Rotax 914 internal generator
rparigoris
PostPosted: Sun Jun 13, 2010 5:49 pm    Post subject: Rotax 914 internal generator Reply with quote
Hi group
I am using Eris Jones Linear Over-Voltage Protector to control my Rotax 914 internal generator through a 75 amp automotive relay.
At moment I have relay on my schematic downstream of the Ducati regulator. If regulator fails and there is in fact a runaway over volt event, true the L OVP device will disconnect it from my electrical system, but the generator will still be outputting.
Do you think I would be better off moving the relay that is controlled by the L OVP to be in series with one of the generators yellow output wires?
Here is my schematic with relay downstream of Ducati regulator:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=80372&g2_imageViewsIndex=0
Please click drop down to get higher resolution of 2592 x 1944.
Thanking you in advance.
Ron Parigoris
PostPosted: Mon Jun 14, 2010 5:37 am    Post subject: Rotax 914 internal generator Reply with quote
At 08:49 PM 6/13/2010, you wrote:
<rparigor(at)suffolk.lib.ny.us>
Hi group
That is a better place to "shut the system" down.
See:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf
rparigoris
PostPosted: Mon Jun 14, 2010 9:11 am    Post subject: Re: Rotax 914 internal generator Reply with quote
Hi Bob
"That is a better place to "shut the system" down.
See:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf"
OK I will place relay at yellow wire.
How many AC volts, and how many AC amps should the contacts of the relay be rated to "break" at?
Thx. again
Ron Parigoris
PostPosted: Mon Jun 14, 2010 10:20 am    Post subject: Rotax 914 internal generator Reply with quote
Hi Bob
See:
The relay you called out on the DC side of
the rectifier/regulator will be fine.
AC is MUCH easier on relays than is DC.
