woxofswa
Posted: Thu May 20, 2010 1:38 pm Post subject: Cabin cover/tailcone joint |
From what I have seen, most guys are glassing over the joint between the aft cabin cover and the tailcone joint.
I haven't yet found guidance for that in the plans anywhere. Is there guidance somewhere that I haven't found or is it builder's choice?
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Deems Davis
Posted: Thu May 20, 2010 2:59 pm Post subject: Cabin cover/tailcone joint |
Builders Choice.
Deems Davis
On 5/20/2010 2:38 PM, woxofswa wrote: [quote] Quote: | --> RV10-List message posted by: "woxofswa" <woxof(at)aol.com> (woxof(at)aol.com)
Quote: | From what I have seen, most guys are glassing over the joint between the aft cabin cover and the tailcone joint.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p=298362#298362
| [b]
dlm46007(at)cox.net Guest
Posted: Thu May 20, 2010 3:25 pm Post subject: Cabin cover/tailcone joint |
You might want to consider glassing over all the rivets (solids or blinds)
imbedded in fiberglass (lid and cowl?). If you don't, you can count on
seeing them again in about a hundred hours or so. Rivet heads will pop
through the paint.
johngoodman
Posted: Thu May 20, 2010 3:30 pm Post subject: Re: Cabin cover/tailcone joint |
You'll discover that there's a tiny angle change there anyway. Perfect for filling. Just run a couple of strips of tape a couple of inches away on either side for a stop so you don't have "feathering to infinity."
AV8ORJWC
Posted: Thu May 20, 2010 11:03 pm Post subject: Cabin cover/tailcone joint |
Showplanes is coming out with a composite transition all the way to the vertical. Might even make it as nice as if Geoff had done it.
John Cox
Sent: Thu 5/20/2010 4:24 PM
Subject: RE: RV10-List: Cabin cover/tailcone joint
[quote]--> RV10-List message posted by: "DLM" <dlm46007(at)cox.net> You might want to consider glassing over all the rivets (solids or blinds) imbedded in fiberglass (lid and cowl?). If you don't, you can count on seeing them again in about a hundred hours or so. Rivet heads will pop through the paint. --
