gcomfo(at)tc3net.com Guest
Posted: Wed Jun 09, 2010 4:43 pm Post subject: fuel selector-(both) |
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Speedy11(at)aol.com Guest
Posted: Thu Jun 10, 2010 6:38 pm Post subject: fuel selector-(both) |
Gordon,
Thanks for your RV-4 info.
I have 84 hours and I'm doing my first annual condition inspection and I have had no significant problems with the both fuel selection on my RV-8A. The right wing will feed slightly more than the left, but that is likely due to a slight skid. I have burned the tanks down to 4.5 G remaining overhead my airport. Remaining was 2.9 in the left tank and 1.6 in the right. Further, I have run one tank dry on the ground in both position (engine faltered as it began to draw air from empty tank) and switched to the left tank (which still had fuel) and the engine kept running.
I have had no indications of vented fuel at either the tank lid or the fuel vents.
So, my confidence level is high regarding use of the both selection on my RV-8A. It is a pleasure not having to constantly worry about switching tanks.
I intend to do skidding flight tests (flying most of a flight in an intentional skid) to evaluate tank feed.
If I discover a significant problem in the suture related to the both position, I can always fall back to using Left-Right like other RVs.
During the building process, I took special care to make the feed lines from each tank the same length and using the same degrees of total bends (no small feat) in order to ensure there was no imbalance caused by higher viscosity on one side. With a RV-6/7/9, the fuel lines are already even from both sides so that problem is resolved.
Stan Sutterfield
www.rv-8a.net
| Quote: | Stan: You may be fine with a "both" position but my experience with the
RV-4 was not. If you haven't already, I suggest an in flight test. With
the -4 I found that fuel would flow from the dominant tank to the other and
when it (the other) was full, fuel went overboard. The transfer was rapid
enough that ~4 gal was transferred in about 15 minutes. Fuel can emerge
from the cap, flow to the flap gap and then flow inboard to the
wing/fuselage gap.
Gordon Comfort
N363GC
