Cameras
drc(at)wscare.com
PostPosted: Tue Apr 27, 2010 9:23 am    Post subject: Cameras Reply with quote
Here are pics of the install
I also have a helmet cam. CONS: it looks where I look so always changing view. It needs a recording device attached to it like a camcorder.
PROS: cheap, I bought used for $150. It can be used in different planes.
I like the look of the vholdr from McGirt. It has the recording device integrated in.
3 cameras All can be adjusted to different views
A 4th camera is on the front screen just to the left of the wet compass. Normally aimed to the left wing tip.
[img]cid:30DFCF5C-FC35-49D5-933C-D32A2BC01899(at)myhome.westell.com[/img]
Hard drive with input cable on left side. Can be removed and downloaded on computer.
[img]cid:4A73A35D-FC2C-4789-88E3-E6A4E3208555(at)myhome.westell.com[/img]
Multiplex behind pilot. All 4 cameras can be shown on same screen. Or just 1, or PIP, etc.
[img]cid:66F72527-DB95-4856-AF67-3C9EC01FE0E3(at)myhome.westell.com[/img]
 Filesize:  112.64 KB
 Viewed:  1524 Time(s)
 Filesize:  119.28 KB
 Filesize:  110.99 KB
