smokyray(at)rocketmail.co Guest
Posted: Tue Jul 06, 2010 8:27 am Post subject: Prop me Up! |
Guys,
I have decided to "lighten up" the front end of my HR2 and go to a composite propeller. I have seen several MT props for sale in BS and wonder how you MT flyers like your prop? I also like the Whirlwind but $$$ is a factor. Jim A and Gummy are running 4 blades, how do you guys like them?
Since most of my flying includes over the top aerobatics, a lighter nose would be nice although my Hartzell 2 blade "paddle" has served me well.
Any comments prop or con would be appreciated.
Smokey
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
t.gummo(at)verizon.net Guest
Posted: Tue Jul 06, 2010 12:21 pm Post subject: Prop me Up! |
Smokey,
I very much like the look of my MT prop. As I don't fly in the weather and live in the desert, I have not seen the effects of rain on the paint. I think I remember hearing about the paint taking a beating when flying in heavy rain.
I have two issues with the four blade MT prop I have. First, I lost about 10 knots TAS at cruise altitude with the four blade. When I had the Hartzell two blade, at 10.5 or 11.5 my normal cruise altitude, full throttle, prop back to 2100 or so, leaned out to 10.5 gallons per hour, I trued at 180 knots. Now, I true at 170 knots under that same conditions. Again, it sure looks good. Jim Ayers tells me that I don't have enough power to use the prop properly (my IO-540 J4A5, is only 250 hp). I did get a great deal from John when I got it. (See, I told you all that I have the slowest rocket.)
Jim Ayers allowed me to use a three blade MT prop for a couple weeks and it very hard to tell it there was any speed lost at all. I keep trying to get him find someone that wants the four blade and will trade me for the three blade.
Second, I use the full throttle hot start technique. As all the weight is in the hub, it spins up quickly. (It was only two pounds lighter than the Hartzell.) So when the engine starts, it CAN very quickly gets to 1200 to 1500 prm while I am reducing the throttle, adding mixture, etc. etc (normally, I don't see that high of rpm on start but it has happened).
I have had the tail come off the ground and don't want ANOTHER Prop strike (reason for getting another prop in the first place). Which, it why I clear in front of me and if the plane wants to roll a couple feet while I am starting, I let it. So, while I call this an issue, it is not problem at all. Like most things, just learn to deal with it.
So fly out to SoCal and I will let you see the prop from the rear seat.
GummiBear
danweseman(at)yahoo.com Guest
Posted: Tue Jul 06, 2010 4:01 pm Post subject: Prop me Up! |
wanna sell the 2 blade hartzell?
Dan Weseman
www.flycleanex.com
www.fly5thbearing.com
To: rocket-list(at)matronics.com
Sent: Tue, July 6, 2010 4:18:50 PM
Subject: Re: Prop me Up!
Smokey,
GummiBear
Posted: Tue Jul 06, 2010 5:18 pm Post subject: Prop me Up! |
Sorry i was asking Smokey.... 180 knots at 10.5 gph... im going out to buck some rivets
Dan Weseman
www.flycleanex.com
Sent: Tue, July 6, 2010 8:24:39 PM
DIV { MARGIN:0px;} Dan,
I would love to sell you the 2 blade hartzell. How about 3000 dollars????
WAIT !!
REREAD !!
the reason for changing to four blade MT.
"don't want ANOTHER Prop strike (reason for getting another prop in the first place)."
I might even give it to you.
I would have gone with another 2 blade Hartzell but there was a 6 month wait and I drove and got the MT prop from John Harmon the next day. After the engine was re-installed after the prop strike check, I was flying a day later.
I have beeb loaning out the prop hub to help builders adjust and fit their cowl.
DO NOT ARCHIVE
GummiBear
N561FS - Harmon Rocket II
375 hours and still smiling
lessdragprod(at)aol.com Guest
Posted: Tue Jul 06, 2010 7:46 pm Post subject: Prop me Up! |
Hi Smokey,
Tom Gummo has the 4 blade propeller designed for the HR3 with a 380 hp engine. Tom Gummo's HR2 doesn't have a 380 hp engine. Therefore, the speed loss.
The 4 blade propeller designed for the HR2 with 260 hp is set for cruise at 15k. It is about 2 knots slower than the 3 blade MT propeller at 4k. And slightly faster tah the 3 blade by around 9k.
If you are flying around 5k, then you'll want a 3 blade propeller. The standard 3 blade MT Propeller assembly weighs around 56 pounds, conpared to 66 pounds for a Hartzell 2 blade propeller assembly on the same scales.
The 3 blade MT propeller is about 2 knots faster than the "D" blade Hartzell, and the same speed as the "J" blade Hartzell, at Reno race altitudes.
With both the "D" blade Hartzell and the 3 blade MT Propeller strsight and level at full throttle, above 2600 RPM the aircraft losses about 3 mph.
The "J" blade Hartzell keeps pulling to 2800 RPM. However, Wolfgang Meng says with 330 hp, the "J" stops at 2600 RPM, also.
Jim Ayers
Posted: Wed Jul 07, 2010 4:55 am Post subject: Prop me Up! |
Which prop offers most low speed thrust and climbs the best ?
Dan Weseman
www.flycleanex.com
From: "lessdragprod(at)aol.com" <lessdragprod(at)aol.com>
Sent: Tue, July 6, 2010 11:46:10 PM
Hi Smokey,
Jim Ayers
Speedy11(at)aol.com Guest
Posted: Wed Jul 07, 2010 5:21 am Post subject: Prop me Up! |
Smokey,
I'm flying a lowly RV-8A with 210 HP (and thus don't need 3 blades), but I have the MT 3 blade and I'm mostly happy with it. In drag races with 2 blade Hartzells, I stay right with them.
The spinner is chrome-look, made of Kevlar, and is very light.
You can see the prop at http://www.rv-8a.net/2007.htm and scroll down to 2 Apr 07.
I have flown in light to moderate rain and the leading edge of paint is shredded.
Climb performance and acro performance with the 3 blade is excellent.
Corrosion on the leading edge metal is a constant problem.
Stan Sutterfield
| Quote: | --I have decided to "lighten up" the front end of my HR2 and go to a co
tor. -Jim A and Gummy are running 4 blades, how do you guys like them?-
- Since most of my flying includes over the top aerobatics, a lighter nos
e would be nice although my Hartzell 2 blade "paddle" has served me well |
Posted: Wed Jul 07, 2010 12:21 pm Post subject: Prop me Up! |
That would be the 80" diameter 3 blade MT Propeller that Sean Tucker and Kirby Chamblis use.
We haven't talked about that one yet. Of course, cruise speed suffers slightly.
Jim Ayers
Posted: Wed Jul 07, 2010 2:32 pm Post subject: Prop me Up! |
Hi Gummy, greatly appreciate it! My "classic" HR2 performs exactly like yours did with the 2 blade D twist. I operate off a short grass strip and most every flight involves aerobatics, so a light nose would be very nice.
Jim Ayers is working some numbers up for a three blade MT, looking forward to seeing it.
Thanks again!
Smokey
Date: Tuesday, July 6, 2010, 1:18 PM
Smokey,
GummiBear
jrstone(at)insightbb.com Guest
Posted: Wed Jul 07, 2010 3:35 pm Post subject: Prop me Up! |
Rob, just to chime in, I love my MT 3 blade 205 kts TAS at max map, 2300 rpm and 11 gal/hr up to 9k then less above. I get about 500 miles with a 10 gal reserve, no wind. I normally cruise at 9 or above with max map and 2200 rpm yielding 198-200 kts TAS. I got my MT from Jim A. he is a great source of accurate info.Jim StoneLouisville Ky
PS When we gonna have that east coast Rocket fly-in?
Thanks again!
Smokey
--- On Tue, 7/6/10, Tom Gummo <t.gummo(at)verizon.net (t.gummo(at)verizon.net)> wrote:
From: Tom Gummo <t.gummo(at)verizon.net (t.gummo(at)verizon.net)>
To: rocket-list(at)matronics.com (rocket-list(at)matronics.com)
Smokey,
GummiBear
Posted: Wed Jul 07, 2010 5:12 pm Post subject: Prop me Up! |
Hi Guys Im still up for a fall east coast rocket flyin. I talked to my rv freinds and they are up for one here at 7FL (haller airpark) i was wanting to get past Oshkosh then start making plans,any suggestions for a date etc would be great.
Dan Weseman
www.flycleanex.com
Sent: Wed, July 7, 2010 7:34:50 PM
Rob, just to chime in, I love my MT 3 blade 205 kts TAS at max map, 2300 rpm and 11 gal/hr up to 9k then less above. I get about 500 miles with a 10 gal reserve, no wind. I normally cruise at 9 or above with max map and 2200 rpm yielding 198-200 kts TAS. I got my MT from Jim A. he is a great source of accurate info. Jim Stone Louisville Ky
Thanks again!
Smokey
Smokey,
GummiBear
Posted: Thu Jul 08, 2010 10:56 am Post subject: Prop me Up! |
Thanks Jim!
On Jul 7, 2010, at 7:34 PM, Jim Stone <jrstone(at)insightbb.com (jrstone(at)insightbb.com)> wrote:
[quote]Rob, just to chime in, I love my MT 3 blade 205 kts TAS at max map, 2300 rpm and 11 gal/hr up to 9k then less above. I get about 500 miles with a 10 gal reserve, no wind. I normally cruise at 9 or above with max map and 2200 rpm yielding 198-200 kts TAS. I got my MT from Jim A. he is a great source of accurate info.Jim StoneLouisville Ky
Thanks again!
Smokey
--- On Tue, 7/6/10, Tom Gummo <[url=mailto:t.gummo(at)verizon.net]t.gummo(at)verizon.net (t.gummo(at)verizon.net)[/url]> wrote:
From: Tom Gummo <[url=mailto:t.gummo(at)verizon.net]t.gummo(at)verizon.net (t.gummo(at)verizon.net)[/url]>
To: [url=mailto:rocket-list(at)matronics.com]rocket-list(at)matronics.com (rocket-list(at)matronics.com)[/url]
Smokey,
GummiBear
Posted: Thu Jul 08, 2010 10:57 am Post subject: Prop me Up! |
How about 1 Oct( my birthday:)
Smokey
On Jul 7, 2010, at 9:12 PM, Daniel Weseman <danweseman(at)yahoo.com (danweseman(at)yahoo.com)> wrote:
Dan Weseman
www.flycleanex.com
Thanks again!
Smokey
Smokey,
GummiBear
