smirdrv(at)hotmail.com Guest
Posted: Sun May 30, 2010 10:33 pm Post subject: Mags: Ignition |
I recently spoke to the mechanic who is checking out my mags..... says they're in good shape and only need the oil seals replaced. My FWF system definitely needs the shower of sparks to run. So if anyone has one they're not using, or know of one available, let me know. One other question..... Tony B's FWF Book shows a diagram of an Ignition set up with S.O.S. using a Key Ignition Switch. Is it possible to use the S.O.S. using Toggles for the power management? If so, does someone have a schematic of how to wire it up? Thanks in advance.
R.C.
The New Busy is not the old busy. Search, chat and e-mail from your inbox
rickpegser(at)yahoo.com Guest
Posted: Mon May 31, 2010 7:45 am Post subject: Mags: Ignition |
check here
www.tcmlink.com/pdf2/SIL648.pdf
rick
--- On Sun, 5/30/10, R.C. Flyer <smirdrv(at)hotmail.com> wrote:
Subject: Mags: Ignition
To: rv-list(at)matronics.com
Date: Sunday, May 30, 2010, 11:29 PM
I recently spoke to the mechanic who is checking out my mags..... says they're in good shape and only need the oil seals replaced. My FWF system definitely needs the shower of sparks to run. So if anyone has one they're not using, or know of one available, let me know. One other question..... Tony B's FWF Book shows a diagram of an Ignition set up with S.O.S. using a Key Ignition Switch. Is it possible to use the S.O.S. using Toggles for the power management? If so, does someone have a schematic of how to wire it up? Thanks in advance. R.C.
The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started. | Quote: |
=nofollow target=_blank>http://www.matronics.com/Navigator?RV-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
