D-sub questions
rparigoris
PostPosted: Wed May 05, 2010 9:46 am    Post subject: D-sub questions Reply with quote
Hi Group
I have a few questions about D-sub connectors:
**How many amps are each pin good for using the nice machined pins?
**How many amps are each pin good for using solder on pins?
**I want to run my Ray Allen pitch and roll servo wiring through D-sub connector. Would it be advisable, especially on the pitch to parallel two pins?
**I need to run 4 shielded wires out on my instrument module (2ea. mic and speaker). I would like to use a D-sub connector on the bottom port side of my instrument module to allow easier instrument module removal and install. Thus there will be a few inches of unshielded wires at the connector:
$$Should I use D-sub shielded shells? This D-sub connector is about 5" away from my Dynon D-10A
**I have a single point ground on firewall with field of tabs. I think I remember seeing for avionics and instruments (can't find it) a D-sub connector with perhaps 3 or 4 wires going to field of tabs, and all the pins connected to one side to those 3 or 4 wires to make a field of pins to be used for single point ground. Is this acceptable for grounding on the same connector:
$$mic and speaker shield?
$$Radio and transponder grounds?
$$Instrument grounds?
Thx.
Ron Parigoris
PostPosted: Wed May 05, 2010 7:41 pm    Post subject: D-sub questions Reply with quote
At 12:46 PM 5/5/2010, you wrote:
<rparigor(at)suffolk.lib.ny.us>
Hi Group
The continuous rating for individual pins is 7A
Same . . .
You can run a LOT of current through a D-sub connector. See:
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/Paralleled_D-Sub_Pins.jpg
I used this technique to run 20+ amps through D-subs on
this vehicle's . . .
http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg
DC power distribution assembly . . .
http://aeroelectric.com/Pictures/Misc/GQM_Power_Dist.jpg
which featured solid state switching. In this application,
we de-rated pins to 4A each and paralleled 5 pins for
the 20A conductors. The de-rating was in recognition of
our 70C max operating environment.
parallel two pins?
Can't think of a good reason why.
No, take shields through the connectors on their
own pins. Actually, these signals can be carried
very nicely on twisted pairs and/or trios with
no shielding but if you choose to shield, treat
the shields as separate conductors.
FOLLOW THE WIRING DIAGRAM FOR THE PRODUCTS YOU
ARE INSTALLING.
Shields on wires that run between black boxes
GENERALLY terminate on either some specific pin
in a connector or the connector's back-shell.
They NEVER get long pigtails off to some remote
ground location.
The grounding configurations shown in Appendix Z
are for accessory power grounds, not system signal
or shield grounds.
