIRECTIVE
In accordance with Article 11(6)(a) of the Air Navigation Order 2005 as amended the following action required by this Mandatory Permit Directive (MPD) is mandatory for applicable aircraft registered in the United Kingdom operating on a UK CAA Permit to Fly.
MPD: 2002-009R2 YAKOVLEV
Airframe Life Limitation
Yakovlev Yak-50 aeroplanes
Reason:
It has been identified that this aeroplane type is subject to an airframe life limitation. This MPD is raised to Revision 2 to remove references to overhaul life and relax the calendar aspect of the airframe life limitations. In addition this revision allows an alternative means of obtaining an airframe life extension to that provided by Yakovlev Design Bureau (YDB) and applies a new 600 hour interim airframe life limit which could be increased subject to appropriate approvals.
Correspondence with the Design Authority, Yakovlev Design Bureau (YDB), has confirmed that there is an initial airframe life limit of 300 hours from new.
This initial 300 hour airframe life limit can be extended to a maximum of 600 hours (interim airframe life limit) by the implementation of an approved maintenance and inspection programme. In the absence of airframe life extensions being granted by YDB, this 600 hour interim airframe life limit has been applied pending further review of what maintenance and inspection programme would be appropriate to extend the limit beyond this value.
Compliance:
Before further flight from the original effective date of this MPD, determine the total airframe hours of the individual aeroplane.
No action is required until the aeroplane reaches 300 airframe hours.
radiopicture
Posted: Thu Apr 01, 2010 4:15 pm Post subject: How it is in England |
Sounds to me like there's a provision to extend beyond 600 hours (see end of paragraph one in the "Reason" section). Maybe Richard knows what "appropriate means and how to get them from the UK CAA (recurrent inspections, etc?). We would have no such restriction in the US, knock on wood. The life limits described by the YDB usually seem to assume unlimited, violent Russian-style akro. Unless I'm mistaken, In the Russian system, Yak-52 life limits could be renewed after comprehensive inspection. They loved to keep everyone busy.
Mark Bitterlich
United Kingdom
Reason:
Compliance:
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
| [b]
Posted: Fri Apr 02, 2010 5:37 am Post subject: How it is in England |
Just have to hope the FAA does not get involved with this.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: Thursday, April 01, 2010 5:53 PM
To: yak-list(at)matronics.com
Subject: How it is in England
Mark Bitterlich
United Kingdom
Reason:
Compliance:
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
richard.goode(at)russiana Guest
Posted: Fri Apr 02, 2010 5:57 am Post subject: How it is in England |
Yes,it is a fact that the total design life was 300 hours,and 47 hours [yes,47] for those 50s in the soviet team.
BUT this was continuous aerobatics,and most flights at 9G.,and often more.
But also remember that this was with the small fuel tank only;generator/compressor removed,and and a MAXIMUM weight for the pilot and chute of 100kilos-220lbs.
So the CAA is being cautious and you will see that the 600 is the interim limit,which will be extended.
In any case each 100 hours we must remove wings;engine ;tail and then do a detailed X-Ray and crack-test inspection.
Also,the 50 will last forever at 6G,but will not at 8/9G,particularly with lots of fuel;extras;"big mac"style pilots etc.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Posted: Fri Apr 02, 2010 6:14 am Post subject: How it is in England |
Well being one of those 100 kilo pilots that tries to limit his G excursions to 6.0 with an occasional 6.5 G.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: Friday, April 02, 2010 8:57 AM
Subject: Re: How it is in England
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
----- Original Message -----
Sent: Friday, April 02, 2010 2:35 PM
Subject: RE: How it is in England
Doc
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Mark Bitterlich
United Kingdom
Reason:
Compliance:
| Quote: | | http://www.matronics.com/Navigator?Yak-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0
dangerous content by the Invictawiz MailScanner
and is believed to be clean.
http://www.invictawiz.com/
-------------------------------------------------- | 123456789 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 1 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 2 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 3 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 4 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 5 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 6 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 7 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 8 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 9 | Quote: | | http://forums.matronics.com | 0
Posted: Fri Apr 02, 2010 9:34 am Post subject: How it is in England |
All excellent points, which is why I was asking.
Knock on wood is right! Oh man.
Mark
Posted: Fri Apr 02, 2010 9:38 am Post subject: How it is in England |
Thank you as always Richard.
One other question. Have there been many 50's that you have seen that
have failed any of these detailed X-Ray and crack test inspections and
if so, can we see some of those results, or at least get more
knowledgeable about them?
Roger on 6G's. You listening Wizard?
"Big Mac" style pilots. I resemble that remark. Sigh....
Mark
Posted: Fri Apr 02, 2010 10:09 am Post subject: How it is in England |
No 50 has failed anything serious [yet!].
We are talking to our CAA and to Yakovlev in Moscow who have said they will help with a similar programme to go beyond 600.
The real problem has been to get them to understand that it is possible to fly a 50 for fun and not just to win a championship.
52s were different-the Soviet total life was 1500 hours,and they all had a total remanufacture at 500 hours,with a possible extension to 600.
Then we came and took most 52s away before any had got near 1500 so no further limit has been set!
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Posted: Fri Apr 02, 2010 10:23 am Post subject: How it is in England |
THANK YOU FOR THAT INFO!
Mark
