rvdave
Posted: Thu Apr 22, 2010 5:05 pm Post subject: cover or paint screws |
Prepping doors after getting seals and pins fit, now wondering whether to cover screws, should I assume never needing to remove door handles and pin blocks, or is there reason to believe I will need to at some point remove the screws? I realize though that the screws do not take and hold paint well and think a smooth door would look better. I don't recall looking that close at other 10s to see what others are doing. Any opinions?
_________________ Dave Ford
Cadillac, MI |
AirMike
Posted: Thu Apr 22, 2010 6:23 pm Post subject: Cover or paint screws |
Most are epoxying and painting over the screws. It is not a big deal, but it provides a more finished look. It is a bit iffy that the paint/epoxy hold when/if the doors are removed and the bolts are re torqued.
This is a good opportunity to pound my drum to those novices in the build process to take a lot (I mean hundreds) of pictures from every angle of the RV10's that you see when you go to OSH or sun-n-fun. Especially focus on pictures under the cowl on these planes. Looking at these pictures will save you much angst in the build process when you can visually see what others have done.
_________________ See you OSH '18
Q/B - sold. |
partner14
Posted: Fri Apr 23, 2010 3:05 am Post subject: cover or paint screws |
If you're going to cover them up..... make sure those nice round heads of the countersunk screws are no longer nice and round when installed.... grind the sides into a square.... less likely to spin when/if removal and reinsalling is necessary.
Don McDonald
--- On Thu, 4/22/10, AirMike <Mikeabel(at)Pacbell.net> wrote:
Quote: |
Subject: Re: cover or paint screws
Date: Thursday, April 22, 2010, 7:23 PM
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
OSH '10 or Bust
Q/B - phase 1 / painting
http://forums.matronics.com/viewtopic.php?p=295348#295348http://www.matronics.com/Navigator?RV10-Lis --> http://forums.matronbsp; - List Contribution Web Site -http://www=======================
40636 |
Posted: Fri Apr 23, 2010 3:23 am Post subject: cover or paint screws |
I'd probably cover the pin blocks, but not the screws holding the latch in place. IMHO there's too much chance of removal on the latch mechanism screws. Also, as was already suggested, you can remove the nuts in a pinch on the pin blocks if you have secured the screws well enough, and possibly squared off the head a little, but you have to remove the door handle with the screws.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Apr 22, 2010, at 9:05 PM, rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=295336#295336
