First Flight
vk3eka(at)bigpond.net.au
PostPosted: Fri Apr 16, 2010 12:36 am    Post subject: First Flight Reply with quote
Hi Guys,
A good day today, my 601XL completed its first flight today with no problems. I had the elevator trim wired incorrectly and up was down, down was up which made for an interesting flight. I also need to re-pitch the prop a bit to give a bit more rpm on takeoff.
I’ll post a couple of pics later.
Anybody out there using a 68” three blade warp drive on an O-200, I would be interested to know what pitch angle the prop is set to.
What a beautiful airplane to fly, Keep at it guys.
Cheers
Peter
Wonthaggi Australia.
http://zodiac.cpc-world.com
Scotsman
PostPosted: Fri Apr 16, 2010 3:19 am    Post subject: Re: First Flight Reply with quote
Congratulations mate....a bit envious though! Please post pics
Cell +27 83 675 0815
johnd
PostPosted: Fri Apr 16, 2010 4:57 am    Post subject: First Flight Reply with quote
Hi Peter,
Congrats on your first flight, mine was just over a year ago and I still have fond memories. Have Fun with your new bird and stay safe!
John Davis
N601JD - 601XL - Jab 3300
7A8 - Avery County Airport
On 4/16/2010 4:30 AM, Peter W Johnson wrote: [quote] <![endif]--> <![endif]-->
Hi Guys,
Cheers
Peter
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
Ron Lendon
PostPosted: Fri Apr 16, 2010 6:42 pm    Post subject: Re: First Flight Reply with quote
Congratulations Peter.
Maybe the Elevator was wired for the North. Chris Heintz is from the other side of the equator ya know.Very Happy
Good on Ya,
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Ken
PostPosted: Sun Apr 18, 2010 7:13 am    Post subject: Re: First Flight Reply with quote
It sounds like you have the identical prop I'm putting on an O-235. What is your pitch setting? I set mine at 12 degrees but have no idea if I'm even in the ball park.
PostPosted: Sun Apr 18, 2010 2:04 pm    Post subject: First Flight Reply with quote
Ken,
I originally had it setup with 15 degrees of pitch which equated to 56
inches of pitch. After some testing, I have adjusted it back to 11 degrees
of pitch. I did a flight test just prior to the last adjustment and things
are much better. I hope to get a flight test today to confirm the 11 degrees
is good.
When I ordered the prop from Warp Drive, they suggested a 68 inch was a good
cruise prop, with a 66 inch being better in climb. Certainly a shorter prop
will give more rpm at static.
Cheers
Peter
burbby
PostPosted: Tue Apr 20, 2010 6:04 am    Post subject: First Flight Reply with quote
Congratulations Peter: Well done --- hope all goes well during testing.
Gary
--- On Fri, 4/16/10, Peter W Johnson <vk3eka(at)bigpond.net.au> wrote:
Subject: First Flight
To: zenith-list(at)matronics.com, zenith601-list(at)matronics.com
Date: Friday, April 16, 2010, 3:30 AM
Hi Guys,
Anybody out there using a 68� three blade warp drive on an O-200, I would be interested to know what pitch angle the prop is set to.
Cheers
Peter
el=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
s.clive.richards(at)homec
PostPosted: Fri Apr 23, 2010 11:58 am    Post subject: First Flight Reply with quote
Peter Congratulations on first flight
    We used 13 degrees with a 66 inch 3 blade on Rays 601 HD so it should be less than that.
Are you aware that Warp Drive recommend a minimum idle speed of 1000 rpm to prevent the blade route aluminium ferrules from cracking from engine pulses we did not and they replaced our blades.
We have now changed to a 66x52 wooden prop as 1000 rpm gives a high taxi speed, our original prop was a 68 inch but found the ground clearance insufficient on the HD
Clive
G CBDG 601 Hd Cont 0-200 350 Hrs
PostPosted: Sun Apr 25, 2010 3:57 am    Post subject: First Flight Reply with quote
Clive,
Thanks. I have set the pitch to 11 degrees at present and seems about right. I’ll keep an eye on it and maybe change it again after a few more hours.
I wasn’t aware of the 1000rpm min idle speed but I keep mine more than that anyway (C150 many years ago!!). I have noticed its pretty easy to fat taxi the XL.
I’m still loving it!!!
Cheers
Peter
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Clive Richards
Sent: Saturday, 24 April 2010 5:58 AM
Subject: Re: First Flight
Clive
----- Original Message -----
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com) ; zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
Sent: Friday, April 16, 2010 9:30 AM
Hi Guys,
Cheers
Peter
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
