Richard Pike
Posted: Tue Apr 06, 2010 2:06 pm Post subject: 4:1 C box |
Got a chance to pick up a 4:1 C box fairly reasonably, idea is to reduce prop speed ~ prop noise. Anybody on the list using one on a 582, and what sort of prop are you using?
How do you like it?
Don't want to waste money experimenting if somebody else has already established it doesn't work...
Richard Pike
MKIII N420P (420ldPoops)
rickofudall
Posted: Tue Apr 06, 2010 3:15 pm Post subject: 4:1 C box |
I have a 4:1 gearset in a "C" box driving a 66" Warp Drive prop. I like it, seems to work good. People tell me it's relatively quiet for a 2 stroke. Even though my Mk III is a bit heavy at 545 lb. empty it climbs like the proverbial homesick angel. Flying single I cannot get a departure stall to break, it just bobs the nose a bit.
Rick Girard
On Tue, Apr 6, 2010 at 5:06 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
How do you like it?
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293242#293242
le, List Admin.
Posted: Tue Apr 06, 2010 3:32 pm Post subject: 4:1 C box |
Rick Girard
Rick G/Gang:
That is normal performance for all models of Kolb aircraft.
john hauck
mkIII - 2,994.0 hours
912ULS - 424.8 hours
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Tue Apr 06, 2010 3:56 pm Post subject: Re: 4:1 C box |
| rickofudall wrote: | I have a 4:1 gearset in a "C" box driving a 66" Warp Drive prop. I like it, seems to work good. People tell me it's relatively quiet for a 2 stroke. Even though my Mk III is a bit heavy at 545 lb. empty it climbs like the proverbial homesick angel. Flying single I cannot get a departure stall to break, it just bobs the nose a bit.
Rick Girard
[b] |
Two or three blade? What rpm at various cruise speeds? Max speed at what rpm?
Richard Pike
rickofudall
Posted: Tue Apr 06, 2010 6:36 pm Post subject: 4:1 C box |
It's a three blade with straight blades and square tips. I get 82 IAS at 6200 RPM, but I run 62 IAS at 5200 mostly for economy and longevity and almost never go above 5600 RPM in level flight.
Rick
On Tue, Apr 6, 2010 at 6:56 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote] --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
> Rick Girard
> do not archive
> [b]
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293261#293261
le, List Admin.
Richard Pike
Posted: Tue Apr 06, 2010 7:19 pm Post subject: Re: 4:1 C box |
| rickofudall wrote: | It's a three blade with straight blades and square tips. I get 82 IAS at 6200 RPM, but I run 62 IAS at 5200 mostly for economy and longevity and almost never go above 5600 RPM in level flight.
Rick
[b] |
Thanks, that's exactly what I wanted. Now All I have to do is see if I can change my 2 blade Ivo to a 3 blade and use it, or do I need to sell the Ivo and go to a 3 blade Warp.
(Which will make John SO pleased... <grin>)
Richard Pike
HShack(at)aol.com Guest
Posted: Wed Apr 07, 2010 6:53 am Post subject: 4:1 C box |
I would go with a 68" 3 blade...........
In a message dated 4/6/2010 11:20:03 P.M. Eastern Daylight Time, richard(at)bcchapel.org writes:
| Quote: | | Now All I have to do is see if I can change my 2 blade Ivo to a 3 blade and use it, or do I need to sell the Ivo and go to a 3 blade Warp |
Richard Pike
Posted: Wed Apr 07, 2010 8:18 am Post subject: Re: 4:1 C box |
| HShack(at)aol.com wrote: | I would go with a 68" 3 blade...........
Currently using a 68" Ivo 2 blade. If I could simply add another blade, that would be ideal. Will call Ivo and ask them.
Richard Pike
Richard Pike
Posted: Wed Apr 07, 2010 12:41 pm Post subject: Re: 4:1 C box |
End of the line - Ivo said no. The U/L prop will not work on the 3.47 or 4:1 ratio gearboxes. Would have to upgrade to a stronger prop than the U/L unit, & that is too much money for what I want. Think I'll just get a good ANR headset instead.
Thanks anyway guys for helping, at least I know more now than I did.
Richard Pike
rickofudall
Posted: Wed Apr 07, 2010 1:55 pm Post subject: 4:1 C box |
Richard, Sounds like a good reason to put the Ivo on eBay and use the money to get a WD. MHO.
Rick
On Wed, Apr 7, 2010 at 3:41 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293398#293398
le, List Admin.
elleryweld(at)aol.com Guest
Posted: Thu Apr 08, 2010 1:45 am Post subject: 4:1 C box |
Richard
if you want to trade your IVO for a 3 blade warp Talk to me
Ellery Batchelder Jr.
