flysrv10(at)gmail.com Guest
Posted: Wed Apr 19, 2006 9:03 am Post subject: empty weight |
Hello everyone. Just weight my plane, empty, no paint. 1558 pounds.
I wonder how it compares with the guys taht are flying.
Do not archive.
Randy(at)abros.com Guest
Posted: Fri Apr 21, 2006 9:11 am Post subject: empty weight |
ROB, mine came in at 1592 without wheel pants. 1626 with. Randy N610RV
Posted: Fri Apr 21, 2006 3:13 pm Post subject: empty weight |
Thanks Randy. Vans Site says 1500 empty. It was puzzeling since the
weight on the 10 should be very close as avionics is almost the only
variable. I started doubting the scale.
Do not archive.
LarryRosen
Posted: Fri Apr 21, 2006 4:55 pm Post subject: empty weight |
Tim 1,685
Randy 1,625
Vic 1,665
Chuck 1,615
Rob 1,558
Chuck and Vic weight from <http://www.rvproject.com/wab/>
Rob, looks like you have the light weight machine. Which prop? With or
without wheel pants?
Larry Rosen
http://lrosen.nerv10.com
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tdawson(at)avidyne.com Guest
Posted: Fri Apr 21, 2006 5:05 pm Post subject: empty weight |
Batteries can make a difference . . . .
TDT
Posted: Fri Apr 21, 2006 5:53 pm Post subject: empty weight |
I have the Hartzell prop. Two GRTs, SL30, SL40 along with a TXP and
an audio panel. The wieght included everything except the paint and
the radios. It included the GRTs. I have a Sears wheelchair battery
(included in the weight also).
This is not a fiberglass plane where there is the possibilty of large
variations between plane weights. I weight the plane with (I believe)
a very accurate racing car scales. Perhaps the discrepency is in our
scales.
I had plans for the first flight tommorow. It is postponed to Sunday.
Do not archive.
On 4/21/06, Larry Rosen <LarryRosen(at)comcast.net> wrote:
Tim 1,685
Randy 1,625
Vic 1,665
Chuck 1,615
Rob 1,558
Larry Rosen
PILOTDDS(at)aol.com Guest
Posted: Mon Apr 24, 2006 4:57 am Post subject: empty weight |
Mine weighed 1613 with dual batteries and paint .No wheel pants
Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Apr 24, 2006 5:12 am Post subject: empty weight |
I would like to get an idea what Gross Weight everyone has
registered there plane for?
Thank You
Ray Doerr
40250 (At the airport and wings are on)
Posted: Mon Apr 24, 2006 6:15 am Post subject: empty weight |
Thanks for the info. I will keep everyone posted as it the plane gets
paint and gets fatter with stuff.
On 4/24/06, PILOTDDS(at)aol.com <PILOTDDS(at)aol.com> wrote:
| Quote: | Mine weighed 1613 with dual batteries and paint .No wheel pants
