jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Sat May 15, 2010 3:36 pm Post subject: Transponder Antenna Location |
We have been told on more than one occasion that ATC was not seeing our transponder. We have a Garmin GTX327 installed. We are wondering if our antenna location might be the problem, our antenna is located in the center of the airplane just behind the firewall. At the time we installed the antenna it looked like a good spot, but that was before we had the exhaust installed. Not sure if the location is the problem or not, just wondering of anyone else has experienced any problems with the antenna in this location. Thoughts appreciated.
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Sat May 15, 2010 3:51 pm Post subject: Re: Transponder Antenna Location |
I doubt that's the problem.. Mine's on the right side.. maybe 10 inches to the right of the centerline (so it's not in the exhaust path)... and it works perfect.. never skipped a beat..
Have you had your txp checked per 91.413? Did it pass that inspection?
_________________ RV-7A
N777TY |
jkreidler
Posted: Sat May 15, 2010 4:10 pm Post subject: Re: Transponder Antenna Location |
Yes, we had it inspected.
Our antenna is between the exhaust stacks and the exhaust exits behind the antenna.
Dick Sipp
Posted: Sat May 15, 2010 5:01 pm Post subject: Transponder Antenna Location |
I occasionally get the same complaint. I would say on about 5-10% of the
controller changes. It seems to occur more often when headed directly at
the antenna sight and long or short range only rather than medium. It
almost always returns for the controller as the position relative to the
sight changes. The antenna is on the belly centerline about 14 inches aft
of the firewall.
Dick Sipp
N110DV
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Sent: Saturday, May 15, 2010 7:37 PM
Subject: Transponder Antenna Location
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=297856#297856
Kelly McMullen
Posted: Sat May 15, 2010 5:02 pm Post subject: Transponder Antenna Location |
It is possible the exhaust stacks are shielding the antenna in that
case. Shouldn't be to hard to patch that hole and move antenna a foot
or so to right or left of exhaust.
On Sat, May 15, 2010 at 5:10 PM, jkreidler
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=297859#297859
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Sat May 15, 2010 5:07 pm Post subject: Transponder Antenna Location |
I'd be checking the antenna cable before I worried about the antenna
location. It isn't unusual to find a loose antenna cable in those
situations. If nothing obvious, ask avionics shop to do a field check
of the transponder, where they observe the output with a small
handheld receiver that will indicate output power. You should have had
a check like that very early in your flight test phase.
On Sat, May 15, 2010 at 4:37 PM, jkreidler
Jason Kreidler
KCHD |
coop85(at)verizon.net Guest
Posted: Sat May 15, 2010 5:32 pm Post subject: Transponder Antenna Location |
Mine is in the same location, about a foot aft of the firewall, with the
same xpdr. No issues to date with 450 hours.
Marcus
Just speculating, but I wonder with your antenna that far forward if you are
getting some issues from the exhaust pipes? As I mentioned previously mine
is a bit further back and while it does get a little dirty, it works great.
Marcus
Posted: Sat May 15, 2010 5:33 pm Post subject: Transponder Antenna Location |
I've never seen a problem with the antenna right where you have it. I'd also check the coax running to the antenna. How high do you normally fly?
The only problem I've noticed is in a specific area about 50 miles east of our home airport here, so it could have something to do with the radar coverage. I assume you've already verified that it isn't always in the same geographic area.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On May 15, 2010, at 7:37 PM, jkreidler wrote:
Jason Kreidler
jkreidler
Posted: Sat May 15, 2010 5:52 pm Post subject: Re: Transponder Antenna Location |
Kelly, we did have the typical inspection performed where he sets up a tests apparatus, but that is done in the shop. Is there another way they test?
We have not narrowed it to a specific geographic location, it seems to happen at random. Our suspicion is that the antenna is being shadowed by the exhaust pipes. We were going to move the antenna back a foot or so, but wanted to get some feedback before making an assumption that that is the real problem. If others have it in the same location and are not having the problem then we would need to dig deeper. We did verify the cables and connections were good.
Kelly McMullen
Posted: Sat May 15, 2010 6:18 pm Post subject: Transponder Antenna Location |
Yes, there is a hand held ramp checker. They are supposed to test the
full system, which means receiving the signal from the antenna, not
connected to a load on the bench.
On Sat, May 15, 2010 at 6:52 PM, jkreidler
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=297869#297869
KCHD |
jkreidler
Posted: Sat May 15, 2010 6:34 pm Post subject: Re: Transponder Antenna Location |
They did test the transponder in the airplane with a receiving unit set up away from the airplane in the hangar. Not a bench test...
speckter(at)comcast.net Guest
Posted: Sun May 16, 2010 5:09 am Post subject: Transponder Antenna Location |
I have mine on the centerline just aft of the fire wall. Mine too looks
like the exhaust might block some of the signal, but it has worked fine all
the time. Mine is quite far forward before the pipes get very far down
along the sides of the antenna. I have the big Forsling exhaust that is
about 3" in diameter at the end.
Gary Specketer
jcumins(at)jcis.net Guest
Posted: Mon May 17, 2010 6:57 am Post subject: Transponder Antenna Location |
Being a RF guy that does a lot of radio work for my company. I would not
place any antenna between the Exhaust stacks you are blocking the radiation
of the antenna a lot. Metal will reflect the radiation of the transmit.
Move the antenna to the far Right or Left and I bet it will work much
better.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94534
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
