rough running at 3400 RPM and above
Goto page 1, 2  Next
dougsnash
PostPosted: Sun Jul 04, 2010 5:25 pm    Post subject: rough running at 3400 RPM and above Reply with quote
Finally, after just over four years of building I am to the point of test running the engine on my CH-701. Not surprising me at all, I am having an issue or two along the way.
The engine runs great from idle of about 1850RPM up to around 3400 RPM and then starts running rough and bogging out. If I pull the carb heat on or pull on the enrichener I can get it up to about 4000RPM before the roughness starts. This would suggest to me I am running lean.
My engine is a 1999 vintage 912UL with the older style Rotax log carb heat plenum. This was a used engine that I got from a scrapped CH-701. There are about 13 hours on the engine before the plane was damaged and not repaired. The engine was run on a test stand three and a half years ago but has not run since.
So far I have pulled the float bowls off and cleaned out the main and idle jets, removed the gunk from the float bowls, and cleaned the little orifice in the corner of the float bowl. After doing this the engine starts and idles great.
I have done a mechanical syncronization and think I have a fairly good pnumatic one too. At least the needles on the lockwood syncro gauges move at the same time. Not quite the same amount though. If it makes any difference I am running 100LL for test purposes so octane shouldn't be an issue.
Any suggestions as to why I am getting bogging out at 3400 RPM?
Doug MacDonald
NW Ontario, Canada
rickofudall
PostPosted: Sun Jul 04, 2010 7:48 pm    Post subject: rough running at 3400 RPM and above Reply with quote
Doug, Look for gunk around the needle jet, the needle itself and in the main jet. Also make sure the vent tube to the float chamber is clear.  Check the carb connector boots to make sure there are no cracks (you can miss this if you don't take them off and get them up to a strong light). Have you checked the plugs after a run up to where it starts to run rough at 3400 RPM? What EGT and CHT readings are you getting at the stumble point?
If you don't feel comfortable doing a full carb rebuild, you might want to consider having a shop do it.
Rick Girard
On Sun, Jul 4, 2010 at 8:18 PM, MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)> wrote:
[quote] --> RotaxEngines-List message posted by: MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
Doug MacDonald
NW Ontario, Canada
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
http://forums.matronics.com
le, List Admin.
dougsnash
PostPosted: Mon Jul 05, 2010 2:31 am    Post subject: rough running at 3400 RPM and above Reply with quote
Thanks for your reply Richard. A blocked vent tube might be the problem. It seems like a venting issue to me. I don't think the sockets are the source as they are new and are the new style with the spacer on the clamp.
I have not checked the plugs after stumbling yet, I'll try that on the next runnup. They are also new and were gapped as per the manual at installation.
Doug MacDonald
clear.  Check the
can miss this if
light).
stumble point?
you might want to
Rick Girard
rampil
PostPosted: Tue Jul 06, 2010 9:58 am    Post subject: Re: rough running at 3400 RPM and above Reply with quote
Check to make sure there is not soot on the float bowls, a loose exhaust joint could boil the gas on one side when the engine power is set high enough
Ira N224XS
dougsnash
PostPosted: Tue Jul 06, 2010 5:57 pm    Post subject: rough running at 3400 RPM and above Reply with quote
The saga continues...
Tonight I pulled the carbs right off of the plane. I pulled them apart and this time got the float needles right out. There was a small chunk of silicone beside the needle in one of the carbs but after removing it and running the engine, there was little improvment if any. I was able to get it up to 4200 with the enrichener on but only the same old 3400 with the enrichener off.
Other things I have tried is raising the needle one notch to full rich. This also made little to no difference. I stopped the engine while it was misfiring at 3400 RPM and pulled a couple of plugs. They were sooty white so I think we can say that this issue is definately a lean misfire.
I read someplace in the parts manual that there are slightly larger main jets available when you run an air box. Since I have the original cone filters, I removed the airbox and ran it with them (also on the richest needle setting) and again the engine stumbles at about 3400 RPM.
One thought I had tonight after all of this playing around is; is it possible that the throttle shaft o-rings could leak enough to cause this issue? I don't know that they are leaking but given that the carbs are over ten years old, it is possible.
While I had the carbs apart I re-checked all of the other passages and found no buildup in any of them. Getting frustrating but this wouldn't be any fun if it was easy.
Doug MacDonald
CH-701 Scratch Builder
912 UL
NW Ontario, Canada
rickofudall
PostPosted: Tue Jul 06, 2010 7:03 pm    Post subject: rough running at 3400 RPM and above Reply with quote
Have you checked all the pieces of the equalizer line between the two intake manifolds? Try checking the vacuum readings at the equalizer and then at the carb taps with the equalizer line connected to see if there's any gross difference.  As long as you had the carbs off, did you pull the carb sockets and check them? I know you said they are recently replaced, but they're easy to check and it eliminates one more possible source of a leak. There was a bad batch a few years back that rotted out within a year. I couldn't see the cracks in mine until I got them off and used a strong light, then the cracks were obvious.
What about the o-rings at the socket and those on the intake manifolds?
Have you checked the diaphragms in the carb domes? You've had them out to raise the needle did you make sure the tab on the diaphragm is set in the slot in the carburetor body?
Also, from the IPC, there are no o-ring seals on the throttle shafts? Have you miked them to see if the carb body is corroded or rotted out the throttle shaft bore?
Personally, I wouldn't start messing with jetting until you've exhausted every possibility of a gross air leak.
Rick Girard
On Tue, Jul 6, 2010 at 8:57 PM, MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)> wrote:
[quote]--> RotaxEngines-List message posted by: MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
Doug MacDonald
912 UL
NW Ontario, Canada
le, List Admin.
aoldman(at)xtra.co.nz
PostPosted: Wed Jul 07, 2010 12:56 am    Post subject: rough running at 3400 RPM and above Reply with quote
When you stopped the engine to check the plugs did you also check the fuel in the carb bowls. The fuel pump { or filter }may not be delivering sufficent fuel to keep it running at high RPM settings. Have you check the exhaust has not become obstructed while the engine was not being used , that problem can also become apparent at high RPM . Just some more things to check.
Downunder
MK111c
joeing701(at)simnet.is
PostPosted: Wed Jul 07, 2010 2:57 am    Post subject: rough running at 3400 RPM and above Reply with quote
Hello Doug.
My friend has a similar problem with his Kitfox and a few days ago he
noticed that the primer line was broken and was sucking air. It was
not the only cause for his rough running engine problem, but I think a
few small air leaks can have a bad effect at hight rpm.
He had checked the primer pump and the lines but could not find any
problems, until he took the line off the carb, he saw the broken line
by the clamp on the carb.
I hope this helps in finding the cause of your rough running engine.
Johann G.
CH-701
912 UL
Iceland.
at about 3400 RPM.
Doug MacDonald
912 UL
NW Ontario, Canada
Thom Riddle
PostPosted: Wed Jul 07, 2010 3:59 am    Post subject: Re: rough running at 3400 RPM and above Reply with quote
Doug,
I suggest you go to http://www.bingcarburetor.com/manual.html
and buy their manual for US$11. With this you should be able to do a complete inspection and cleaning. A ten year old carburetor is likely to need new seals/o-rings. This is also an opportunity to make sure that the correct jets are in place. I've done many Bing 64 and Bing 94 carb cleaning and inspections and it is not uncommon to find carbs with the wrong jets installed and bad seals, especially on older ones.
If you don't feel comfortable doing the complete inspection and cleaning let me know. I do them for $50/carb plus parts and only replace parts that actually need replacing. I'm not trying to sell you a service because I feel that anyone who can build an airplane can do this work themselves with the proper documentation. But some are not comfortable going deep into their carburetors so I offer this service.
Thom Riddle
Buffalo, NY
http://sites.google.com/site/riddletr/a&pmechanix
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
ami(at)mcfadyean.freeserv
PostPosted: Wed Jul 07, 2010 11:56 pm    Post subject: rough running at 3400 RPM and above Reply with quote
There is also a filter in the mechanical fuel pump.
Obviously there is no way of cleaning this.
Only a fuel pressure test (measured downstream of the pump) will give a clue as to whether its blocked.
Duncan McF.
ptag.dev(at)tiscali.co.uk
PostPosted: Thu Jul 08, 2010 3:13 am    Post subject: rough running at 3400 RPM and above Reply with quote
Hi! I’ve not been following this thread but the electrical fuel pumps also have a very fine thimble filter in the intake end which needs VERY careful attention to remove it for inspection/cleaning and it is impossible to get a replacement filter .Returning this filter into its working location needs a very blunt instrument to push the filter into place from the bottom of the thimble shape taking care not to damage the gauze.
Bob Harrison.
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Duncan & Ami McFadyean
Sent: 08 July 2010 08:55
Subject: Re: RotaxEngines-List: Re: rough running at 3400 RPM and above
Duncan McF.
dougsnash
PostPosted: Thu Jul 08, 2010 7:51 am    Post subject: rough running at 3400 RPM and above Reply with quote
Thank you for all of the suggestions. I'll be looking into these issues a little further this weekend.
Yesterday I ordered a complete overhaul kit for both carbs. It's a little pricey but then everything will be new. This morning I ordered the Bing manual. I've probably spent more on the three gallons of 100LL I've burned troulbeshooting this issue than the cost of the manual.
Anyway, all of this stuff should be here Monday or Tuesday so hopefully I'll be running correctly by mid next week. I'll keep you informed.
Thanks again
Doug MacDonald
CH-701
NW Ontario, Canada
dougsnash
PostPosted: Wed Jul 14, 2010 6:14 pm    Post subject: rough running at 3400 RPM and above Reply with quote
An update on my progress. I recieved the carb rebuild kits and have installed them. Tonight I ran the engine up and it runs a bit better but still not right. Now I am able to get it up to 3800 before it starts to miss and bog down. Again, I am still able to get it up to over 4000 RPM by pulling on the enrichener.
I performed a full carb sync on it today. I was able to get the gauge needles to line up very nicely. While I had the carbs off for cleaning and rebuild, I pulled the carb sockets off and they are like new, no indications of leaks.
I disconnected the fuel line where it goes into the engine fuel pump and checked for flow from the electric Facet I am using in lieu of gravity feed. There is a steady stream of fuel coming form the the line. I pulled the fuel lines at the carb and ran the Facet again and am getting lots out of the carb fittings too.
Next, I disconnected the airbox from the carb and had my assistant run the engine up. I watched the carb slide and at 3800RPM, the slide was about two thirds to three quarters open. About where I think it should be at that power level.
I'm starting to think this might be an ignition problem. All of the plugs are new and I gapped them when I installed them but I don't recall now what I gapped them to. I see in the maintenance manual it says to gap them to 0.027 to 0.031. I'll have to check that tomorrow and see where they are at.
I don't know guys, any suggestions?
Doug MacDonald
CH-701, North Western Ontario, Canada
E. D. Eliot
PostPosted: Wed Jul 14, 2010 7:56 pm    Post subject: rough running at 3400 RPM and above Reply with quote
No experience with Rotax yet but did solve a few 'automobile engine problems' by first checking the resistance of the high tension wires.  Once, I replaced spark plugs and one of the 'new' ones was bad.  God luck  - we;ll all learn from watching your progress.
Date: Wed, 14 Jul 2010 19:12:19 -0700
Subject: Re: rough running at 3400 RPM and above
--> RotaxEngines-List message posted by: MacDonald Doug <dougsnash(at)yahoo.com>
Doug MacDonald
&gt=====================
[quote] _===================
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail. Get busy.
now is the good life - enjoy it
Dick Maddux
PostPosted: Thu Jul 15, 2010 4:58 am    Post subject: rough running at 3400 RPM and above Reply with quote
Doug ,
Have you done a mag check? I had a rough runner and it showed up in the mag check. After much work,frustration,etc I called Ronnie Smith at South Mississippi Light Aircraft and he suggested I check the red power lead to the coils for a break. I used a sewing pin with an ohm meter and attached one lead to the pin (the other to ground). By penetrating the plastic shielding of the wire I worked my way back along the wire and sure enough I found the break along a flat run. It was totally invisible from looking at it. With a cut and splice, I was back in business.
You could call Ronnie. He is very helpful and sure knows these engines!
      Dick Maddux
      912 Ul
      Milton,Fl
sdemeyer
PostPosted: Thu Jul 15, 2010 5:21 am    Post subject: rough running at 3400 RPM and above Reply with quote
I know this will sound silly but, do verify your spark plugs wires are going to the correct cylinders. When I purchased my KF, I had a similar problem and found that the guy I purchased from had swapped a couple of ignition wires. Once I put them on the correct cylinders, problem went away. Download the Rotax heavy maintenance manual and compare with the schematics.
Scott
Date: Thursday, July 15, 2010, 5:56 AM
Doug ,
    Dick Maddux
        912 Ul
        Milton,Fl
http://www.matronics.com/Navigator?Rtarget="_blank"
el="nofollow" target="_blank" href="http://www.matronics.com/contribu===
rayw
PostPosted: Thu Jul 15, 2010 6:26 am    Post subject: Re: rough running at 3400 RPM and above Reply with quote
Doug,
I have had this problem you describe. Spraying carb cleaner into the jets and visually inspecting is not enough. You need to take a small piece of stiff wire and work it around the jet ofice to get the "crust" to break loose. This happened to me and the "crust" was in the main jet of just one carb.
I actually used the needle from the jet and not a piece of wire. I was careful not to bend the needle.
Ray
Gtblu
PostPosted: Thu Jul 15, 2010 2:34 pm    Post subject: rough running at 3400 RPM and above Reply with quote
Hi Doug,
Have you tried a diferent Prop. I had the oppertunity to try some diferent props a few years ago, and each caused a diferent rough spot in the engine. Worth a go to eliminate that as the problem.
Cheers
Gtblu
PostPosted: Fri Jul 16, 2010 6:05 am    Post subject: rough running at 3400 RPM and above Reply with quote
Hello Rotax owners.
My friend is also experiancing rough running on his Rotax 912 ul and has done all kinds of adjustments,replacing carb parts and cleaning, but is tearing the engine off to look at the electrical system. His plane is a Kitfox and the engine is to close to the firewall to do any inspection on the megnetos and ignition system.
We were wondering if anyone has replaced the spark plug wires without replacing the ignition coils? Are the wires screwed into the coils or glued?
Johann G.
Rotax 912 ul.
Zenith 701
Doug ,
                                             Dick Maddux
                                             912 Ul
Roger Lee
PostPosted: Sat Jul 17, 2010 2:03 pm    Post subject: Re: rough running at 3400 RPM and above Reply with quote
The spark plug wires screw into each coil. The wires can be replaced.
It may just be the air gap between the pick up coils and the sensor that needs adjusting. Bad grounds can cause these type of problems. If someone has just rebuilt the carbs just prior to this that is where I would look. Someone may have put a part in the wrong way. Yes there are a few parts that can be installed wrong.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Goto page 1, 2  Next
Page 1 of 2
