Jacking Point
Site Admin
PostPosted: Wed Jun 30, 2010 7:01 pm    Post subject: Jacking Point Reply with quote
Okay, so I'm sure this has been asked a few times already, and I should search the archive, but what the heck, let's start a new thread.
I got my new tires today (Goodyear Custom Flight III, btw. Super sweet.) and started looking for ways to get them on. I can really only see two ways to jack the plane up easily with a normal jack.
1) I could put a short saw horse under the wing tie down and then put a hydraulic jack on it and lift the side of the airplane up by this point. If I just gently lift the plane by hand at this point, it seems like that's an awful lot of weight to be lifting that far out on the wing. Can the spars really handle this?
2) I could put a saw horse under the lower engine mount bolt to the firewall and use a hydraulic jack to lift the plane up. This seems less scary, but I question the shear strength of the bolt lifting all of the weight by this single point.
What's the convential wisdom on jacking a tail dragger RV-8 to change the tires? There has to be a way with out building some elaborate dolphin contraption.
BTW, with regards to my tire wear, since there's a fair amount of camber(?) afforded by the Grove gear, I've got nearly all the wear on the outside 50% of the tread. I could probably rotate them 180 degrees and get another 70 hours of flight time, which wouldn't be bad for 22-year old stock kit tires from Van's (remember, I swiped them from the RV-4 project after the brake incident). But, I probably should have rotated them a bit sooner. While there's not cord showing, the tread is gone. Live and learn; I'll be rotating these GYCFIII's in a more timely manner. If I can double my wear life by rotating because of the camber, I might get 1000 hours out of these babies! Wink
RV-8 #82880 N998RV
Status: Enjoying The Fruits of 2500 Hours of Labor!
dsvs(at)ca.rr.com
PostPosted: Wed Jun 30, 2010 8:23 pm    Post subject: Jacking Point Reply with quote
Matt,
I use aircraft wing jacks and lift the plane at the tie downs. No problems
so far. BTW this is a 7 but I know others with 8's that also use ac wing
jacks
