Robin(at)PaintTheWeb.com Guest
Posted: Thu Jun 17, 2010 11:43 pm Post subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggest |
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=100711999?KEYS=christian_eagle?LISTNAME=RV?HITNUMBER=3?SERIAL=00300129883?SHOWBUTTONS=YES
Mark,
Here is how we drilled and attached our canopy (no cracks)!!
1. We heated the garage to about 90 degress 6 hours prior to starting to
work.
2. We drilled the initial holes with a #40
3. Opened up the #40 hole to the proper size with a Uni-Bit (single flute no
grabbing!
When we installed the canopy and shirt we use semi-weld (Pro-seal) in
caulking type tube that premixes it ( you'll need to use/borrow a
specialized caulking type gun to use the tubed material. We used minimal alu
pop rivets (mostly as keeper riviets). The semi-weld method is the same as
used on the Christian Eagles and Pits (without any rivets). You can also
paint the semi-weld after.
Works and looks great and has some ability to flex (read deal with stress,
Good Building,
Chuck & Dave Rowbotham
RV-8A (Nianitc, CT)
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of MLWynn(at)aol.com (MLWynn(at)aol.com)
Sent: Thursday, June 17, 2010 2:40 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion
Hey gents,
I am at the same spot. Have been considering sikaflex (how I did the canopy) and 3M 5200. Where in the archives would I find this information?
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 6/17/2010 10:54:35 A.M. Pacific Daylight Time, crowbotham(at)hotmail.com (crowbotham(at)hotmail.com) writes:
Hi Robin,
We used the same adhensive that Christian Eagle uses on our 8A. The complete details with product info are in the archives. The RV was hangered in CT and flown on a regular basis through out the year over nine years - No cracks and no change in the seal.
Hope this helps - Keep at it - it's really worth the effort!
RV-8A (Sold)
RV-9A (Dave's building)
Date: Thu, 17 Jun 2010 09:03:30 -0700
Subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion
To: rv-8list(at)matronics.com (rv-8list(at)matronics.com)
It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work?
Robin
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. 01 23 45 | 6789 Day Browse, Chat, FAQ,[/b]p://www.matronics.com/Navigator?RV-List[/quote]012 m">http://forums.matronics.com[/b]p://www.matronics.com/Navigator?RV-List[/quote]34 -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b]p://www.matronics.com/Navigator?RV-List[/quote]5
martinaerodrome(at)gmail. Guest
Posted: Fri Jun 18, 2010 5:09 am Post subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggest |
robin,
10 years ago when I built my RV8, the adhesive process was started. I procrastinated for several weeks trying to decide which process to use ie rivets or adhesive. I used rivets because I did not understand or trust the adhesive process. That was a mistake. No matter how careful you are during the installation, after 100 hours cracks begin to appear from the rivet points.
This forced me to stop drill the cracks. I have watched other installations with adhesive, and I don't see cracks. I noticed after flyinng 2000 hours on my RV8 that the canopy contracts and elongates substantially with weather changes, especially in winter and summer. I live in Wisconsin and it gets cold here in winter. I hope this experience helps you with your decission. I vote for the adhesive process.
Dick Martin
RV8
N233M
the fast one
On Thu, Jun 17, 2010 at 11:03 AM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Robin
t="_blank">http://www.matronics.com/Navigator?RV-List
Posted: Fri Jun 18, 2010 10:43 am Post subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggest |
Thanks Dick,
This morning we ordered two ordered two 2 oz. kits of Scotch weld from Spruce. $35 per kit, but I know it's good stuff, we have used it before. I was not going to use rivets. I remember what rivets did to my RV-4 canopy. Nothing will make you cry quicker than seeing your first crack in a perfectly clean canopy.
Robin
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Richard Martin
Sent: Friday, June 18, 2010 6:06 AM
robin,
Dick Martin
RV8
N233M
the fast one
Robin
Use the Matronics List Features Navigator to browse[/b] | 0 Day Browse, Chat, FAQ,[/b] [/quote]123 m">http://forums.matronics.com[/b] [/quote]45 -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]6
bgray(at)glasair.org Guest
Posted: Fri Jun 18, 2010 1:39 pm Post subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggest |
Over here in the plastic airplane world, the rule is to never drill holes in plexiglass.
Bruce
www.Glasair.org
Posted: Fri Jun 18, 2010 3:01 pm Post subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggest |
Unless you want to stop a crack (probably from the hole you drilled in the plexiglass!)
Scotch Weld it is, no drilling required.
Robin
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Bruce Gray
Sent: Friday, June 18, 2010 1:00 PM
Subject: RE: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion
Bruce
www.Glasair.org
